Original => Hot Tub Forum => Topic started by: drewstar on March 07, 2007, 10:36:21 am
Title: Hotsprings auto clean system>
Post by: drewstar on March 07, 2007, 10:36:21 am
What became of the Hotsprings Autoclean (?) system that was recently introduced?  From my understanding,  this was an automatic sanitizer system that monitored and automatically added chems to the water.  It wasn't standard, but available for an additional charge.
I was over at the Hotsprings website, and saw no mention of it, and haven't heard any new buyers mentioning it.
It seemed like a good idea, but I was very curious/ a bit skeptical on how reliable it would be and all the variables involved with it. I wanted to learn more about it and see if it was a practical solution.
Was this an ill concieved idea and that has been deep sixed?
Title: Re: Hotsprings auto clean system>
Post by: hottubdan on March 07, 2007, 10:44:34 am
http://www.hotspring.com/Spa_Showroom_Hot_Tub/auto_fresh_spa_care.html
30th Anniversary has taken over as primary marketing position.
We have sold 3 systems so far.  All customers report success.
Need to balance water.  Then program dosing engine.  Monitor and adjust every 2 weeks.  Products are BaquaSpa.  I have found water is better than hand delivering Baqua products.
Post by: drewstar on March 07, 2007, 10:48:11 am
Thanks Dan.
How come I can't find that page when navigating via thier home page? I don't see any reference when going to hotsprings.com  I would think it would be at least mentioned under the water care section?
Post by: Chas on March 07, 2007, 10:49:07 am
(http://www.hotspring.com/Spa_Showroom_Hot_Tub/gifs/diag_autofresh_big.gif)
(A)  Dosing Engine
Your authorized Hot Spring dealer will install the dosing engine containing the advanced components that drive the AutoFresh system. The sophisticated switching valve, pump, and circuit board work together to calculate the precise amount of chemicals needed, and automatically dispense them into the spa water.
(B)  Cartridge & Cartridge Base
The cartridge base will be attached to the underside of the filter lid by your authorized Hot Spring dealer. You simply install the disposable AutoFresh cartridge, which becomes invisible once in place.
The cartridge contains a chlorine- and bromine-free sanitizer, shock, and waterline control. Each cartridge lasts about three months, varying based on spa size and usage.
(C)  Water Care Icon
IQ 2020 Spa Control SystemEvery two weeks, a flashing water care icon reminds you to test the spa water. Simply input the test strip reading into the IQ 2020® control panel or optional remote control.
(D)  IQ 2020® Control System
The Hot Spring IQ 2020® Control System communicates with the AutoFresh dosing engine, and together they determine and deliver the correct dosage.
The pH, Total Alkalinity and Hardness must be in the "ok" range indicated on the test strip container before adding AutoFresh chemical into the spa.
Download the AutoFresh Owner's Manual (PDF format - 1.16MB)
The sanitizer included in the cartridge is registered under EPA Reg. No. 1258-1265-73081.
8-)
Post by: Chas on March 07, 2007, 10:51:02 am
Thanks Dan.
Wow - you beat me to the post Dan.
Drew - look for this on the home page:
(http://www.hotspring.com/gifs/bug_autofresh_home.gif)
Post by: drewstar on March 07, 2007, 10:51:54 am
chas,
I'm relating this all back to my own limited experince with manual dosing of dichlor, and I only does after I am done using the tub for the day.  How does this system  handle this? IE: I don't want to get into the tub the moment after the auto system decided the water needed to be shocked, or is this set up that the user hits a button that says initates the auto system to test and dose?
How does it handle weekly shocking?
Post by: drewstar on March 07, 2007, 10:52:41 am
Ah....way on the bottom.  Should be in the Accesories section as well and listed as an option in each spec of the tub.  ;)
Post by: xrdirthead on March 08, 2007, 10:19:10 am
Any feedback on it yet? Too soon?
Post by: Vanguard on March 09, 2007, 12:49:04 am
chas,
The system does not "monitor" the water.  It is dosing the water on a regular basis.  So, the water gets shocked regularly (not sure what the interval is), plus sanitizer and water line control is added.
Every two weeks, the user tests the water with a biguanide test strip and inputs the info via the control panel.  The user must also check the pH balances as well.
The control panel has an icon that is on steady while AutoFresh is set.  The icon blinks at two weeks to tell the user to test the water.
If needed, you can add extra product via the control panel or by using regular biguanide products.
The system is pretty simple.  Just set up, then every two weeks test the water, input info and your done.
Post by: xrdirthead on March 09, 2007, 03:58:28 am
I think we need some field testing on this. Could someone please send me a Grandee and I'll let you know how well it works and drop in the stereo system while your at it.  ;)
Post by: Chas on March 09, 2007, 10:10:09 am
Absolutely.
I'll just get your delivery address off your check...
Send it to:
{Poster's address deleted by Mod}
 8-)
Post by: xrdirthead on March 09, 2007, 10:28:27 am
Single digit temps lately in Boston make me wish my address was in Vista, CA
Absolutely.
Send it to:
 8-)
Post by: Styx555 on March 09, 2007, 11:12:49 am
Quit complaining...we set a new record earlier this week with minus 42 Celcius.
Any pricing on the auto clean system?
Post by: Chas on March 09, 2007, 12:19:57 pm
Automatically, and it doesn't interfere with normal use of the tub at all.
 8-)
Post by: MarKee on March 09, 2007, 02:36:36 pm
I was wondering the same thing about the retail price of this system. I heard through others it was retailing between 1,000.00-1,500.00 is this accurate?
Post by: East_TX_Spa on March 09, 2007, 02:40:16 pm
We sell it for $1400.
Terminator
