Original => Hot Tub Forum => Topic started by: In Canada eh on April 16, 2007, 06:46:55 pm
Now before all you Bullfrog bashers get your knickers in a twist,
ITS NOT FROM THE WATER BEHIND THE JETPACKS ;)
On Thursday I noticed a strange "plasticy" odour from our tub water, so I shocked with MPS, figuring it to be combined chlorine. Saturday the odour was still there :-?
So, ever wondering about all the Bullfrog rumours I checked in behind the jet packs and the water and plumbing all looked fine, I even went so far as to sprinkle a little dichlor in behind each seat.
Took alk and pH readings and all is OK, TDS was fine 2 weeks ago when dealer did test. So I wiped down all the surfaces and the cover and shocked again with MPS
Today when I got home the odour is still there :-?
Anyone have any ideas?
How old is the water?
Sorry, I guess I should have added that. The water is about 2 months old
does this tub get heavy use?
No, not normally about 2 or 3 times per week
Ever think it was coming from the cover and/or the bar top above the water line? Try some bleach and water on those surfaces, just may take care of it. ;)
How old is the spa. Cover is a likely suspect.
Hottub.pool-boy and hottubdan,
Tub is only one year old and when I shocked on Thursday I did wipe down the underside and all the seams of the cover.
Just got home and went and took a whiff, smell is still there but its not as bad :(
If I can't get rid of it by the weekend I will dump and refill
