Original => Hot Tub Forum => Topic started by: Cass on September 26, 2005, 04:35:24 pm
Title: It's here!!!!!!!!!!!!
Post by: Cass on September 26, 2005, 04:35:24 pm
But the electrician can't come until tomorrow.   :'(   My question is this, should I have my spa filled or empty tomorrow morning when he comes?  I don't expect he will wait around while the spa fills so he can turn the power on.  So should I fill it in the morning before he comes?  Thanks.   :)
Also:
1.  The thin white strap that's around the filter.  Does that stay on?   (T.R. Caspian)
Title: Re: It's here!!!!!!!!!!!!
Post by: tonyp on September 26, 2005, 04:39:12 pm
I would fill it so that I could test it before he leaves.
Also:
I did.
Post by: Guzz on September 26, 2005, 04:39:30 pm
So long as the spa does'nt have to be moved at all you could fill it today, and the white strap stays on. Congratulations, may you have much Tigertherapy... Guzz
Post by: Cass on September 26, 2005, 04:48:30 pm
Thanks for your replies.   ;)
Post by: Spatech_tuo on September 26, 2005, 05:03:35 pm
It only takes about 45 minutes to fill but if you/he want to move it a bit you'll need to know that ahead of time. I would discuss this with the electrician and let HIM decide but also let him know you want to fill it and see it running before he leaves. He could time it to start filling as he's winding down and cleaning up.
Post by: Cass on September 26, 2005, 07:07:34 pm
Good idea. Thanks.
Post by: hottub.pool_boy on September 26, 2005, 09:54:03 pm
the thin band stays on. eventually it will fall off.
Make sure the electrician trims the mouse screen neatly. look closely, there are pre-punched areas/knockouts for 3/4" conduit.
or take the mouse screen off all together and refit it yourself after he/she has completed the electrical work.
Post by: Lori on September 27, 2005, 05:35:19 pm
Have I wished you hot, clean, bubbly water for many years to come??
You are almost in Spatopia!  Enjoy it!
Post by: Cass on September 27, 2005, 05:55:50 pm
Thanks Lori.   ;)  All I have is cold water at the moment though.  Darn electrician can't come until tomorrow.  We've been expecting him since monday.  He says his truck is in the shop.  I'm trying to be patient, but it isn't easy seeing that beautiful water out on my patio.   :'(
Post by: Lori on September 27, 2005, 06:05:26 pm
I went through something similar.  Just remember, when you DO get hot water, all of this frustration from waiting and being delayed will quickly melt away!  This will all be a distant memory pretty soon!  Hang in there!
Post by: Cass on September 27, 2005, 06:09:16 pm
Thanks.   :)
Post by: amat1950 on September 28, 2005, 01:59:39 pm
Happy soaking in your new tub, Cass!!!!! I have had ours two weeks and it is truly wonderful.
Ann
Post by: Cass on September 28, 2005, 02:46:35 pm
Electrician finally came this morning!!!!  Had it hooked up in 2 hours.  He says it should be warm/hot in 9-10 hours.  It's already starting to feel warm!!!  Yipee!!   :D
Post by: Spatech_tuo on September 28, 2005, 04:26:22 pm
If you ran 220v it'll be warm sooner than 9-10 hrs. Hope your Tigger Rivver serves you well.
Post by: drewstar on September 28, 2005, 04:32:05 pm
Yup. Unfprtunately the worst thing you can do to your tub is actually get in it.  That screws up the water chemistry. Most of us just balance and b!tch about the water.
Actually get in the Tub? That's Crazy Talk!
