Original => Hot Tub Forum => Topic started by: wmccall on February 27, 2007, 03:35:05 pm
Title: My next hot tub.
Post by: wmccall on February 27, 2007, 03:35:05 pm
I might go a little smaller, just the two of us now, not as many parties as I thought we might have.
Title: Re: My next hot tub.
Post by: Zep on February 27, 2007, 04:32:12 pm
I think I would stay about the same.
CalSpas SQ-92
Seating Capacity: 5-6 Person
Dimensions: 93" x 93" x 39½"
Dry Weight: 900 lbs
Filled Weight: 4,648 lbs
Water Capacity: 450 gal
If anything larger, but most likely the same.
My next one will be in-ground.
Post by: Chad on February 27, 2007, 06:35:31 pm
I'm with Zep.
When/if  I move into a bigger house with more of a yard, I will purchase a larger tub(possibly even a swim spa) and definetly sink it into a deck. All this really depends on what new home construction does for the next 5-10 years.
Post by: Vinny on February 27, 2007, 06:50:22 pm
I voted smaller but it would depend if the smaller one had different jet configurations.
The other thing and something that might be added is "none at all".
Depending on my future usage a tub may not be in the picture. I tend not to go in due to my wife doing homework with my youngest and I really feel guilty enjoying myself as she works to about 8:30 every night. I also don't feel sleepy as others do when I use the tub, so I am wide awake and tend not to go in late (8:30 isn't nessesarily late but I would be up to after 11).
Post by: Zep on February 27, 2007, 06:57:46 pm
WhyNot....they aren't for everyone....
but I just love the way an inground spa looks
(http://www.allspas.com.au/images/inground.jpg)
(http://www.allspas.com.au/images/DSCN1523.JPG)
(http://www.poolandspa.com/images-cool/spa01152000.jpg)
(http://www.poolandspa.com/images-cool/spa03462002.jpg)
(http://www.poolandspa.com/images-cool/spa01582001.jpg)
(http://www.poolandspa.com/images-cool/spa01332001.jpg)
Post by: Chad on February 27, 2007, 07:03:07 pm
Nice pics. 8-)
It's definetly the way to go, imo.
It actually becomes one with your property. I love it!
Post by: Spatech_tuo on February 27, 2007, 07:13:38 pm
I absolutely love the way they look as well. I just don't like the function you give up by sinking them all teh way in. I'm a half way man myself.
Post by: Vinny on February 27, 2007, 07:13:56 pm
Nice pics. 8-)
That's definately a youngin talking! ;D
When I was 23, I knew no aches or pains ... at 47 they come and go mysteriously.
Getting that low to the ground is something that I wouldn't want to do and didn't. Crawling into a tub and then back out again is something I really wouldn't want to do now.
But to each his or her own!
Post by: Chad on February 27, 2007, 07:20:13 pm
24  :)
Post by: Zep on February 27, 2007, 10:17:17 pm
I know it's a personal decision....
And I am certainly not going to win many over
when I bet 98% of all acrylic tubs are above ground.
(because it's cheaper, easier to deal with, and typical)
I am 48 and don't consider myself "old" but with that said.....
An an in-ground if done correctly can actually be less
trouble-some to get in and out of for an older person.
For example my brother's in-ground in Colorado
shown below is easier to get in and out of than my above ground.
(http://i7.photobucket.com/albums/y273/ItsZep/Hot%20Tub/100_0198.jpg)
An in-ground isn't necessarily harder to get in and out of
in fact it can be easier.
After all....the closer the tub is to ground....the less distance there is to fall.
Old people get in and out pools which are no lower than in-grounds spas.
Some spas have steps in them just like pools.
Again....2EachHisOwn!
Post by: hotubinn on February 27, 2007, 11:43:39 pm
Hope you guys are lining your pockets with gold!  That would cost a fortune to repair :)
Post by: Chad on February 27, 2007, 11:53:48 pm
What do you mean?
Post by: hotubinn on February 28, 2007, 12:21:49 am
What do you mean?
Tough access, increases time involved on repair...helps put my kids through college!
Post by: Chad on February 28, 2007, 06:36:36 am
Oh...... I can see that being the case in some applications if one builds something and doesn't plan ahead. I hope you're not implying that I don't. Whenever I do get a new tub and move into a house that will allow me to do something like this, you can gaurantee that I'll make sure it's just as accessible as a typical installation. Plus your kids college tuition is paid by my dealer not me, I have a 5, 7, 10 warranty, with no trip fees. :) Nice try though.
Post by: hotubinn on February 28, 2007, 09:06:45 am
5 years is a short time, thats about the point you start having trouble!  You don't think the manufacturer would actually set up the warranty during a period filled with problems would you?  Lots of warranties have exlusions and loopholes.  No companies that I do work for, pay me to disassemble a deck, gazebo etc...  Someone has to prepare the access...if it is the service guy, you should be paying for his time.
Not to single you out, or imply anything as to how you would build it, but from my seat, sure it looks nice, but nothing good can come out of an install like this.  I have dealt with a number of situations recently that required removing the tub from the hole completely to repair.  One gentleman said forget it, and went out and bought a Bullfrog to try to avoid having to tear it out again for a leak ( interesting tub, hope it works out for him).  Leaks can and DO happen everyday.  It is tough to install a spa in a hole without having supports for decking around it that still leave room to remove the panels, if the panels can be removed.
I have seen many in ground type installations that look awesome, but none I would recommend to family or friends. "IMHO"
Post by: Zep on February 28, 2007, 09:24:15 am
re: Hope you guys are lining your pockets with gold!
"pockets of gold"?.....LOL.
If an in-ground is done properly it is not normally
going to be a problem servicing it.
My brother has had his in-ground Sundance for ten years in
a very, very cold...almost extreme environment and has never
had any problem with repairs or servicing access.
You just design the hole correctly and it's not
going to be a big deal servicing it.
Hey, but like I said it's not for everybody....like most
unique special things in life they can possibly be at
times higher maintenance....beautiful women are
many times "higher maitenance" but that doesn't
mean I am gonna go chase ugly ones!....LOL
Post by: drewstar on February 28, 2007, 09:24:21 am
Access isn't just for warrenty work and tubs several years out from purchase.  I've had to hit my tiger river reset switch on the pump a few times, I can't imagine that pain in the butt it would be on some of thew above installs.   Or change the lightbulb, or clean the 03 lines.   I like some of the inground installs, but they must have access to the equipment area.
Post by: Zep on February 28, 2007, 09:38:06 am
hey drewstar.....
you know alot more about this stuff than I do....
but why would an in-ground spa like the one shown below
if it had access pull-out panels on all four sides
be so "unbelievably difficult" to access or service?
(http://i7.photobucket.com/albums/y273/ItsZep/Hot%20Tub/RothSpaVault.jpg)
Post by: tony on February 28, 2007, 09:43:25 am
Many inground spas have remote pumps.  A portable spa sunk in the ground would need direct access to the equipment area and some kind of access to the other sides.
Post by: Spatech_tuo on February 28, 2007, 10:55:07 am
hey drewstar.....
That is different from the other pictures,
a) They didn't sink it all the way in so it'll be easier to enter/exit (though I'd have had it another half foot higher).
b) They designed accessibility around the spa.
That is well done.
Post by: drewstar on February 28, 2007, 11:00:27 am
hey drewstar.....
Zep, I doubt I know more than you, but thanks.   ;)
That spa is set up for access. however, the ones in your original set of pics you posted,  I didn't see any that allowed for access, no?
Post by: Zep on February 28, 2007, 12:20:33 pm
Guys....I am not sure how the first set of pics allow for
access, but I presume there is access.....unless the people
are idiots....no?
Like a great toupee...you don't know it's there.....
a great in-ground hides the access so well
you don't notice it.
If the access is screaming out at ya.."here I am".
then IMO....thats a poorly designed in-ground.
As far as the second picture, I actually would sink it down
further where it is almost flush.....if you have full access on
all four sides why only go half way?
I suppose some ingrounds with the step/lip look pretty cool
and have some functional purpose for seating.
I just don't see a problem with in-grounds if it is done
correctly with removable panels on all four sides.
Of course I realize 99% of tubs are going to be above
ground....but in my mind there is just no comparison
as far as looks and elegance.
(http://www.poolwarehouse.com/graphics/inground-spa.jpg)
Post by: Zep on February 28, 2007, 12:49:09 pm
WhyNot....
I am more of a fan of the flush in-ground, but here are some
additional pics of semi-in-grounds that look pretty cool:
(http://www.creativespas.com/images/+grand_canyon.jpg)
(http://www.creativespas.com/images/+anthem.jpg)
(http://www.creativespas.com/images/+riogrande.jpg)
Post by: dunerunner25 on February 28, 2007, 06:33:17 pm
Nice pics!
Post by: hotubinn on March 01, 2007, 12:34:48 am
Nice pics!
I agree, those are nice pics.  However, none of them look easily accessible, even the one with wood around the four sides.  There still needs to be wood supports that run right next to the cabinet in order to hold up the wood.  This makes access tough.  Now, most of the time you will only need access to the equipment panel.  Sometimes pumps are mounted on the side panels and heaven forbid you ever have a leak.  To each his own, I have just dealt with these problems too many times for me to ever reccomend this style of install.
Post by: Dr. Spa™ Ret. on March 01, 2007, 12:44:40 am
I've always been more inclined to go with what you're calling "semi-in-grounds". The full ingrounds are difficult to get into and out of. You pretty much have to first sit on the deck and swing your legs into the spa...... Or, from standing, take a "blind" step into the spa with nothing to hold onto.
With the semi-in-grounds, you walk up, sit on the edge of the deck and swing your legs over. Or, if really done right, the lower part of the deck is exactly the same height at the entrance step/seat and from a standing position you swing your leg over the side and your standing on something that's in the same plane as the deck. Either way, there's still the edge of the spa to hold onto...
(I was going to say, the last thing I want is for some drunken girl I bring home from the bar and convince to get nekid with me in my spa to do is slip and crack open her head, before we even get wet..... But then I thought some here might think it uncool and not find that comment as funny as I did when I thought it up)
And, the first pic Zep posted looks like all 4 wood deck panels left out for access. The semi-in-grounds may, or should, be constructed that same.
