Original => Hot Tub Forum => Topic started by: Bonibelle on November 23, 2005, 11:45:22 am
Just wondering how to insert a website from my favorites list into a post?
Click on the website, go up to the address bar, highlight it, click "copy", come back here and in the body of your message put the 'http:// "paste" ' and you're good to go.
Terminator
How do you get the link to be active? Whenever I try that the past works, but the link isn't live- you can't clik directly on the text.
Is that a bb restriction, or am I missing something?
You type this [url].
Then you paste the www.whatever.com
Then you type this [url] but between the "[" and the "u" put a "/"
And it should work.
Terminator
Helpful hint #22:
If you can't get the syntax correct to do whatever....posting live links, posting pics, using special fonts, etc....just find a post that has whatever you are attempting and click "reply". This will show you the syntax to use. Copy, start your own post, paste and replace with your own info and, voila, you're cookin'!
