Original => Hot Tub Forum => Topic started by: Zep on December 14, 2006, 08:54:43 am
Anybody ever used one of these?
(http://www.theinternetspastore.com/IMAGES/PORTABLE%20VACUUM%20SYSTEM.jpg)
Advantage Portable Vacuum System
Protect the Main Filter from excessive dirt and debris with our Portable Vacuum System.These systems are ideal for pools, fountains, ponds, etc. with a large amount of debris. Dirty water goes into the portable vacuum's filter cartridge and clean water goes directly back into the source. May be used as an auxiliary pump filtration system when the existing pump-filter is non operational. Perfect for winterizing and draining of pools and spas. Hitch accessory for easy on/off mounting to service vehicle is available. Features include: 1.5 HP pump w/6" trap, rugged .090 wall steel construction, powder coated finish, 150 Sq. Ft. cartridge filter, 50' 12-gauge insulated cord, heavy duty tubed tires and on/off switch with GFI
Portable Vacuum System Features
1.5 HP Pump w/6" Trap
150 Sq. Foot Cartridge Filter
50' of 12 Guage Insulated Cord
On/Off Switch with GFI
Heavy Duty Tubed Tires
Rugged .090 Wall Steel Construction
Power Coated Finish
Complete Assembly with Fittings. 6 Position Valve interchanges with
leading brands Koi Pond Package with Hi/Low switch, 2 Speed Motor
and 1.5 HP/150 lb Tank
No, but I just love how you include a picture with your posts!! I always read them just to see what you have found. :) :)
thanks kervis!
(http://i7.photobucket.com/albums/y273/ItsZep/Hot%20Tub/f456683c09571219f868192ac94c7891.jpg)
