General => General info Somewhat hot tub related => Topic started by: wmccall on February 03, 2007, 07:31:27 pm
Posted with Vista?
Posted with Vista?
Huh?
Huh?
(http://images.windowsmarketplace.com/img/edt/Marketplace2.0/modules/vista/32bit/boxshots/upg_HomePremium.jpg)
Posted with Vista?
How do you like it thus far?
Sorry....question mark threw me off...thought you were asking, not telling :-[
Couple of neat features. I bought a new computer with it rather than upgrade. It took me forever to get it on my network and for it to see my other computers and my printer, but it turned out that wasn't Vista's fault, it was the stupid pre installed Norton Internet Security program.
Buying it was a pain, the stupid little geek selling it was a pain, I just wanted to buy it and go. Finally had to tell the little 5h1t that I have been working on computers when his dad was still in Diapers. ;)
Think I'll go back to Mac.
8-)
The only way I'd take a new OS would be to buy a new computer. I've heard too many horror stories of people trying to install a new OS on their existing machine.
I'm not even sure this PC I have has the nads to run Vista.
Hopefully by the time I get a new PC most of the bugs will be worked out of Vista.
You are very wise Brewman. People as me when they should upgrade to Vista. I tell them when they get a new PC. And when Vista SP1 comes out...
Probably good advice. Upgrades can frequently be a little dicey. I was not prepared to risk my main PC that I use for my business. Since my daughter left, I've had a empty computer desk, so I put the new PC there so my wife can use it while I'm working on mine. I always have the top end PC in the house, so she thinks she does :D I wasn't going to rush in but I have customers buying it now, so I've got to familiarize myself with it.
From Windows 3.1 through XP, when you upgrade you carry forward many problems developed over time that the upgrade keeps to remain backward compatible. That does add some vulnerability (XP did not have a registry entry called RUN SERVICES - that many viruses look for, but if you did an upgrade from ME, 2000, or 98, that key was migrated up.) There are some problems that at an expensive per hour charge, its not worth troubleshooting to a customer, just back up the data, and start over.
Working in the IT industry as I do, I find it rather ironic that my personal PC needs are as modest as they are. Right now I'm sailing along just fine on a 4 year old Dell, with a 2.4GHz P-4, 512MB RDRAM, and a 120G hard drive. Most of my home PC use involves the internet and email, and some very minor Word and Excel use.
I did take XP's service pack 2 upgrade, and had no trouble. But I'm pretty sure that Vista wouldn't run on my PC with it's relatively small RAM.
I did see some pcs for sale with Vista and 512mb of RAM at Best Buy. Mine came with 1gb, I will probably eventually add another 1gb.
I see in my specs,that I have 64 bit. Should I run Vista 64 bit,verses 32 bit? And Bill,do you have 2 open slots for mem? If not,it will cost ya a few bucks as you will have to scrap what you have now,to upgraDe to 2 gigs.
SystemInfo version 3.12
Stylesheet version 3.10
CPU Info
Physical Processors 1
Logical Processors 2
CPU 1/1
Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
Manufacturer Intel
Family Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
Architecture 64-bit
Internal Clock 2.7 GHz
Internal Clock Maximum 2.7 GHz
External Clock 266.0 MHz
Socket Designation Socket 775
Upgrade ZIF Socket
MultiCore 2 Processor Cores
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, SSE, SSE2, SSE3, PAE, NX
Version Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
Caches
Level 1 32 KB
Level 2 4 MB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.2180
Primary Device NVIDIA GeForce 8800 GTX
Linked Display Adapters false
Display Device 1/1
NVIDIA GeForce 8800 GTX Driver 6.14.10.9792
Description NVIDIA GeForce 8800 GTX
Manufacturer NVIDIA
Total Local Video Memory 768 MB
Total Local Texture Memory 1009 MB
AGP Aperture Size 0 B
Driver File nv4_disp.dll
Driver Version 6.14.10.9792
Driver Date 12-21-2006
Driver WHQL Certified true
Max Texture Width 8192 px
Max Texture Height 8192 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3.0
Pixel Shader Version 3.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 337.5 MHz
VGA Core Clock 108.0 MHz
Max VGA Memory Clock 0.0 Hz
Max VGA Core Clock 0.0 Hz
PCI
Name NVIDIA GeForce 8800 GTX
Vendor ID 0x10de
Device ID 0x0191
SubSystem ID 0x039c10de
Revision ID 0x00a2
Memory Array 1/1
Max Module Capacity 2 MB
Location System Board
Use System
Supported Speeds -
Supported Types -
Supported Voltages -
Memory Slot 1/4
Installed Enabled Size 1.00 GB
Form Factor DIMM
Frequency 800.0 MHz
Slot A0 [Bank0/1]
Manufacturer None
Type DRAM
Type Details -
Total Bit Width 128 b
Data Bit Width 128 b
Memory Slot 2/4
Form Factor DIMM
Frequency 800.0 MHz
Slot A1 [Bank2/3]
Manufacturer None
Type DRAM
Type Details -
Memory Slot 3/4
Form Factor DIMM
Frequency 800.0 MHz
Slot A2 [Bank4/5]
Manufacturer None
Type DRAM
Type Details -
Memory Slot 4/4
Form Factor DIMM
Frequency 800.0 MHz
Slot A3 [Bank6/7]
Manufacturer None
Type DRAM
Type Details -
Motherboard Info
Supported Slot Types ISA, PCI
Manufacturer NVIDIA
Model NFORCE 680i SLI
Version 2
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Release Date 01/12/2007
BIOS Properties Plug and Play, Flash
Name Microsoft Windows XP
Version 5.1.2600
PlatformId 2
Service Pack Service Pack 2 (v2.0)
Suite 768
Product Type 1
Media Center false
Windows Environment 32-bit
Locale US
Desktop Width 1280 px
Desktop Height 1024 px
Desktop BPP 32 b
Internet Explorer Version 62900.2180
<______"3DMark06".exe 3092 16 MB______>
Storage Device 1/6
WDC WD1500AHFD-00RAR1
Device Drive Type Hard Disk
Name WDC WD1500AHFD-00RAR1
Manufacturer (Standard disk drives)
Model WDC WD1500AHFD-00RAR1
Vendor ID String WDC WD15
Product ID String WDC WD1500AHFD-00RAR1
Product Revision String 20.07P20
Storage Device 6/6
ASUS DRW-1608P3S
Device Drive Type DVD
Name ASUS DRW-1608P3S
Manufacturer (Standard CD-ROM drives)
Model ASUS DRW-1608P3S
Vendor ID String ASUS
Product ID String ASUS DRW-1608P3S
Product Revision String 1.24
Monitor Info
Monitor 1/1
Name BenQ FP241W (Digital)
Manufacturer BenQ
Max Width 1920 px
Max Height 1200 px
Stick with the 32 bit if your going to purchase now. Someday hopefully the 64 bit will be beneficial but that day isn't today.
CPU Info
CPU 1/1
Manufacturer Intel
Architecture 64-bit
Upgrade ZIF Socket
Caches
Level 1 32 KB
Level 2 4 MB
DirectX Info
Version 9.0c
DirectDraw
Display Device 1/1
Manufacturer NVIDIA
PCI
Vendor ID 0x10de
Device ID 0x0191
Revision ID 0x00a2
Memory Array 1/1
Use System
Supported Speeds -
Supported Types -
Memory Slot 1/4
Form Factor DIMM
Frequency 800.0 MHz
Slot A0 [Bank0/1]
Manufacturer None
Type DRAM
Type Details -
Memory Slot 2/4
Form Factor DIMM
Frequency 800.0 MHz
Slot A1 [Bank2/3]
Manufacturer None
Type DRAM
Type Details -
Memory Slot 3/4
Form Factor DIMM
Frequency 800.0 MHz
Slot A2 [Bank4/5]
Manufacturer None
Type DRAM
Type Details -
Memory Slot 4/4
Form Factor DIMM
Frequency 800.0 MHz
Slot A3 [Bank6/7]
Manufacturer None
Type DRAM
Type Details -
Motherboard Info
Manufacturer NVIDIA
Version 2
Version 5.1.2600
PlatformId 2
Suite 768
Product Type 1
Media Center false
Locale US
Desktop BPP 32 b
Storage Device 1/6
Storage Device 6/6
ASUS DRW-1608P3S
Monitor Info
Monitor 1/1
Manufacturer BenQ
Max Width 1920 px
Max Height 1200 px
Bill,
I'm suprised with all your geek abilities you didn't slap a new PC together for yourself.
So far I am loving my new OS.
Bill,
It frequently doesn't pay anymore, hardward prices are at minimal markups these days.
Your right. You can go to Dell or any B & M and get some good deals. I still enjoy doing my own builds mostly so I can hand pick all the parts and pick out a cool case. Newegg and zipzoomfly are a couple of my favorite sites to get parts from.
