Original => Hot Tub Forum => Topic started by: BobRex on August 22, 2005, 08:55:21 am
Title: Lightning!!!!
Post by: BobRex on August 22, 2005, 08:55:21 am
Last week my house got struck by lightning :'(.  It appears to have struck a vinyl porch post (interior steel column) and travelled to the Cameo sitting about 3ft. away.  Took out the heater and circulator pump and then travelled into the house wiping out a printer, cable modem, garage door opener, a couple of GFCIs, the security system fire alarm controller, and a tube amp (stereo).
Almost everything is fixed or replaced, I've just gotta tear the amp apart and see what got hit.  But I did discover one small problem - it seems that the hat tub breaker trips during a filter cycle.  Time to call service back!
Title: Re: Lightning!!!!
Post by: stuart on August 22, 2005, 10:41:27 am
Your ozonator was probably zapped and trips the GFI everytime it tries to kick on...
Post by: georgiapeach on August 22, 2005, 03:12:16 pm
Robrex,
Sorry to hear about your lightening strike.  Same thing happened to me a couple of months ago!  Luckily, the only thing that went on my hottub was the GCFI breaker to the heater and the place where I bought the hottub came out and replaced at no charge.... :-)   I also lost my computer modem, router, shredder, garage door opener, 2 ceiling fans in my sunroom, and a telephone.  Strange how it hit certain things, but not others, i.e., stereo and TV (which was on and I only had it for 4 days!).  Most expensive thing I had to replace was my garage door opener ($300!).
Peachy
Post by: georgiapeach on August 22, 2005, 03:12:50 pm
Excuse me...I meant to say BobRex...Sheesh!   :(
Post by: BobRex on August 23, 2005, 11:53:48 am
Hmmm, I didn't think of the ozonator.  I'll unplug it and try the spa tonight.  Thanks Stuart!
Hey Peachy,  don't worry, I've been called worse, lot's worse  ;D
Post by: johnvb on August 23, 2005, 07:46:54 pm
So what kind of tube amp?
I just got a pair of Maggies, using an Aragon amp to drive them. Thinking about adding a tube preamp, like a Foreplay.
I ran a 230 volt/ 4 wire dedicated circuit to a subpanel in my A/V closet/racks, and have a 4 pole disconnect, which basically "unplugs" everything electronic with one quick pull. (Of course I still have to be home when the storm hits)
Post by: BobRex on August 24, 2005, 09:53:23 am
The amp is a Welborne Moondog, it's a 2A3 triode based SET amp.  Put's out about 3.5 watts of some of the purest sound you'll ever hear.  Won't work with Maggies though, they need more (lot's more) juice.
Post by: tootall on August 24, 2005, 10:12:33 am
Just a question? For those who live in places were Thunder storms are a regular thing? what about a lightning rod? would that have prevented what happend? shure would like to know?
Post by: BobRex on August 25, 2005, 10:08:42 am
Lightning rods are a mixed bag.  The problem is that they may attract lightning that otherwise would miss the premise.  In my case, I'm in a rancher in a 2 story neighborhood.  There are plenty of taller structures around me, and in fact one of them took a hit (blew the chimney apart!).  BUT, there was a strike in a field (left a small crater) and my strike was at waist height on a porch, nowhere near the highest point of the house.
Personally, I'm not convinced that lightning rods are truly effective.
Post by: Chris_H on August 28, 2005, 10:16:51 am
I was just looking at some older posts.  I would doubt that it was the ozone as Stuart said because if I am not mistaken the Sunzone Ozone on the Sundance have a built in fuse.  Make sure you call your electrician and make sure the GFCI didn't break when the lightning stuck.
Post by: stuart on August 28, 2005, 05:25:12 pm
Be interesting to find out what it was....
Fuse or no fuse, if you get moisture in the system from a check valve failing you may or may not blow a fuse however you will more than likely trip the GFI breaker.
Post by: BobRex on August 29, 2005, 01:01:41 pm
Well, Chris hit it on the head!  On Friday I had both the electrician and the spa tech at the house and they discovered that the GFCI would trip even with no load.  So the electrician swapped out the GFCI and since then everything's working fine.
Just for the record, the spa tech had replaced the controller board the previous week when I originally placed the call.
Post by: Chris_H on August 29, 2005, 01:28:02 pm
I’m smarter than Stuart.  Now, that is a first. :)
Post by: stuart on August 29, 2005, 02:33:21 pm
They need to have one of these little smiley guys that bows down in respect because I would have used it ;) :( :o
BTW, a lot of people are smarter then me...I simply talk more and louder with a much more intimidating look so that I can hide that ;D
Post by: tootall on August 29, 2005, 10:28:00 pm
thanks for the Info on Lightning rods I do understand better now. I just live in a place were we do not get a whole lot of lightning.
Post by: Chas on August 30, 2005, 10:36:16 am
That has worked for me for years.
Post by: AAAAAAA on August 31, 2005, 10:42:00 pm
I find it funny when people claim tube amps are so pure..when the tube's purpous is to color the sound, thus changing it from its original state.
And lets not forget back then there were no rules for rating equipement, if you wanted to rate a 50watt amp at 5 watts... then so be it.
That is all.
Post by: BobRex on September 01, 2005, 09:19:03 am
Hmmm, 25 years of doing IC design work at Bell Labs ( you may have heard of them, they invented the transistor  ;D), 20 years of selling high-end audio (both tube and solid state), EE and Comp Sci degrees, and I've never seen any citation (and I'll go back to Keroes and Williamson) where the purpose of a tube is to "color the sound".  So could you please enlighten me as to where you discovered the purpose of a thermionic device?  And as to where it was discovered that semiconductor based devices are so devoid of this purpose?
Are you ready to argue the sonic impact of even order versus odd order harmonics?  Have you seen Scott Frankland's research concerning the distortion spectrum of triodes vs. other devices at low power levels?  I'll give you a hint - at low levels DHTs are superior to all other devices.
Now, since this is a forum for HOT TUBS, please resond via PM so as to not bother everyone else.
