Original => Hot Tub Forum => Topic started by: mothergoose45 on February 21, 2006, 02:34:31 pm
I read on forums that Cal spa is bad, but does anyone like their cal spa? Has anyone had good luck with them? Im asking b/c I can but a 2001 96x96 Cal Spa used for $2000. It only has 25 jets but thats fine with me for starting out. It is owned by an older couple and has always been kept inside in a sunroom(whic is a plus). It looks brand new. I dont want to spend 6000+ for a spa. Would you guys think I can go wrong with this spa? Also does Cal Spa transfer their spa to a second owner? This is a large spa that has been very well taken care of.
Should I go for it? Thanks for the help.
some have had good luck with cal....others have not. if you want, you can search them in the site and see whats been said.
is the spa running now? if not, ask if you could see it running, maybe even talk your way into testing it out. i would highly recommend it. might seem trivial, but you wont know what you are getting into w/o seeing it opporate.
as far as the warrenty goes, no they do not transfer to a 2nd owner.
if the spa is in good working condition...it could very well be a good "starter" for you.
Thanks so cal. The spa was working fine when i went to look at it. Both pumps operated as well as all of the controls. It is full so I guess that means there isn't any leaks. I am going back tomm. to look inside the unit and give him a deposit if everyhting looks well. The way I look at it is, as long as its a decent spa I dont think I can go wrong for $2000, even if a pump goes out along the way. Also it has a light that says "Ozone" on it. What does that mean? What do I need to look for when I go back tomm for the last look? Thanks for the help.
Don't know what it costs to move a spa but you have to figure that into your cost. If it is still in good shape might still be good deal but will certainly add something to the cost as most dealers will likely deliver a new spa.
i would play with the controls. turn the pumps on. see how quiet it is. ask about their electric bill. after 5+ years it would be difficult to know the cost of running it but it could give you a little insight.
i would open the equipment panel, take a peek inside. since it was in a sun room, critters are probably not an issue...but it would hurt to look. also, you will see if it is fully foamed or not. depending where you are located and where the tub will be placed, full foam will help insulate the tub.
ozone helps maintain water chemistry. now a days, just about every spa has it standard or packaged in ( last year Marquis had it as an opition with their constantclean system). the light indicates that the unit was in a cycle. being 5+ years old, it might be near time to replace it.
also, see if they will throw in the disconnect. will save $100 if you went to lowes/home depot....more if the electrician gets it for you.
a few people have gotten a used spa in here and they are very happy with them. for me, i would still ask to test the tub. but if you dont, do as much talking around the tub while its running. just in case there is an issue (however slight) such as over heating and it shutting down.
hope this helped, good luck and congrats, you are about to be in hot water (im pulling for ya)
I can't coment on the brand itself or price but...
The illuminated ozone icon indicates that there is an ozone system connected to the tub. There are 2 types of ozone systems: UV (uses a UV light bulb) and CD: uses a spark plub type doo hickey. The ozone unit if UV may need a new bulb. CD units also don't last forever. Ask was this a factory installed unit? Did they ever replace the bulbs?
as far as checking out the tub, some of the things I'd look at are:
Open up the equipment bay and look for moisture and inspect the unions and plumbing. Look for signs of leaks rodents, decaying joints and hoses. Since this was an inside tub, the equipment are should be spic and span.
Make sure all the jets are working. Work all the jets and diverters. Run the pumps at all speeds. lsten for nosiey pumps, excessive vibration, strange sounds, etc.
Take a good look at any pillows. These might be in need of repair.
Look for blemishes in the shell and repairs to any cracks.
Take a good look at the exterior cabinet, the cover, lifter and steps.
Inpsect the filters. It maybe a good idea to figure in purchasing new filters.
I'd also take a look at how to get in and out of the house.
Don't forget to ask about the electrical box (who will do the disconect?) Are the box, breakers and wire whip included?
Ask about supplies and other freebies they might have laying around. (vacs, chems, test kits, manuals) etc.
Can they give yo uany history on the tub? When it was bought, how much paid, any repair work, why are the selling....
Are they going to let you wet test?
Good luck!
I will be moving it myself with a large trailer. Actually I just helped move my brothers to his new home an hour ago. Ironic. Socal thanks for the info. I dont really know how loud the motors should be. What should the foam inside look like? When I was there the other day it ran for 5 or so minutes and it sounded normal to me. I messed with all of the buttons and they seemed to work well also. There is only one button for the jets. Push once turns the 1st pump on, push twice and the 2nd one comes on. So you think I should replace the ozonator? Wonder what that runs. The thing I like is the spa (cosmetically) is in brand new shape(besides the pillows which is no biggie, will replace) and the cabinet looks perfect. I dont mean to ask all these questions but want to get some opinions. Anything else you guys can think of checking or asking before I buy this would be a big help. Thanks
when the equipment bay is open, if you see hoses hanging its partial foam.
drew (as usual) makes some good (ummm better) suggestions on what to look for as well. you could always print this out and take it with you so you dont forget anything on this growing list we are making for you ;D
youre welcome for the help. but not nessicary to thank me. like alot of people on here, i just want to help people get in some hot water ;)
as far as the ozone goes....like drew mentioned, if it has not been replaced before you probably would want to. here is the cal website. it has dealer locator and a parts page. http://www.calspas.com/. or 1-800-cal-spas. dont know if they will sell you parts or direct you to a dealer, but its worth a try.
if the owners do not have a manual, should be able to get one through the 800#.
Sounds like it only has one 2 speed pump. I would offer them 1500 then you got a good deal if everything works.
good point Tman.....is it a 1 pump model?? 96x96 seems too big for only 1 pump. again, that mystery will be solved by looking inside the equipment bay.
He told me it had two pumps. One on each side. What will they look like(i dont know, this will be my first tub)?
I also thought it would have buttons such as Jet1 and Jet 2, but it only has the one button. mmmm. I guess I will find out tomm. a 8x8 tub with one pump wouldnt be right, i wouldnt think. I will be able to look at the owners manual tomm night as well. If it is a 1 pump tub, should i even consider(being 8x8) buying it?
instead of trying to describe...which i started to due lol....lets do it this way.
http://www.calspas.com/parts/index~catalog~Pumps.htm
its a link to the type of pumps cal uses. as far as should you get it if its only 1 pump.....honestly, its an individual choice. granted, its a large spa. but there are only 25 jets from what you mentioned. i would consider it, but would have to wet test.
hope that helps
socal
Is it still hooked up so you can check it out? I have a friend with a 2000 Cal spa that he is still happy with. Its a low end one. This is a lot of spa for a little money. If it is operating, it probably is a deal. As Ronald Reagan said, "TRUST BUT VERIFY"
The big knock against Cal Saps is how well the back their product (or don't back it). However, in your case that is pretty much irrelevent as it will not be under warranty. Getting a used spa isn't a bad idea but I would look into where teh enarest dealer is so you'll know parts are available if/when needed 9and who would be available to service it when issues arise). Good luck.
Ok. I called the couple selling it. The pump is a 6 HP Dually pump. Made by GE. I called Cal spas and they told me this. The dually pump is actually two pumps running on one motor. So it has two pumps, but they run on one motor. To me that is a good thing for operating costs. I called a couple of Cal dealers around here and told them I was looking at a used Cal spa(so their opinion wouldnt be as bias, to get me to buy one from them). I asked them about the Dually and both dealers said it is a good one. They said it is like two pumps but saves money since it doesnt draw as many amps. One told me they sell 1/3 of the spas with the dually and one hasnt had to be serviced yet. They said 2 pumps would put out a little bit more, but it is alot more powerful than having one pump. And it does only have 25 jets. It looked to me like it put out some force when I turned it on. What do you guys think? It sounds like it might be a good buy.
Also thanks to everyone for helping me out. $2000 is $2000 so I just want to be sure I am getting my moneys worth. Again this is going to be my first Spa. I am 25 and just bought a home so my budget is low, so used is a good option for me as long as its a nice spa. One of these days I might be able to get me a "New, 60 jet spa" but like Socal said, I just want to get in hot water!
Thanks guys, I found a good forum with some good people in it.
you are deffinately going about it the right way, not only asking in here but also talking with the dealers. no one can say yes/no except you. it sounds like its in good working condition. you have seen it running which is a big plus.
honestly, i would jot down some notes from what we have said in this link (or just print it out) and give the owners the 3rd degree ;). after that, if you still feel comfortable with the performance/price/anything else we have mentioned.......go for it.
let us know how it goes.
socal
eventhough you are looking at the used route (which is fine, im not knocking it or anythin) it is good to test them out. if this was an empty tub, been sitting in the sun for 3 years without a cover on it, and the owner wouldnt fill it up for you, we would all be screaming [glb]RUN[/glb]....but since its up and running, in your budget, and it seems the owners have taken care of it, i think it wouldnt be a bad decision.
Thanks. I will let you guys know tomm night after I go. I still have to get my patio extended and want to wait for warmer weather so it would be 3 weeks or so until I get it running at my home. He said he would keep it running until I need it so it doesnt freeze. It's cold here in Ky. Again thanks and I will post tomm night.
I think that if you can see it running and it looks to be in really good shape as you've indicated then $2k isn't too bad of a deal for a good sized 4 to 5 yr old spa.
I agree with ST except I always offer less when ever I buy anything. When you get turned down as many times as I have it gets easy to ask, and it will never hurt. I think them dually pumps are funky. But they do seem to work good. Seems it would cut the motor life in half but it don't. Maybe by 1/3.
They were asking $2400 and i got them down to $2000. I will ask if they will include the GFI with it.
Just got back and I bought the tub. I looked at everything you guys said and I only found one problem. One of the fitings coming out of the pump was leaking a little. There was a little spot under there where it leaked before. He said he never saw it b/c the bottom sits under the deck. I turned the jets off reached under with my hand and it was loose. I tightened it by hand and let it run for 5-10 minutes and it wasnt leaking at all. Just a loose fitting. That didnt hold me back. Everything was nice and looked brand new. It was built on 4-2001. Every jet work great as well as the jet controls. He is getting a smaller tub so he wouldnt include the breaker but oh well. My brother with me b/c he has owned a spa for 5 years and knows more than i do. He said the leak wasnt a big deal. The biggest thing that could happen is I would maybe have to get a new fitting if it did it again. He couldnt believe the condition of the spa and agreed it was a great deal. I cant wait to get it home here in the next couple of weeks. It was fully insulated(couldnt see any pipes but the ones that came out of the pump. It was in top shape. Thanks to all that helped me getting my new (but used) hot tub. I am going to post some questions about chemicals to use so help me out. Thanks guys.
Chris :)
Congrats! I hope it works out for you!
Put some thought into moving the tub, as this is were joints and such can get knocked around and cause problems.
congrats mothergoose!! im happy to hear everything was alright with the tub (other than a loose fitting). good idea to take your brother along due to his experience with hot tubs.
as far as the disconnect goes.....there are a few different ones that are available at lowes/home depot. they range in price approx 50-125 bucks. we use/reccomend the brand conneticut electric (but that doesnt mean you have to use it ;D). if you purchase it yourself and do some prep work, it will save you money on the install. just something to think about so you keep your budget.
when are you picking up the tub? let us know how the 1st soak goes.
as far as chemical questions.....have we not done enough??? just kidding ;) ;D we are hear to help!
socal
Thanks guys. I still have to extend my patio to hold this big tub. 8 ft by 8 ft. Cant wait to get it. So it will be maybe a month. It will be alot of work but I can sooth my muscles when its all said and done. ;)
aint that the truth!!!! it might seem like a ways away, but when its all done you will be very happy.
