Original => Hot Tub Forum => Topic started by: tanstaafl2 on March 21, 2006, 12:36:29 pm
Title: Baking Soda vs Soda Ash
Post by: tanstaafl2 on March 21, 2006, 12:36:29 pm
Keep reading in various places differing opinions about Sodium Bicarb (baking soda) and Sodium Carbonate (soda ash).
Some places say don't use baking soda, use only soda ash. Others seem to have no problem with Bicarb.
Is there a big difference in terms of use in a spa?
Title: Re: Baking Soda vs Soda Ash
Post by: orlandoguy on March 21, 2006, 01:46:16 pm
My pool supply store says yes, there is a big difference and he probably makes more money saying that. But baking soda works fine for me.  Either way, both are cheap.  Baking soda much more so.
Post by: Brewman on March 21, 2006, 02:18:09 pm
Most of the alk increase products I've looked at contain 100% sodium bicarbonate.  Baking soda.
That include the ones packaged and sold at pool and spa dealers, the bigger cheaper containers sold in the pool section of the big boxes.
Post by: HotTubMan on March 21, 2006, 02:26:40 pm
Bicarbonate will raise TA more than pH.
Ash will raise pH more than it will TA.
So, if you have low TA and good pH, use bicarbonate.
If you have low pH and good TA, use ash.
Post by: Tatooed_Lady on March 21, 2006, 02:29:46 pm
I'm gonna start taking notes....
Post by: luvin_tubin_sqezin on March 21, 2006, 02:34:55 pm
I swear, I've already started printing out some of these posts for future reference....and I don't even have my tub yet!!!!
Post by: tony on March 21, 2006, 03:49:05 pm
And if you have low TA and low pH, use bicarbonate.
FWIW, I have only used baking soda.
Post by: tanstaafl2 on March 21, 2006, 03:49:15 pm
Excellent. Very helpful to know. Probably should have used soda ash then as TA was OK towards higher range and I was most interested in raising the pH.
Live and Learn!
Post by: HotTubMan on March 21, 2006, 03:55:28 pm
Good point and most will if they follow this rule:
Always adjust TA then pH.
Post by: Tman122 on March 21, 2006, 05:19:49 pm
I exclusivly use baking soda. Water comes from the tap 60-70 TA and 7.0 PH (acid rain in Minnesota I spose) Baking soda does exactly what I need it to do to both.
Post by: hottubdan on March 21, 2006, 08:30:39 pm
There will be a test tomorrow.  Bring your number 2 pencil. ::)
Post by: Dr. Spa™ Ret. on March 21, 2006, 08:45:56 pm
Sodium bicarbonate (sodium bicarb, bicarb or baking soda) has a pH of 8.3 and contributes bicarbonate to total alkalinity. Because the spa water pH is close to the pH of the bicarb, it will have a greater effect on TA than pH. So if you want to raise just the alkalinity with a small rise in pH, use bicarb. 1 lb of bicarb added to 10,000 gallons of water will increase TA by 7.15 ppm and increase pH by about .1 to .2 unit.
Sodium carbonate (soda ash) has a pH of 13.0 and contributes carbonate to total alkalinity. Because it has a high pH, soda ash will raise both pH and total alkalinity. 1 lb of soda ash added to 10,000 gallons of water will increase TA by 11.33 ppm and will increase the pH by about 1.0 unit.
Post by: Tatooed_Lady on March 21, 2006, 09:25:26 pm
*LOL* I'd fail......miserably.....but then, so long as I keep track of how much of what does what to what (in writing, no less), I should be ok.....  :o
My husband is gonna kill me when he finds that post-it note on his forehead.......
Post by: tanstaafl2 on March 22, 2006, 12:14:47 am
So how do I raise pH and hopefully have the least affect on TA if both Bicarb and Soda Ash raise TA. I guess to get the most bang for pH compared to TA I should have used Soda Ash instead of the Bicarb as was suggested earlier.
Live and Learn I suppose. Doesn't seem I did too much harm with Bicarb so far. Not sure pH is raised that much but TA still seems to be OK albeit on the high side at 120ish.
Post by: Snowbird on March 22, 2006, 06:51:33 am
Try this thread.
http://www.whatsthebest-hottub.com/cgi-bin/yabb/YaBB.pl?board=wtb-hottub;action=display;num=1140625398;start=10
Post by: Brewman on March 22, 2006, 08:40:56 am
If you put a lot of Baking Soda in your spa, remember not to put any vinegar in there.  If you want to see why, take a small glass and mix the two.  Then imagining that happening in your spa.   ;)
Post by: tanstaafl2 on March 22, 2006, 10:01:04 am
Ah yes, Mr Wizard strikes again. Been there, done that!   ;D
Post by: tanstaafl2 on March 22, 2006, 10:09:39 am
Try this thread.
Thanks, another interesting thread. I guess my biggest problem is I don't have a lot of confidence in the test strips. Hard to say exactly where the colors I get fall on the scale.
Wish I had a machine that I could pour a little water end and get a precise readout of the various characteristics. Not likely to happen though.
Post by: tony on March 22, 2006, 04:17:08 pm
Taylor Test Kit.
Post by: tanstaafl2 on March 22, 2006, 10:50:52 pm
Tested my tap water as well as the tub today just out of curiosity.
pH seems to be about the same at around 6.8-7.0 at best for both despite my use of 1 TBS of baking soda yesterday morning. The TA was very low for the tap water but about 120 for the tub which seems to be about where it was before the baking soda, maybe just slightly darker than before.
No chlorine reading in either after using a single tsp of dichlor last night. And the CA still seems to be reading low in both (The strip calls this one "stabilizer" and I am just guessing it measures CA.
Probably try to refrain from messing with it for a few days while the service tech comes out to evaluate the error message I keep getting for "power board communication".  Dealer suspects the secondary control pad on the opposite side of the tub.
Hasn't seemed to affect spa function so far but disconcerting none the less.
