Original => Hot Tub Forum => Topic started by: brewski on December 20, 2005, 12:18:23 pm
Title: High Blood Pressure & Hot Tubs
Post by: brewski on December 20, 2005, 12:18:23 pm
After owning our hot tub for just over a year now (and lovin' it) my family physician has told me that I need to start taking medication for stage 1 hypertension. Darling wife says I also need to cut back my use of the hot tub as she thinks it is bad for my BP. I use the tub about 5 nights per week for maybe 20-30 minutes per soak, is that really too much usage or is the wife being too cautious?
Title: Re: High Blood Pressure & Hot Tubs
Post by: drewstar on December 20, 2005, 12:28:32 pm
I have high blood pressure. I am on medicatication for it,  and asked my doctor about it, and was told not to worry too much about it, as my BP isn't that high, and I was only soaking for 1/2 hr about 3 times a week.
(101 F).
So, you can enjoy a hot tub if you have high BP, but talk to you Doc about it,  as only your doctor knows your spefific conditions and risks.  I was warned to be a bit more cautious about getting out of the tub, as the heat can have a greater effect on someone with HBP.
Post by: blizzard on December 20, 2005, 12:37:29 pm
Definitely would talk to the Doc. Of course some of the advertising on hot tubs I have seen claim to help HBP and other things, but then again it's hard to believe everything (anything) you here from someone that is trying to sell you something.
Post by: drewstar on December 20, 2005, 12:43:48 pm
From the American Heart Association Web site:
http://www.americanheart.org/presenter.jhtml?identifier=4653
High Blood Pressure and Hot Tubs (Saunas)
AHA Recommendation
Hot tubs and saunas — if not misused — pose no risk to healthy people. People with high blood pressure who have no symptoms should tolerate saunas well. The relaxing of the blood vessels associated with the heat is about the same as from a brisk walk. Any active symptoms such as chest pain or shortness of breath that would cause a person to avoid moderate exercise would also be a reason to avoid a hot tub or sauna.
Alcohol and saunas aren't a good combination. Don't drink while in a sauna. Also, moving back and forth between cold water baths and saunas or hot tubs can raise blood pressure. If you have high blood pressure, don't do this.
Post by: blizzard on December 20, 2005, 12:54:30 pm
I wonder what they mean by misuse ??? ???
Post by: drewstar on December 20, 2005, 01:08:08 pm
Using the hot tub the way Term does.
The man is an animal.
;D
Serioulsy though, I took it too mean soaking too long or at a very high temp, consuming mass quanities of alcohol.
Post by: brewski on December 20, 2005, 02:34:56 pm
Usually if I drink anything while soaking it is water. Maybe a beer once in awhile.
 ;D
Post by: fatman on December 20, 2005, 03:46:18 pm
All depends on what type of medication your doc is prescribing for you. If doc is giving you a beta blocker(slows the heart down a bit) then you probably wouldn't have any problem with the vasodilation that occurs with a dip in the hot tub. On the other hand, if doc is prescribing a drug that vasodilates then that would not be good for hot tubbing. Ask doc to describe for you how the drug works on the body. Other factors to consider would be if you are a diabetic, obese and how hot you keep your tub. The warmer the water, the more you will vasodilate.   Alcohol and hot tubbing don't mix well either. When you first ingest a beer it will vasodilate your veins/arteries. As the alcohol goes through your digestive system you will vasoconstrict and your heart rate(pulse) will increase. Your body will be in a tug-of-war with the vasodilation from the heat and constriction caused by the alcohol. It's much better to drink water or a Gatorade while you are tubbing.  Talk to your doc.
Post by: Haynes on December 20, 2005, 06:55:59 pm
Precautions should be taken to avoid orthostatic b/p  (low blood pressure ) ie: take your time changing positions, rise slowly from the hot tub and let your body adjust to  standing for 30-60 seconds before walking ect to prevent sudden drop of b/p. I am on antihypertensive meds without any ill effect.  If you are on meds and your doctor is maintaining your systolic b/p 90-100, you would be more prone to the orthostatic hypotension so be careful .
Post by: Steve on December 20, 2005, 07:02:21 pm
And after all of that information you received above, go talk to your doctor as he knows you and your BP better than anyone here. It's not something to take lightly.
Post by: wmccall on December 20, 2005, 07:24:28 pm
Lots of wise advise so far. I also have/had Stage 1 hypertension, and a soak in a hot tub can raise it slightly while in many people find their BP lower soon after the soak. Many Doctor's feel the spas are a long term benefit to people with high BP.  The best thing, as any doctor will tell you for 1st stage is excercise and diet.  And I'm sure any doctor would say as with the excerise, "within reason"
Post by: Dr. Spa™ Ret. on December 20, 2005, 11:24:09 pm
TONS of info on Google. Type in;
hot tub hypertension
Post by: brewski on December 21, 2005, 11:40:31 am
Thanks everyone for all the advice! Well I just picked up my meds at the pharmacy last night on the way home fom work, 10mg of Lisinopril, 1 pill per day. I am scheduled to meet with the doc next Tuesday to see how well the meds are working and when I do I will discuss these issues with her.
Just for clarification, I'm usually a water drinker when in the hot tub but will sometimes have ONE beer, usually after a round of golf and just wanting to relax. Water temps are normally kept at 102 and in the summer we drop it down to maybe 98-99. I am well aware of the diet and exercise necessity although I'll be the first to admit that I shudder at the thought of both. Since my first meeting with the doctor on the 9th I have made a conscious effort to improve in both aspects and my darling wife is acting as my "coach" with gentle and not so gentle reminders on a regular basis.
Thanks again all.   ::)
Post by: drewstar on December 21, 2005, 12:06:25 pm
I'd be very curious to hear what your doc says about the hot tubbin. If it's not prying, please let us know what he says.
Good luck.
Keep yourself healthy. :)
Post by: fatman on December 21, 2005, 05:50:23 pm
Lisinopril is an ACE inhibitor. It will vasodilate your veins and arteries and is metabolized in your kidneys.  ACE inhibitors are very effective drugs so do be careful of the tub temp and the sudden temperature change that goes along with getting out of your tub.
Post by: brewski on December 28, 2005, 11:07:00 am
Good luck.
Well I met with my doctor yesterday and she is quite pleased with the way the meds have worked in the first week. My BP yesterday in her office was 125/80 down a good bit from what it was pre meds.
As mentioned elsewhere she did advise me to be careful getting out of the tub and also suggested that I keep my usage to about 20 minutes per night as I generally do anyway.
Thanks again for all the good suggestions and information.
Post by: grahamtasia on December 28, 2005, 11:52:55 am
I am glad to hear your bp is down! In your situation it is always best to consult your physician.
