Original => Hot Tub Forum => Topic started by: usnrret on January 27, 2007, 10:33:37 am
Title: Alkalinity
Post by: usnrret on January 27, 2007, 10:33:37 am
My taylor test kit says my alkalinity should be between 80 and 120 but my Hot Spring owners manual says keep it between 125 and 150.  Which is right?
Title: Re: Alkalinity
Post by: windsurfdog on January 27, 2007, 12:08:54 pm
I would believe the Taylor over the HS...BUT...if your TA falls in range of either, I wouldn't worry about it...concentrate on pH over TA.
Post by: hottub.pool_boy on January 27, 2007, 04:55:47 pm
HS is right. 125-150 tends to buffer ph better in hot water.
Post by: Chad on January 27, 2007, 08:20:21 pm
Not in my water. ;)
Post by: tony on January 28, 2007, 10:34:14 am
If I keep my TA at 100 or above, my pH will consistantly rise.  My water works best when TA is at 80 which is how it comes from the tap.  At that level, my pH falls slightly and needs adjusting maybe once per month.
