Author Topic: Leak  (Read 1992 times)
nicker22
Leak
« on: August 19, 2014, 08:52:36 am »
So I have a leak in my Beachcomber tub.  I have found the leak which was the light unit.   My question is now, I have removed allot of foam to find this leak, will the existing foam in the tub dry out on its own or do I have to remove all the wet foam?   What is the best way to re-insulate my tub?
thanks
Leak
Re: Leak
« Reply #1 on: August 19, 2014, 08:55:09 am »
I like to remove as much of the wet foam as possible. The new spray in foam will adhere better. But don't re-foam until you are sure of your repair.
Re: Leak
