Original => Hot Tub Forum => Topic started by: jgirvine on May 27, 2006, 02:25:43 pm
Title: Question for D1 owner or retailer
Post by: jgirvine on May 27, 2006, 02:25:43 pm
We purchased a D1 Triad II used.  There is no D1 dealer around us.
We are getting an error message that says clean filters and check water level or call for service.  The owners book says if cleaning the filters and adding water (it is at the middle of the tile) to turn off the power and let it reset.  We have tried all of this repeatedly.   Nothing is getting rid of the error message.
Any suggestions out there?
Title: Re: Question for D1 owner or retailer
Post by: dadofrad on May 27, 2006, 02:50:50 pm
fill free to contact me  at sales@midnightsunspas.com and i will help you out
Post by: Chas on May 27, 2006, 03:23:43 pm
You said you added water, you said you reset the spa. Have you cleaned the filters? It's where I would have started.
Post by: jgirvine on May 27, 2006, 03:25:39 pm
I cleaned the filters several times and when that didn't work, I even tried putting in new filters.  No luck.
Post by: Micah on May 27, 2006, 03:46:48 pm
Have you tried taking the filters out and then reseting it.  I have had the same problem with a customer.  It ended up being a bad circ pump
Post by: jgirvine on May 27, 2006, 03:48:48 pm
Yes, tried that, a couple of times.
Post by: kufferaths on May 27, 2006, 04:52:08 pm
Did you push and the D1 icon for three or four seconds?
Post by: kufferaths on May 27, 2006, 04:53:15 pm
I meant push and hold Icon for three or four seconds.
Post by: jgirvine on May 27, 2006, 04:55:05 pm
yes, did that for 5 seconds to put it in standby mode.  Did not help, but thanks for the ideas, keep them coming...somethings gotta work.
Post by: Micah on May 27, 2006, 05:22:35 pm
Sounds like either the circ pump or the flow switch
Post by: jgirvine on May 27, 2006, 06:22:01 pm
But if it was the circ pump or the flow switch, would it be heating?
Post by: Micah on May 27, 2006, 06:36:34 pm
Had a customer 6 months ago that the water was hot. but the circ pump was starting to spin at a slower speed. The flow switch registered that there was not enough flow and put up the clean filter icon.  We replaced the flow swich and the circuit board. It wasnt till we replaced the circ pump that everything worked correctly
Post by: wetone on May 28, 2006, 01:44:34 pm
when you take the filters out, look down into the housing were the filters go in,  you'll see a 6" long black cone in each housing. the filter housing on the circ pump side has a very fine stainless steel mesh strainer inside the cone and they can get plugged up. Your owners manual should have directions on how to take them out, if not PM me.
John
