Original => Hot Tub Forum => Topic started by: Haynes on July 10, 2005, 07:04:07 pm
Title: Water Chemistry Software
Post by: Haynes on July 10, 2005, 07:04:07 pm
Does anyone have a water chemistry software to help maintain proper water chemistry?  It is something I would like to try.  Just ordered a Taylor test kit and would like to take out the quess work of how much chemicals to add ect.
If you have a software please state where you got it, how well do you like it and if it can it be ordered online.
Thanks in advance.
Haynes
Title: Re: Water Chemistry Software
Post by: wmccall on July 10, 2005, 07:33:41 pm
I didn't investigate, but I think I saw something like this at spadepot.com
Post by: Vinny on July 10, 2005, 07:42:43 pm
Don't have software but the Taylor kit does make it easy!
This is all in the booklet that comes with Taylor kit:
Test your tap water.
You know your spa's volume - so you may need to add x oz. of alkalinity increaser and y oz. of calcium increaser to get to a beginning level. PH will move up as you use alkalinity increaser.
For calcium - your done until a water change, for alkalinity or PH add 1 or 2 tablespoons of increaser to get them up.(dependent on volume)
To get alkalinity or PH down - use z oz. of PH down.
As far as dichlor - well that is hit or miss - the Taylor kit doesn't seem to work for me. But how much chlorine to get to a certain PPM is dependent on how many people are in the tub. 1 person may need 1 teaspoon but 5 people may need 2 tablespoons.
When you get the kit, read the instruction booklet - it really does explain a lot.
