Brand Specific Forums
Bullfrog Spas
Bullfrog A8 Electrical Panel
Pages: [
Topic: Bullfrog A8 Electrical Panel (Read 5866 times)
Sorrentino100
Junior Member
on:
October 13, 2017, 03:49:36 am »
Moving from a 20-amp/30-amp HotSpring electrical box. What exactly is needed for a Bullfrog A8? I would appreciate if you would let me know what I'll need.
The HotSpring panel and circuit breakers are for sale if anyone is interested.
on:
Senior Member
Re: Bullfrog A8 Electrical Panel
Reply #1 on:
October 13, 2017, 12:40:06 pm »
Regular old 50 amp gfci
d00nut
Full Member
Reply #2 on:
October 13, 2017, 01:35:11 pm »
50 Amp GFCI, and then you'll need to pull new wire from the panel to the hot tub (4 wires for the BF #8s) versus the #10 & #12 for the Hot Spring.
Thisismyname
Full Member
Reply #3 on:
October 13, 2017, 06:54:09 pm »
I just pulled 4 #6 wires for the A8 from the 50a GFCI
Sorrentino100
Junior Member
Reply #4 on:
October 13, 2017, 09:13:51 pm »
The wire from the house circuit breaker reads: Romex Simpull (TM) AWG 6 CU3 CDR with AWG 10 Ground Type NMB 600 Volts Covered. This goes from the house circuit breaker out to the 20/30 amp panel on the outside. Probably around 54 feet of it from CB to outside box.
Lowe's and HD had Eaton 50-amp panel "BR" series. It states to use a different series for outdoor use. I went on HD's website and found this:
http://www.homedepot.com/p/Midwest-Electric-Products-50-Amp-240-Volt-240-Watt-Non-Fuse-Metallic-Spa-Panel-Disconnect-with-GFI-UG412RMW250P/100686230
. Is this what I need?
The HotSpring panel setup was around $400.
Sorrentino100
Junior Member
Reply #5 on:
October 16, 2017, 09:07:34 pm »
Look like the Eaton CH500SPA may be a good choice. It's a good size box with touted premium features.
http://www.eaton.com/Eaton/ProductsServices/Electrical/ProductsandServices/Residential/SpaPanels/CHSpaPanels/index.htm#tabs-2
Fcat
Junior Member
Reply #6 on:
October 18, 2017, 06:44:44 pm »
Quote from: Thisismyname on October 13, 2017, 06:54:09 pm
Dont you have to use #6 wire ? or is #8 acceptable for 50 amps ?
Reply #6 on:
Pages: [
Bullfrog Spas
Copyright ©1998-2026, Whats The Best, Inc. All rights reserved. Site by
