Author Topic: What temp do you keep your spa when you aren't in?  (Read 4689 times)
solo
« on: October 30, 2007, 11:41:24 am »
Do you keep it close to soaking temp all the time or do you let it get down to a lower temp, then heat it up prior to getting in?
tony
  • 2002 Optima
Re: What temp do you keep your spa when you aren't
« Reply #1 on: October 30, 2007, 11:57:20 am »
102 all the time.
Repeat_Offender
« Reply #2 on: October 30, 2007, 12:21:05 pm »
101 all the time.
Bullfrog 562
« Reply #3 on: October 30, 2007, 12:50:41 pm »
I change it a couple of times a year for the seasons.  Other than that, I only drop it 5-15 degrees if I'm out of town for more than 3-4 days.
H823Putt
  • My backyard oassis
« Reply #4 on: October 30, 2007, 01:57:06 pm »
104 all the time. Sometimes I wish it went higher.
The_Pa._Lady
« Reply #5 on: October 30, 2007, 02:59:26 pm »
Solo,
I would think it would be more expensive to lower the temp and then reheat the water again to the temp you want it at.  I set mine at a certain temp and leave it there.
Happy Tubbing!!
Cyn
« Reply #6 on: October 30, 2007, 03:01:20 pm »
I turn my tub down to 101 and leave it there and then I turn it up to anywhere between 102 and 104 and close the lid for about 5-10 minutes before jumping in.
104 degrees
« Reply #7 on: October 30, 2007, 03:19:06 pm »
Summer 100 degrees. Winter 104 degrees :)
rick
« Reply #8 on: October 30, 2007, 03:37:02 pm »
what he said.
mark 2550
« Reply #9 on: October 30, 2007, 10:53:29 pm »
103 to 105 everyday so I can enjoy my soak when needed
