Author Topic: Freeflow Accent  (Read 18374 times)
dakota7557
Freeflow Accent
« on: December 01, 2012, 08:34:28 pm »
Hi, I'm from the Rapid City area and I've owned my Freeflow Accent for a month now and love it.  It holds 270 gallons and I had it hooked up to 220...If I knew how to post a picture I would...Jody
Freeflow Accent
JohnnyK45
Re: Freeflow Accent
« Reply #1 on: December 02, 2012, 02:07:00 pm »
A couple of steps...
1) Sign up for a free account at a photo hosting site; example: photobucket.com - there is no catch, it's simply a free and easy to use site that will host your images for you to share on any number of forums.
2) Reduce your image size if it's a large file size and upload your images to (example) photobucket.com
3) Simply copy the image code you'll see once you select that image at photobucket (or other hosting site) and insert that in your reply here (you will need to hit the "insert image" icon just above this box area, then you'll insert your code (paste it) between the brackets you'll see.
That's it; sounds more complicated in typing this out, but it's rather easy.
J
GrammaD
Re: Freeflow Accent
« Reply #2 on: February 03, 2013, 09:58:06 am »
I have had my Freeflow Accent since October 2011 with 110 amp service.  I love it, it's smaller than alot of the tubs out there but the $3400. price tag wasn't! :D :D
GrammaD
Re: Freeflow Accent
« Reply #3 on: February 03, 2013, 10:12:26 am »
trying to follow the upload directions, not sure if this worked!
ADMIN NOTE: I tried to help, but the link odesn't seem to be correct.
« Last Edit: February 06, 2013, 08:08:44 am by wmccall »
Re: Freeflow Accent
« Reply #4 on: February 06, 2013, 08:11:25 am »
Hot Spring Ace
Re: Freeflow Accent
« Reply #5 on: February 06, 2013, 04:49:30 pm »
The link was good because I saw it right after she posted it, 3 people in a Freeflow, 2 were kids if memory serves me. The link must have gotten cut off since on the other end.
bimmerdog
Re: Freeflow Accent
« Reply #6 on: February 13, 2013, 11:01:49 am »
I use photobucket and it works fine on this site.  Hope you can find a system that works for you.  It's nice to see new tubs in their new home.
Re: Freeflow Accent
