Author Topic: 3 Year old Jacuzzi J325 waterfall issues.  (Read 13398 times)
im45us
« on: August 12, 2017, 10:12:33 am »
Has anyone taken apart the water fall on a J325? I can't turn mine off . I turn the wheel and nothing. I have not found much about that on line, just for older tubs and it all seems to involve cutting pipes. I am wondering if the top pops off? The front comes up but the back doesn't seem to move and I don't want to break anything.
Re: 3 Year old Jacuzzi J325 waterfall issues.
« Reply #1 on: August 12, 2017, 11:53:01 am »
 They really are not fixable, you will have to order a new one.   To remove it, take off the back panel.  Then reach up under the shell below the WF and unhook the 3/4" line running to it.   I use to just cut the line and splice a new line in if that makes sense?  Then unscrew the nut holding the WF in place.  Then reverse the steps when putting the new one back in.   You will also have to unplug the light ribbon as well.    It's not a hard job, just a PIA if you have never done it.
  Does it look like this one?
 https://www.spastore.com/jacuzzi-j-300-series-waterfall-kit-6560-125-replaced-6560-130-2540-904-2007-2015/?utm_medium=googleshopping&utm_source=bc&gclid=EAIaIQobChMI4LH6lobS1QIVAWZ-Ch3srQjSEAQYBCABEgIx7fD_BwE
im45us
« Reply #2 on: August 12, 2017, 04:07:53 pm »
Yes it does look like that but I would think it should be under warranty so maybe I will talk to the place I purchased it from.
BullFrogSpasMN
« Reply #3 on: August 12, 2017, 06:14:20 pm »
every jacuzzi waterfall breaks because they don't know how to plumb a spa properly
« Reply #4 on: August 12, 2017, 06:35:48 pm »
    The plumbing is not the issue, Bullfrogs are plumbed the same.   They are just crappy waterfalls.
« Reply #5 on: August 12, 2017, 08:50:16 pm »
This is right on. I used to just cut the line also and splice in a new piece. It's easier. Ain't done one in like 10 years though. Do it during a drain and refill.
