Original => Hot Tub Forum => Topic started by: wmccall on March 19, 2006, 10:40:11 pm
Title: Question for Spatech(s)
Post by: wmccall on March 19, 2006, 10:40:11 pm
Or anyone else that has experience for that matter.  My tub needed a little shock tonight so I dumped in big dose of dichlor.  Frequently when I do this I think about the waterfalls.  There are two of them, they came with the tub, I wouldn't have special ordered them. I rarely use them, but can't say never.   When shocking I wondered if I should occasionally run the waterfalls so that they get cleaned out.  For those of you who have looked, does algea, mold, or other nasties grow up inside little used waterfalls on otherwise well maintained tubs?  I figured you would be the ones who would know.
Title: Re: Question for Spatech(s)
Post by: Chuck_55 on March 19, 2006, 10:58:54 pm
What kind of Spa ?
Does it have plurge cycle that runs 1 minute or 3 to clear all plumbing & blow out the system? If one of the top ten would think, Most likely.
good evening to ya
Chuck 55 ;)
Post by: Chas on March 20, 2006, 12:04:52 am
It is generally a good idea to run chorinated water through all systems, especially systems which aren't used all the time.
Post by: hottubdan on March 20, 2006, 12:04:53 am
Running the waterfall occassionally makes sense.
Post by: ssbraun on March 20, 2006, 12:18:53 am
I follow advice I got from others on this board;  I leave diverter valves in the mid position so all lines get flushed during filter cycles; I also leave the waterfalls "trickling" for the reason you cite...preventing potential growth of unpleasant things.
Post by: Spatech_tuo on March 20, 2006, 01:01:19 am
There's the answer.
Post by: Brewman on March 20, 2006, 08:28:42 am
Makes sense to me to be sure that all plumbing gets regular water circulation.
Our Optima has what I think is called a "blowout" function, where each day at noon all pumps activate for several minutes to make sure that stale water is pushed out of the pipes.  And we got the same advice in our owners manual- leave all valves in the middle when spa isn't in use.
I've also learned thru experience to be sure to use things every so often, just to keep em running.  Especially mechanical items like cars, spas, anything mechanical.  Seals and valves can get defective if they are left alone too long.
Water shutoff's are notorious for going bad if they aren't used occasionally.  In our first house the water main wouldn't totally stop water, it trickled thru the valve because I hardly every used the valve.
