Original => Hot Tub Forum => Topic started by: Campsalot on July 27, 2005, 05:38:25 pm
I have discovered what causes foam in my hot tub. No I am not drinking beer in the tub. I recently changed my water and added the necesarry chemicals like bromine, PH -, etc... Once I added the water clarifier, I got foam. Seems to me clarifier should be renamed to foamafier. Anyone else have input on this?
foamifier is a pretty accurate description. I try not to put any chems other than sanitizer, shock and baking soda in my tub. I do use Spa Perfect enzyme stuff once a week and after a filter change just in case there is a trace of cleaner left in the filter
txwillie
Arrrgh. Tell me this isn't true. I had a slight foam problem after several curious friends spent a significant time in my new tub. I used a foam down product. It worked ok. but the water was cloudly, so I then used a clairerfier.
Water cleared up, but then slight foaming came back.
More anti foam which lead to more clairfier which lead to more anti foam which lead to more cairefier...you get the picture. After 1.5 weeks of chasing this, I said "screw it" and followed the 1 month rule and dumped the water.
arrrrrrrgh! Gererally speaking, doing clairifiers typically cause some residual foaming?
IMO, clarifiers should be used when needed but not as a routine add. They do cause more foaming initally and you should rinse off your filter after using them.
BTW, I never cared for much foam in my beer either.
I added my clarifier last night since the tub looked a bit cloudy but everything else was in perfect alignment, ph bromine and alk was good....mine never did foam, but...what I got was worse than foam...a tub line from h e double tooth picks..it looked like someone smeared grease on the side of my tub!! EWWWWWWWWW talk about gross to clean up this morning! So......my water is now very clear, and everything is clean once again..oh I am currently cleaning fliters.
hey campsalot
You must be drinking american beer. Foam in our Canadian beer brings a tear to my eye each sip. Listen, tilt the glass when you pour, the true canadian way.
And for petes sake, stop drinking the old milwauke and spend the money on some good canadian beer. Our beer actually has flavour and booze, unlike that american brand.
Eh, bosco! What kinda of beer should I drink eh! Maybe I should go north. You see after all I'm just a hoser eh??? LOL Good post Bosco
ouch eh, you cant talk like that without a tuke on eh. Listen come deep north into a small place called Canada, where the beer is always cold and strong, hockey is always on one of our channels, and only where men can grab a broom and use it to play a sport. Thats what im talking about, Canada.
Watch out for the mounties at the border, and if you want to go tubbing at my house, make sure you bring a winter hat, -26 sure is cold down here but it usually gets colder than that.
oh yeah I forgot,
Take off eh!!!!
;D ;D ;D
