Original => Hot Tub Forum => Topic started by: CapMorgan on May 29, 2006, 03:53:22 pm
Hello all,
I’ve had my hot tub almost 3 months now im still using the first fill of water. My water is clear but for the last month my PH is been on the low side 7.2 I like to keep it between 7.4 and 7.6 so every week when I test my water I find my PH on the low side so I have been adding Pro Team PH up. Every week I have been adding Ph up to keep PH up but now my TA has been rising it is now at 140 how can I keep my PH at 7.5 with out my TA rising I like to keep my TA at 125.
CapMorgan
I've had the same problem recently with both my pH and TA being low. Whenever it happens I add plain ole baking soda. In my case 2-3 tablespoons for 450 gallons. I run the jets for 20-25 minutes and then check the following day. After a day I'm back within normal range.
Acceptable water parameters are usually given as a range. Trying to hit specific readings can only complicate things needlessly. All your numbers sound fine. Don't worry, be happy.
I agree wmccall! I don't try to get "exact" readings. If I'm in the range, I'm happy!
cappykat the plain ole baking soda you are using you mean like arm & hammer baking soda?
Also im just fighting low ph not low ph and ta by using ph up my ta has been rising when i started my ta was at 80 now it is at 140 while my ph is still on the low side.
1.) When just using baking soda does that just raise the ph or does it raise both ph and ta?
2.) What can i use to lower just TA?
Thanks CapMorgan
Yep, plain ole baking soda in the yellow box...LOL! It raises both but more the pH. Someone on this board told me about the baking soda...maybe Vinny??
I'm not sure about lowering the TA. You can use plain ole vinegar to lower the pH. I'm not sure about the amount. Those in the know, please respond.
Unfortunately whenever you try to lower either PH ar alkalinity both go down. The one thing I've read is to add an acid (PH down, muriatic acid (real nasty stuff) or even vinegar) in one spot without any circulation and it effects the alkalinity more than PH. I've never tried it but it might work.
My suggestion is to not worry about alk too much. It's only function is to lock in the PH so it doesn't bounce. If you have a Taylor kit and see what readings give you balanced water ... there are an aweful lot of "perfect" readings that can be had!
To get PH up get soda ash (I believe), there is something in the stores that'll raise only PH ... if it was a pool I'd suggest Borax but I don't know what effect (if any) it will have on your tub .. although I did use it once in a pinch ...
AND for baking soda, the heck with Arm and Hammer, buy generic ... I buy the store brand and get 2 lbs for $0.79 and it treats a lot of water ... both spa and pool.
Balancing water is more like hand gernades and horseshoes......and gov't work...... 8)
Vinny!
Do you know if I can effectively use the "Taylor Test Kit" even though I use...........................Baqua? :o
AP
Vinny!
AP
NO! you can't ... But apparently Taylor makes a Baqua kit! :D Maybe e-mail Doc for availability.
