Original => Hot Tub Forum => Topic started by: Anoroc on April 25, 2006, 08:51:54 am
Title: Jet Pressure Majesta Vs Vanguard
Post by: Anoroc on April 25, 2006, 08:51:54 am
I am just curious for those who have wet tested both of these can you comment on jet pressure of these two hot tubs.
I believe the Majesta has a captains chair that is supposed to be very strong and I think the Hp is 2.5 continuous on both pumps.  The Vanguard has two pumps at 1.65 continuous Hp.
I am not buying a sundance but since these two spa probably compete against each other I was curious about the jet pressures in the seat given the difference in HP.
Title: Re: Jet Pressure Majesta Vs Vanguard
Post by: hymbaw on April 25, 2006, 11:29:38 am
I am a Sundance dealer, however,  I used to sell HotSpring and think highly of their tubs. That being said, the jet pressure in a Sundance FAR exceeds that of a HotSpring IMHO. That is across the line not just when comparing these particular models. Again, just my opinion.
Post by: shabba34 on April 25, 2006, 11:33:31 am
I would have to agree with Hymbaw 3-4 years ago when HS had no HP spas in there line.  This is not the case anymore with the Envoy, Vista, and Grandee performing as well as many high powered spas in the industry. ;)
Post by: tanstaafl2 on April 25, 2006, 12:35:03 pm
Haven't been a dealer for either (primarily because I am not a dealer!) but did wet test both HS (envoy, vanguard but not the grandee which I think was the one I would have been most interested in) and Sundance (optima, majesta) recently before buying a spa.
I found the Sundance to have superior pressure overall and while the HS could get decent pressure in a particular spot it usually was at a sacrifice to other seats. The Sundance tended to have better pressure in more seats at the same time.
Of course my own spa was better than both at providing good pressure in all seats at the same time!
And cost about the same...
Post by: salesdvl on April 25, 2006, 12:36:55 pm
I don't know that I would say that adding 1/2 a hp to the 2 jet pumps and re-labeling them as "High Performance" puts them up there with  3, 4 or 5 jet pump spas, but that has never been their focus.  Their empire was not built based on "We have more firepower than anyone else."  And that's OK.
Post by: shabba34 on April 25, 2006, 12:50:02 pm
More like adding 1 1/2 hp to each pump.  And I do agree that there goal is not firepower.  They also don't require 3,4,and 5 pumps do to the limited # of jets in the spa.  Notice I say # and not variety.
By me saying High Performance is claiming what the MFG labels the spa vs. there EE energy efficient units.  Not like I'm sayng they are "Super High Performance". ;)
Post by: salesdvl on April 25, 2006, 01:15:19 pm
Jet Pump 1 Wavemaster® 9000; One Speed, 2.5 HP Continuous Duty,
4.8 HP Breakdown Torque
Jet Pump 2 Wavemaster® 8000; One Speed, 2.0 HP Continuous Duty,
3.9 HP Breakdown Torque
Adding 1 1/2 hp would mean that the Grandee was a 1hp & a 1/2hp.  But I get the point.
and I prefer the "Super Dee Duper" High Performance.  :o   ;D
Post by: shabba34 on April 25, 2006, 01:23:24 pm
Ok...1.4 BTHP on one and .4 BTHP on the other.  Where both right. ;D ;D ;D
Post by: J._McD on April 25, 2006, 01:45:27 pm
I did not realize they were so underpowered before, but didn't we already have this discussion in another thread where only ¼ or ½ the spa can operate at performance levels?
IF you are not saying they are HP (high performance) is it that you only mean to imply it? ???
Post by: Anoroc on April 25, 2006, 01:49:25 pm
When did the HP increase.  Is that new for 2006?
Post by: shabba34 on April 25, 2006, 01:53:00 pm
Calling the spa as it is labled from Watkins.  HP or EE.  And the comment I made regarding the HS spa performing now much better in a wet test then they used to is correct.  J_Mcd, when was the last time you wet tested an Envoy or a Vista?  I know I was in the Optima and the Maxxus not but a month ago.  All 4 spas perform well, I just don't tout mine as having a Superior feel to the rest. ;)
Post by: J._McD on April 25, 2006, 02:12:27 pm
I argree with your statement in general, most all spas perform well, and that is why people should wet test them.  However, I made no claims of superiority or performance, although I do believe the SD accupressure seat out performs anything that HS has, and that is left only to the interpretation of the end user.  He is the one that finds the superior spa.  And, that could be the brand you sell or any other of the brands mentioned here.
Post by: Spatech_tuo on April 25, 2006, 02:26:24 pm
I argree with your statement in general, most all spas perform well, and that is why people should wet test them.  However, I made no claims of superiority or performance...
Ya know, if my Dad was still around he'd round up about 8 of you guys and give you all boxing gloves and say "I'm tired of hearing this bickering, go at it and get this over with so I can get some peace" (true story in my family by the way). ;) ;D
Post by: East_TX_Spa on April 25, 2006, 02:36:51 pm
Boxing gloves hell, let them go full contact!
(http://i20.photobucket.com/albums/b206/EastTexasSpa/9010f824.jpg)
(http://i20.photobucket.com/albums/b206/EastTexasSpa/1759079e.jpg)
Terminator
