Original => Hot Tub Forum => Topic started by: cappykat on November 10, 2005, 09:58:01 am
Title: Readings are High Again
Post by: cappykat on November 10, 2005, 09:58:01 am
Yesterday when I refilled, I checked the water and everything was perfect.  I just checked today and the pH and Alkalinity is high again.
I'm using AquaChek test strips.  The pH seems to be between 7.8-8.4 and alka beween 180-240.
Should I add a couple OUNCES of pH Down??
Title: Re: Readings are High Again
Post by: East_TX_Spa on November 10, 2005, 10:01:16 am
Yes.  That should do it.
Terminator
Post by: cappykat on November 10, 2005, 10:02:11 am
Morning, Term!  Ok, I'm adding 2 OUNCES of pH Down, right??
Post by: East_TX_Spa on November 10, 2005, 10:10:53 am
Buenos dias senora!
Si! pH decreaso, undale!
Terminato'
Post by: cappykat on November 10, 2005, 10:23:55 am
Now I'll wait 24 hours and test again?
Post by: East_TX_Spa on November 10, 2005, 10:25:34 am
How does your calcium hardness reading look?
Terminator
Post by: grahamtasia on November 10, 2005, 11:39:25 am
You should take a spa water sample along with a tap water sample  to a local pool and spa store that does water testing and have them test for metals. Also check the date on your test strips to see if they have expired.
Post by: wmccall on November 10, 2005, 11:43:37 am
Yes.  What are you usin to test? 7.8 is high, but tolerable, 8.4 is just high.  The alk readings are ok. If that were my tub, and I thought the reading was 7.8 I would leave it alone as my PH tends to drift down over time.  If I knew my PH was 8.4 I might try to lower it. I'm currently out of PH down, so I might give the White vinegar a try. High PH is not something I normally see.
Post by: grahamtasia on November 10, 2005, 11:46:55 am
You do not have to wait 24 hours.  Run the jets for an hour or so and then test it.  2 hours should be sufficient.
Post by: cappykat on November 10, 2005, 11:51:27 am
AquaCheck paper test strips.  It's a match the colors game..HA!  The hardness was within normal range and the bromine was normal.
I say pH is between 7.8-8.4 because the pink is between those ranges.  I would say it's on the high end.  I put in 2 ozs. of pH Down and I'm going to wait to check it late tonight or tomorrow morning.  Husband will probably use tonight.  I'm sick with a sinus infection so I won't be going in.
Post by: grahamtasia on November 10, 2005, 11:54:34 am
Make sure the tub is running after adding the ph down, so, you do not drop your alkalinity. You can check in a couple of hours.
Post by: cappykat on November 10, 2005, 11:55:14 am
When you say "run the jets" does it matter if the cover is up/down?  That's probably a stupid question, but I don't know if it matters.
Post by: grahamtasia on November 10, 2005, 12:02:02 pm
You can run the jets with the cover on.  If you run the jets with the cover on alot, the increased condensation will make the cover heavier over time. The way I do it is if I am home I leave it open and if I have to leave I keep it closed.
Post by: ssbraun on November 10, 2005, 12:07:52 pm
I leave the cover 1/4 open (3 piece cover); I think it is most important to do so for an hour or so when shocking but I do it when adjusting ph also.  One note:  If jets are on with air valves open, the aeration can give "false" high ph readings.  I've been battling high ph for a couple weeks, and I add ph down, run all pumps for 15-20 minutes, wait an hour and retest / redose as req'd.
Cheers!
Post by: HotTubMan on November 10, 2005, 01:11:14 pm
Cappy;
You didnt mention what your chlorine or bromine reading are.
I mention this because I find one very weak aspect of test strip and lower end test kits (ones without thiosulfate (chlorine neutralizer)) is reactions with chlorine.
If your chlorine is high, it is quite likely that you will get a high pH reading even if your pH is OK.
A nicer test kit or store lab will test your chlorine before the pH to determine how much neutralizer is required to get an accurate pH reading.
Post by: East_TX_Spa on November 10, 2005, 01:13:34 pm
Cheers!
I don't know much about math, but how do you leave a 3-piece cover 1/4 open?  That must be calculus or one of those other Chinese words.
Terminator
Post by: HotTubMan on November 10, 2005, 01:19:10 pm
Maybe its a three seamed or quad-fold cover....
Post by: grahamtasia on November 10, 2005, 01:19:33 pm
I was wondering if anyone was going to go there!  Good call!!
Post by: cappykat on November 10, 2005, 01:25:06 pm
What is a better test kit to use?  I just checked after 2 hrs. and hardness and bromine levels are within normal range.  The pH and alk is still high (same #'s as before I added 2ozs. of pH Down.  I'm going to take a water sample to the pool store and see what they say.  Should I do anything else in the meantime?
Post by: grahamtasia on November 10, 2005, 01:31:10 pm
I wouldn't do anything else at this point.  Take a spa sample and a tap water sample to the pool store. Between the two they should be able to resolve your problem.
Post by: ssbraun on November 10, 2005, 01:53:09 pm
Terminator
Simple really: put one seam in the middle; split one of the 2 halves into 2 again giving you a 3 piece cover with a small (approx 1/4 size) section to open and add chemicals etc.  Standard Maxxus cover... ;)
Post by: stl-rex on November 10, 2005, 01:58:36 pm
I got sick of trying to decipher the colors and bought this:
http://cgi.ebay.com/Hanna-pH-TESTER-METER-Aquarium-Hydroponics-Lab_W0QQitemZ7559090510QQcategoryZ58191QQrdZ1QQcmdZViewItem.
Sorry for promoting a product.  I have no ties to it other than I bought it and it works well.  It comes precalibrated.  Our temps and pH range are not extreme enough to worry about compensating for those attributes when reading pH off the meter.  It's great.
Post by: East_TX_Spa on November 10, 2005, 02:09:38 pm
Simple really: put one seam in the middle; split one of the 2 halves into 2 again giving you a 3 pice cover with a small (approx 1/4 size) section to open and add chemicals etc.  Standard Maxxus cover... ;)
I like pi! :D
Terminator
Post by: grahamtasia on November 10, 2005, 02:18:48 pm
Pi is very good and very helpful!
Post by: drewstar on November 10, 2005, 03:02:16 pm
pumpkin or apple?
Post by: cappykat on November 10, 2005, 03:04:06 pm
Just came back from doctor...sinus infection so I'm out of the hot-tub for a few days.
Thanks stl-rex.  I'll check out that website.
Post by: grahamtasia on November 10, 2005, 03:05:05 pm
During this time of year pumpkin is a very popular choice. However, you can never go wrong with apple.
Post by: Brookenstein on November 10, 2005, 03:16:24 pm
Hope you feel better soon!
Wouldn't the steam from the spa help you feel better?  Why do you have to stay out of the spa?
Post by: ssbraun on November 10, 2005, 04:47:32 pm
I like pi! :D
Terminator
shoulda known we'd get back to your love of all types of pi sooner or later ;D
Post by: cappykat on November 10, 2005, 04:48:35 pm
Thanks, Brooke.  Mostly cause I feel like crap and just want to get some sleep.
Post by: East_TX_Spa on November 10, 2005, 05:12:25 pm
I DO love pie!  What's your favorite kind of pie ssbraun?
Terminator
Post by: grahamtasia on November 10, 2005, 05:15:09 pm
Pi readings are up also i've noticed, not just the ph!
Post by: Lori on November 11, 2005, 05:58:16 pm
I have to make 2 Key Lime Pies for next weeks holiday dinner!!
;D
