Author Topic: Air Jets?  (Read 9668 times)
bulmer4nc
  • Now a Canes Fan.
Air Jets?
« on: June 19, 2004, 09:23:25 am »
Hey All,
Myself and my wife went out for a round of wet testing yesterday afternoon.  Tested from the 3 main dealers in the area.  We tried 2 Marquis (SA reward and euphoria), 2 Sundance (cameo and optima), Jacuzzi 375 and Hotspring Vista.
We really like the air jets on the Sundance.  What are everyone's thoughts on air jets / blowers?  I've read and been told a lot about them cooling the water and stuff like that.  Wanted to get some other opions too.
I think we're ready to pull the trigger on the Optima... Just wanted see what everyone thought of air first.
Guess the biggest thing is how reliable are the air blower pumps?  Do they last as long as the regular pumps?
Thanks,
Ken
Air Jets?
Grant
Re: Air Jets?
« Reply #1 on: June 19, 2004, 09:49:18 am »
My wife likes the air jets the best. As for temp, who cares!
Re: Air Jets?
« Reply #2 on: June 19, 2004, 10:27:00 am »
I also like the air jets.  It gives a totally different type of action.  We use them mostly during summer when the water never cools no matter what you do.  They are really great when you have a lot of people in the spa.
« Last Edit: June 19, 2004, 10:28:27 am by tony »
Rboehme
Re: Air Jets?
« Reply #3 on: June 19, 2004, 04:52:01 pm »
Typically the air blower will fail before your water pumps. This is usually due to the check valve failing and allowing water into the air blower.
Re: Air Jets?
« Reply #4 on: June 19, 2004, 07:45:33 pm »
We have the blower on our spa, I am neutral toward it, my wife, who's opinion is way more important than mine, loves it.  She's also into the aroma thing, which is dispensed thru the air blower system.
If the air blower wears out, no big deal, just have the motor replaced.  You can still use the spa without it.
dazedandconfused
  • Still Negotiating ....
Re: Air Jets?
« Reply #5 on: June 19, 2004, 07:59:11 pm »
Brewman -
Can you really smell the scents bubbling thru the water?  When I wet tested the cameo/optima, the dealer put new lemon scent in but I couldnt smell anything - maybe my nose is getting old!
ZNICK
Re: Air Jets?
« Reply #6 on: June 19, 2004, 09:48:13 pm »
A blower adds water movement to a tub, but so does a tub with more "water jets".  In the end, it's strictly opinion, although a VERY high % of my customers opt to get the blower with the air jets.
To me, an important consideration is how the tub is insulated.  If the tub is a "full foam" tub, the blower will be pulling air from outside of the cabinet, therefore (in the cooler months/climates) you WILL have cold air coming in, which is uncomfortable, and cools the water. If you have a "thermal pane" insulated tub the air comes from inside the cabinet... therefore it won't cool the water, and wont be as uncomfortable.   Granted, the air inside the cabinet is not as hot as the water itself, but 90 degrees is a lot better than 15 degrees.
Also consider cleanliness and safety. When you turn the blower motor off, water will backflow into the lines.  Make certain that there are one way valves to be sure water cannot backflow into the blower motor.
You should also make sure that the blower automatically turns on a couple times a day for 30 seconds or so.  This will force this water out of the hoses and back into the tub so it can be filtered and cleaned.   If your tub doesn't do this, and you don't use the spa for several days/a week, the water in the hose can get "stagnant" and you'll smell an odor for a couple of minutes when you turn on your blower, and this "old" water is finally pumped back into the tub.  (sometimes the reason they put the "scent" into the system at the showrooms before turning the blower on?)
Z
« Last Edit: June 19, 2004, 09:49:06 pm by ZNICK »
Re: Air Jets?
« Reply #7 on: June 21, 2004, 01:57:41 pm »
dazedandconfused
Lemon is the weakest scent that SD offers (except maybe apple).  Lavender is the strongest I've experienced so far and lasts a long time.  Some of the scents you can hardly notice even when new, while others work very well.  I'm still experimenting.
doodoo
Re: Air Jets?
« Reply #8 on: June 21, 2004, 02:14:14 pm »
I agree with Tony that the Lavender is the most powerful. And like Brewman, my wife loves it and that is what matters most, for if she is happy, so is daddy ;).
Truly though, you are in NC or thereabouts, so the temps don't get that chilly.  Here in Ottawa, it can get a little colder but hey I agree, so what.  Bought my Optima for several reasons and one of them was the blower.
Most of the issues raised about cleanliness are covered with the Sundance line given that the tub is programmed to flush once per day at midnight for two minutes and is not user programmable which means that you cannot over ride it. It will activate Pump no. 2 and the blower to circulate any water in the plumbing. After that Pump no. 1 will kick on for one minute.
empolgation
  • you pay what you get it for
Re: Air Jets?
« Reply #9 on: June 21, 2004, 02:20:45 pm »
??? and where does the air come from that replaces the "90 degree" air from inside the cabinet... the "15 degree" air no?
The blown air doesn't get heated in either case.
Sounds to me like it doesn't make a difference.
Using the above example you either pull outside air directly or suck outside air into the cabinet before blowing it. Either way you are cooling down your water; granted, one way may be more uncomfortable than the other.
« Last Edit: June 21, 2004, 04:02:41 pm by empolgation »
e
Re: Air Jets?
« Reply #10 on: June 21, 2004, 02:55:42 pm »
For those of you who have the Sundance Aromatherapy system, describe for me what the container that you drop the crystals into looks like.
Here is why I ask.  On my Dynasty, you unscrew a cap on the top of one side of the tub and drop in the bag of smelly crystals.   It goes into a chamber that appears to be an upside down T.  If you can imagine this you are dropping the bag into the vertical part of the T and the horizontal part of the T looks like its a main air line heading to the diverter for pump number 2.   There is a single screen that prevents the fragarance bag from falling all the way in.  However, the bag never goes past the vertical part of the T so it is not in the direct air flow. (unless perhaps you take the cover off?)   If they put 2 screens on the horizontal part of the T and allowed the crystals to set directly in the air line, perhaps it would work better?  I'll have to recheck the owners manual to see if they recommend keeping the cap open. I'm curious to see if yours is diferent, if I was able to explain myself clearly :)
« Last Edit: June 21, 2004, 02:56:35 pm by wmccall »
doodoo
Re: Air Jets?
« Reply #11 on: June 21, 2004, 03:50:54 pm »
wwmcall - The Sundance aromatherapy is similar in approach to what you describe for your Dynasty. You unscrew a main cap and then unscrew a secondary cap underneath which has a seal built in. Inside is a cavity which has the cappacity to hold a sealed container of beads. You can only insert the Sundance aromatherapy container because it is shaped in the same manner and is a perfect fit. The beads never come in contact with the water as the airblowers rush air past the beads on their way to the tub. So this is more or less the same approach.
You raise a good point empolgation. The open space within the thermopane style has only enough air to supply about 1 second of air to the tub. Which must be replaced by outside ambient air in order to feed the demand.
The biggest difference is that on the full foam the intake does not impede air flow as it is set within the cavity of the mechanicals. The mechanical space on the Optima has vents on the top to permit air movement with the rest of the skirting having a 1'' insulation.  I am uncertain and perhaps the termopane owners and dealers can clarify this, but I remember a dealer we visited and he used this as a selling feature that warm air for the blower was better than cold air. A quick visit with some basic mathematics and we quickly established and agreed that the capacity of the air blower on that product meant that the warm air in the cavity was gone in just under one second.  And therefore like a house that is very drafty, and when air is forced through cracks and cavities or through insulation you get a a gradual breakdown of the effectiveness of said  barriers in insulation thereby reducing the effectiveness R value over time. I don't remeber vents on the product we saw. IMHO
« Last Edit: June 21, 2004, 03:58:39 pm by doodoo »
usuallytrue
  • Sundance owner
Re: Air Jets?
« Reply #12 on: June 21, 2004, 05:44:55 pm »
I have the Altimar and I for one love the air jets.  I don't know why - just a different sensation - maybe it's a girl thing ;) (you know, bubble baths, champagne...)
That was one of the features that swayed me over HS and now I like the option of using it or not.
As for the aromatherapy - I've been using the lavendar and it works ok - not as intense as I thought it would be, but pleasant...I wouldn't use it as a deciding factor though...
bulmer4nc
  • Now a Canes Fan.
Re: Air Jets?
« Reply #13 on: June 21, 2004, 11:48:18 pm »
All this talk about the air basically coming from outside the cabinet is probably true (even though the dealers say it is taken from inside).
My question now is this: Is this not also true for the air that is added to the regular jets?  The dealers have told me it's a valve that opens up at the pump itself to allow air to mix with the water.  If this is cold air, then wouldn't this 'cool' down the water as much or even more than the small air jets?  It seems like lots of air gets added to the water stream when you turn it up to get more action in the tub.
Ken
empolgation
Re: Air Jets?
« Reply #14 on: June 21, 2004, 11:53:29 pm »
The air has to come from somewhere, no tub has a hot air storage tank whether it's full foam or thermopane.
e
Re: Air Jets?
