Author Topic: shock spa hot spring Jetsetter with ACE System  (Read 8778 times)
fridaydog
« on: June 19, 2011, 09:04:34 pm »
I have a Hot spring Jetsetter with the ACR system.  I'm confused on how to shock the spa.  Do I add chlorine even though the ACE system is supposed to take place of adding chlorine.
Dan
Peter Lee
Re: shock spa hot spring Jetsetter with ACE System
« Reply #1 on: June 22, 2011, 07:49:29 am »
Spa Treatment is Really amazing. Last august I visited at Singapore. I got Spa treatment there. They do it with herbal remedies like Honey, fruits etc. hot spring fall was too good. I like there Eco friendly theme.
« Reply #2 on: June 22, 2011, 10:47:00 am »
...but the honey and fruit always gums up the filters.
soak-king
    • Backyard Oasis
« Reply #3 on: June 23, 2011, 12:40:50 pm »
Dan
You can manually tell the ACE system to shock the spa by pressing a few buttons. If you have some chlorine on hand it won't hurt anything to add it into the filter compartment (as long as it is the correct type of chlorine for spas)
robmet1015
« Reply #4 on: July 28, 2011, 11:16:58 am »
[/quote]
Is there a manual or link on HotSprings site that explains in detail how the ACE system works and what chemicals one would still need to utilize for a proper hottub balance...
« Last Edit: July 28, 2011, 11:26:55 am by robmet1015 »
d00nut
« Reply #5 on: July 28, 2011, 07:06:43 pm »
[/quote]
Your dealer should have given you the manual.  However, to shock the spa temporarily with the ACE system:
Options > Water Care > Boost.   Then it will ask you if you really want to boost the system... say yes (obviously!)  ;)
