Poll
How to reset ice falt on read out
a
1 (100%)
b
0 (0%)
Total Members Voted: 1
Author Topic: ice warning on marquis reward 2003  (Read 11958 times)
oldiron
« on: April 08, 2011, 12:00:43 am »
Hi all We just purchased a Marquis reward hot tub after filling I turned on as per book and I get a ice indicator on the display panel and now the heat will not come on. Any ideas how to reset this book says to contact dealer? Thanks in advance.
Bonibelle
  • '05 Marquis Epic
Re: ice warning on marquis reward 2003
« Reply #1 on: April 08, 2011, 10:14:40 am »
 I also have a Marquis tub and I do remember getting that ice warning after a refill. I believe it is a protection thing..I called my dealer for you and the tech will get back to me. As soon as he does, I will post. I think that once the water reaches a certain temp, it will start up normally...just right now the water is way too cold.
« Last Edit: April 08, 2011, 10:17:16 am by Bonibelle »
Bonibelle
  • '05 Marquis Epic
« Reply #2 on: April 08, 2011, 10:16:40 am »
My tech says leave things alone and once the water is above 55 degrees, the tub will run normally. So no worries, nothing is wrong..it is just a protection feature..good luck
colo_artist
« Reply #3 on: April 08, 2011, 10:20:48 am »
I just got a new Marquis. When I filled it up I got the ICE warning. I checked the manual and it says...
FREEZE PROTECTION
When a freeze condition is detected (which occurs
when the temperature in the heater housing drops to
55°F, (13°C) the jet pump(s) is automatically activated.
In areas with extremely cold winter conditions, your
spa should be fine as long as it is left running at normal
operating temperatures.
Once the temp got over 55 the ICE warning went away. As best I can tell all an ICE detection does is to turn on the pumps. It doesn't prevent the heater from heating.
oldiron
« Reply #4 on: April 08, 2011, 01:07:07 pm »
Thanks for all the help. What I came up with is yes the ice warning did go away but I found it was locked in sleep mode once I put it back into standard the heater came on and is working normal now. Guess I should read the book more ha ha.  Thanks again. Larry
« Reply #5 on: April 08, 2011, 01:24:18 pm »
That was interesting!   BTW, welcome to the forum oldiron
Bonibelle
  • '05 Marquis Epic
« Reply #6 on: April 08, 2011, 02:20:25 pm »
And this was a good example of why I support my dealer (and I just bought my new cover from him)..Help is only a phone call away..even help for forum friends  ;)
