If you have a relatively short or moderate run, you are probably ok. 6 gauge wire is rated for up to 60 amps.
I am curious, what is considered a short or moderate run in terms of length?
To my knowledge a breaker is either off or on; no inbetween. Can I try running the tub with the 40A, and see if it trips or should I go with a bigger breaker from the start? How would the tub know what breaker it is hooked up to, besides the actual breaker tripping?
-Greg
Do you know what size wire was installed?
You can use 10 gauge for up to 30 amps, but 40 amps needs 8 gauge. That's for copper wire.
If it isn't copper wire, what is the other kind? There is an inspection note that says something about aluminum... could that be the type of wiring I have? Anyway, I can't tell what the guage is. There are 2 wires. One white one that has magic marker on it to look black and the other one was either black or hot pink. I forgot already. Anyway, the wires were real thick looking especially in comparison to some on the 15A ones. Hopefully I'm fine. When I have someone out to give me estimates on the wiring for the spa, I will have them check it out for me.
Thanks for the help.
I would check name plate rating on tub "full load amps" to see if 40amp breaker will hold the load. There is NO harm in trying the 40, if it draws too much it will trip the breaker which will not harm a thing, that is what they DO.
If it trips or you are suspect upgrade breaker to 60amp your #6 wire is rated for that current anyways. The only time length of wire comes in to play is if it's hundreds of feet long.
enjoy
Copper wire will look like the color of a penny, aluminum wire will look like silver color.
I gotta remember to write that down! ;)
Are you making fun of my wiring stupidity? :o
I'm still thinking I need an electrician to look at it.
BTW, the wire gauge size is probably printed on the outside insulating jacket of the wires themselves in case hubby didn't already check.
