Author Topic: Del Zone Ozone Test Kit  (Read 3981 times)
dennisoates
« on: August 29, 2013, 07:39:01 am »
Has anyone had any luck with this ozone test kit. I am using a 10 year old Prozone ozonater and wonder if its still functioning properly. thanks
Re: Del Zone Ozone Test Kit
« Reply #1 on: August 29, 2013, 09:13:19 am »
Is this on your Jacuzzi 355?
dennisoates
« Reply #2 on: August 29, 2013, 11:04:39 am »
yes, Jim, it was plumbed for a ozonater, I took mine off my old Jacuzzi,, and hooked it up, I ran a wire to a outlet, because as you said mine is 220v, but the think is old, but I see the ultraviolet light glowing and it bubbles in the spa.
« Reply #3 on: August 29, 2013, 01:40:33 pm »
 My guess is after ten years the thing is not producing ozone anymore, life of any ozonator is around 5 years.   Ultraviolet might last a bit longer but the output of the bulb is probably zero, even though it's on.
 Pretty good price on this on just make sure it's 220v
 http://www.hottubwarehouse.com/Del-Ozone-Spa-Eclipse-Ozonator-p/spa%20eclipse.htm?1=1&CartID=0
« Last Edit: August 29, 2013, 01:48:07 pm by Jacuzzi Jim »
dennisoates
« Reply #4 on: August 30, 2013, 05:48:55 am »
thanks Jim, by female plug is different then any I have seen, can I send you a email direct to see if you recognize it? or try this link
http://www.flickr.com/x/t/0099009/photos/rainbowtawas/9625792001/
thanks and do you know where I can purchase a service manuel for this j 355 Jacuzzi? really appreciate your help.
« Reply #5 on: August 30, 2013, 11:14:34 am »
  You want the mini JJ plug the one in the link looks like it but not sure those pins will match up and its a different color..
dennisoates
« Reply #6 on: August 30, 2013, 04:01:57 pm »
thanks Jim
