Original => Hot Tub Forum => Topic started by: puma on November 27, 2005, 07:04:09 pm
Title: HS Vanguard or Sundance Optima?
Post by: puma on November 27, 2005, 07:04:09 pm
We are looking at these two models for purchase I was wondering if anyone can help us make the decision.  My questions are:
Is it true you have to clean the HS filter every month in a dishwasher? (we don't have one) so that is somewhat of a factor.
Does the Vanguard spaudio system connect to the ipod?  (we were told it did)
Is the warranty on HS 7 years and the Sundance 10? I keep reading the HS warranty is better but was told this at the Sundance store.
Anything else that you think would be helpful would be greatly appreciated.  We were really impressed with both spas, but really need to make a decision.  Many thanks for your input. David
Title: Re: HS Vanguard or Sundance Optima?
Post by: tonyp on November 27, 2005, 07:39:40 pm
You can wash the Tri-X in a dishwasher but you don't have to.
I don't have it but I believe that the SpaAudio connects to any audio device with a headphone jack.
Post by: puma on November 27, 2005, 07:44:43 pm
Thanks for the response Tonyp.  Can you wash it by hand then?  Or do you replace it?
Post by: PaulMc on November 27, 2005, 08:07:41 pm
  Puma. I happened to buy a Sundance, the Majesta. Both companies make great tubs. I didn't see you mention wet testing. That's the key ingredient to me... how do they feel. If you really think they're the same, then since they're both good manufacturers, I'd fall back on how you feel with the dealer. If you really like one a lot better or feel more comfortable or trsut one over the other, then go with them. Cost to heat and run, chemicals, filters etc. over the space of a few years and warranties are probably close with either, I'm not sure because in my case the decision was easy after the first two criteria.
 Enjoy testing them.   paul
Post by: tonyp on November 28, 2005, 06:09:07 am
You can spray on filter cleaner or soak them in it instead of the dishwasher.  I do that when I change the water.  Monthly I just rinse them with a hose.
Post by: Debra on November 28, 2005, 08:07:04 am
I agree with Paul.  For us it came down to the wet test.  We were deciding between the same two as you and went with the Optima only because the moto-massage wasn't comfortable for us.  So try it out and I'm sure you'll be happy with either tub.
Post by: Brewman on November 28, 2005, 09:10:51 am
Qualitywise you won't go wrong with Sundance, and what's been posted here says the same about Hot Springs.  Comes down to dealer- either one give you a better vibe than the other?  Price- Is one significantly more expensive?  And as others have said, which one fits you better?
Post by: hymbaw on November 28, 2005, 11:20:20 am
Definately wet test!
HOw many people do you envision using it? For tubs that are close in size (Vanguard 7'3"x7'3", Optima 7'5"x7'5") the Optima will fit more people. Both great tubs, can't go wrong.
Post by: Guzz on November 28, 2005, 02:06:20 pm
1. You can clean the HS filters like any other filter, once a month is normal.
2. Yes
3.Both spas have a 5 year parts & labor warranty, the sales man is refering to the shell warranty, bit of salesman ship there.
Both are good spas, I sell Hotspring and the Vanguard is a very popular spa, even more so since they put in the new double moto massage and extra pump. You will be happy with either so let the wet test decide.
Post by: puma on November 29, 2005, 11:20:01 pm
Thank you everyone for all of the good advice and the answers to all of my questions.  We are going to look at them again this weekend and hopefully make a decision.
