Original => Hot Tub Forum => Topic started by: wade on March 05, 2005, 12:48:04 pm
Title: to ozanate or not to ozanate that is the?
Post by: wade on March 05, 2005, 12:48:04 pm
are the advatages worth the $ ???am told by dealer that ican expect to spend about $1400 for the best they have to offer.is acheaper one out there,or is it worth the$ will having an ozanter reduce the amount of chlorine i have to use .what about the cover.ihave heard that ozone destroys cover.any help is allwaysappreciated.
Title: Re: to ozanate or not to ozanate that is the?
Post by: HotTubMan on March 05, 2005, 01:03:44 pm
Wade;
You are refferring to the Arctic Peak Ozone system, right?
I dont know if it is worth that much (I don't mean the dealer is overcharging, I dont know the dealer cost), but it is better system. For those that dont know, the system in question uses a circ pump and extended tubing and multiple contact chambers.
I think you would enjoy benefit from a CD or Plasma system.
An ozone system can hurt the cover. So can consistently high levels of cl/br.
HTM
Post by: Spatech_tuo on March 05, 2005, 01:30:45 pm
$1400, seriously? CD ozone usually costs $200-400 depending on the unit. UV is less expensive, less effective and requires a bulb change about every 1½ yrs (and its not a $3 bulb). For $1400 I'd expect a VERY good CD unit and a factory rep at my house every weekend to mix drinks for me and mow my lawn.
Post by: HotTubMan on March 05, 2005, 02:56:07 pm
In Canada, they retail their "peak ozone" system for $2K.....
Post by: Chas on March 05, 2005, 04:52:55 pm
Be still my heart !!
:o :o :o ::)
Title: Re: to ozonate or not to ozonate that is the?
Post by: JPKeirstead on March 05, 2005, 05:36:13 pm
While the Peak Ozone System is very expensive, there are is a reason.  The components that we put together to build this system are very expense.
1)  We use a corona discharge ozone generator that was designed for swimming pool applications.  It produces 500mg/h of ozone at a concentration of 1400ppm.
2)  Because we are producing so much ozone, we have to adequately mix it and then destroy any off-gas that has not dissolved into solution.  To do that we require:
 a)  A special circulation pump that is capable of performing in a highly corrosive application.  The pump we use costs more then a standard jet pump.
 b)  We then need a mazzei injector to help break up the ozone so that in can more readily dissolve into solution.
 c)  From there we need a stainless steel static mixing column with ,high surface area Tri-pac in it, to further help mix the ozone into solution
 d)  Then it goes into another stainless steel off-gas chamber, which is designed to draw off any undissolved gas.
 e)  The undissolved gas is then drawn through a catalytic filter, which converts the ozone back to oxygen.
This system is extremely effective.  No question.  It is not for the customer looking to save money.  It is for the customer who would like to limit chemicals as much as possible.  Please, before anyone jumps on me, I am not suggesting for a moment that it eliminates the need for sanitizer.
James
Post by: Chas on March 05, 2005, 05:57:16 pm
Sounds impressive.
Do you have to replace or service the catalytic filter?
Post by: JPKeirstead on March 05, 2005, 07:43:17 pm
You shouldn't.  However, it could be replaced if it was is not performing as expected.
Post by: Steve on March 05, 2005, 08:45:11 pm
Thanks for the details James. I guess the obvious question would be to compare it to other quality ozone units available that require much less maintenance compared to ozonators of the past and eliminating the need to replace the chip every 20-24 months. These units are sold at around $250-$300US I believe.
Is there anything that will show the payback time of your ozonator as opposed to the more conventional units? What is the warranty on this peak ozone unit? Thx,
Post by: JPKeirstead on March 05, 2005, 10:38:27 pm
Hi Steve,
Actually it is quite a bit bigger then the other ozone generators I have seen in any spa.  So it is more expensive then $200-$300.  And it is more then just an ozone generator, it is a system, that not only produces ozone, but also mixes it into solution.  However, you have made a great observation.  I think that payback on this system, if one was only measuring their savings on chemicals, would be measured in years.  I believe the real advantage to the system is how little chemical is required to maintain quality water, and in the ozone's ability to oxidize other contaminants in the water.
We warranty the Peak Ozone System for five years.
James
Post by: Steve on March 05, 2005, 11:31:32 pm
Thanks James. For the record, and I believe I speak for many here, I do appreciate your feedback and insight and the way in which you present it.
This has always raised an interesting debate and even though I work for a manufacturer that has ozone standard with all models, the question is and has always been, just how much does ozone reduce chlorine use and what is the actual benefit to the consumer.
Would you agree with the statement that we as an industry are unable to determine this figure and attach a meaningful dollar value to the end user of the financial benefits of ozone?
How do you then correlate a payback for the benefit of going to such an advanced and costly system? Meaning, if I were a customer, how would I be able to determine if spending this additional amount would benefit me from a financial and maintenance standpoint understanding the core benefits of a generic ozone system and comparing it to yours?
I agree that payback for ozone is calculated in years as it is with virtually any ozone system on the market today. The fact remains that none of us have been able to put a true dollar & cents value to it and therefore can not give an accurate response. Do you agree with this?
Post by: Spatech_tuo on March 06, 2005, 12:58:29 am
This is one of those occasions where some look at ozone differently. I don't think we should try to justify ozone's usefullness based on a reduction in chems. I say this for 2 reasons:
1) Ozone's main advantage is it helps keep the water clean/clear and results in EASIER water care. This is huge if you've ever seen people's frustrations in caring for their water. If it helps make the spa experience easier it makes the experience much more pleasurable.
2) It doesn't reduce chems that much. I'm a firm believer that while it should technically mean less chlorine need its not much and I advice people not to purposely try to reduce their chlorine use because of ozone because chlroine is too important.
Having sauid that, I'm still floored by the thought of an ozone system being $1400. I'm sure it works well but so do the other CD systems that cost $250-350.
Post by: HotTubMan on March 06, 2005, 11:12:32 am
Dimension 1 hads a system that is similar in principle and design to what JP has described.
There are differences, subtle and large. The two largest would be the generator & circ pump. D-1 uses the Plasma/UV bulb. D-1 uses a Laing circ pump. By the sounds of things the two items would be less expensive to replace than on the Arctic system.
I think I would have difficulty "upselling" the D-1 UltraPure system for $1000-$1500, thankfully it is a standard feature on a Dimension 1, which could help account for the higher price point on the Reflections & Bay collections.
Post by: wade on March 06, 2005, 06:24:27 pm
thanks for the info .i will have to do a little more research on any other ways of reducing my chlorine.it still seems to be what causes my skin problems.although changing to granular rather than chlorine floater seems to have helped.thanks again.        wade
Post by: Vinny on March 06, 2005, 08:59:15 pm
Wade,
Have you gone to Doc's site and look at the FAQ section for Vermonter's and Northman's way of chlorinating your spa. It seems that if you follow their regiment you will soak in close to zero or zero chlorine while maintaining a safe tub.
Although I don't have a tub yet, I do plan on using their advice. It seems that a lot of people follow the their advice and don't have any problems with their water.
Just my 2 cents.
Post by: wade on March 12, 2005, 11:14:54 am
 ???yoah vinny being a newbie i'm still a little lost :-/      how do i get to docs site to check this out?thanks for your help                      wade
Post by: HotTubMan on March 12, 2005, 11:20:05 am
I am not Vinny, but I have played him on TV.
Doc's Site:
http://www.rhtubs.com
Post by: wade on March 12, 2005, 11:43:10 am
thanks htman intresting site ,although i wonder,are all these produts for sanitizing your spa oked by health canada.has anyone heard any info on a sanitizer  using some sort of process using salt?
Post by: Steve on March 12, 2005, 12:58:31 pm
No Wade...not everything is approved for use here. In the US, they allow anything. Here, we're little more cautious! ;D
Hence the number of posts for itchy skin and rashes based from US consumers! ;)
Post by: HotTubMan on March 12, 2005, 01:53:07 pm
Steve;
You trying to get us Canadian chased out of here :) ;) :D ;D
Post by: Steve on March 12, 2005, 02:12:20 pm
What would this forum be without the Canadian content?  ??? OK..it wouldn't change at all...good point HTM! ;) ;D :-X
Post by: Vinny on March 12, 2005, 02:40:43 pm
HotTubMan - you do a good job portraying me!! Keep up the good work!
Wade I directed you to Doc's site because of the chlorine info that Northman and Vermonter had posted. I'm sorry I didn't include the site address - I think there is a Wade there and I thought you were him!
As far as the salt - there are salt generators that produce chlorine here in the US. People with in ground pools sometimes use them. I have an above ground so I have no clue how it works!
Post by: wilson on March 12, 2005, 05:43:21 pm
Just a 'Canadian newbie' here....But it seems in my search, this last week, some dealer somewhere (and I'm thinking it was Arctic spas) suggested that there was a possible issue about health risks and ozonators??  Do I have that confussed?  Wouldn' t surprise me with all info I'm trying to absorb!
Thanks for any clarification...!
Wilson
Post by: Steve on March 12, 2005, 08:38:05 pm
The drawbacks of ozone can be a concern for asthmatics, but there are no direct health issues I’m aware of with a detailed study outlining this.
Other concerns can be early deterioration of pillows, under-side of the cover and plastic materials that ozone can break down prematurely. High chlorine levels can cause the same concerns though…
Ozone is often over sold though I do believe it has some benefits. I’ve never had ozone, use our spa 5 days a week, filter 4 hours per day, and have 1 25sq ft filter and yet the water quality has always been fantastic. Would 4 filters, ozone and 24 hour filtration improve that? I don’t think so either… :-/
Post by: Vinny on March 12, 2005, 09:06:45 pm
Wilson,
It might have been me. I'm not in the hot tub industry, I'm not a dealer but I am a techie! Please note the info I state is based on what I've read from articles and whatever little information I could find on the subject of ozone.
Here in the US, about 5 years ago the FDA issued a warning regarding the possible health problems with air cleaners that emit ozone. There are 2 types of air cleaners that I know of that make ozone - a full house electrostatic air cleaner (Honeywell here in the US is the major manufacturer) and the room type air cleaner (Ionic Breeze - no fans or filters). Certain levels of ozone can cause illness as per the FDA.
We also get ozone alerts when the air quality is poor. The advisory is to stay indoors as much as possible.
What does this have to do with ozone in tubs? Along with what Steve said, my opinion is that IF a tub doesn't use all the ozone (most tubs probably don't), the gas is collected at the water surface and if your sensitive it could cause problems. As per Dr. Spa, ozone is heavier than air so it would fill the cavity between the cover and water.  I would imagine that after it filled the cavity the continuous adding of ozone could spill out into a closed room.
With that said - I am going to get ozone on my tub and there are probably thousands of owners who have tubs with ozone without any problems. The tub I'm getting will only be running ozone about 8 hours a day and I figured that I can always disconnect it if need be.
Hope this helps!
Post by: wilson on March 12, 2005, 10:43:06 pm
Thanks Steve and  Vinny for your replies.
4/5 members of this family have asthma...so it sounds like we'll be staying clear of an ozonator  - and/or I'll add this to my list of secondary research ie., after I first figure out which tub I want!!!!  The learinig curve keeps getting steeper!!!!
Wilson
Post by: Vinny on March 13, 2005, 09:40:38 am
Wilson,
I have a pool and keep it sanitized entirely with chlorine. Ozone is considered a joke in the residential pool world. As Steve said, you can keep your tub clean and safe without it. As long as you keep up with the sanitation and shock - you should be fine. Go to Doc's site: rhtubs.com and look under the forum FAQ section for the info I suggested to Wade.
If you really want ozone - look at the tubs that have the "better" ozone systems as mentioned here. One manufacturer that isn't mentioned is Artesian, they have a upgrade to their ozone system that does what D1 and Arctic does. I believe this is something that can't be added later on if you decide, although I've been to the Del Ozone and they do have a mixing/degassing chamber that they sell as an add on unit - I have no idea where it goes - I would imagine you want it toward the end of the run.
As far as filtration, in a pool you only need to turn the water over 1x a day; I'm not sure how often in a spa. It sounds like Steve doesn't have a circ pump and uses his pump #1 on low 4 hours a day for a filtering cycle. If you find a spa with a circ pump, the therapy pump filter cycle will be shorter if at all. If you buy an Artesian that has a circ pump, the filter cycle controls the ozone time.
Good luck!
Post by: tony on March 13, 2005, 09:55:17 am
I've owned my spa going on three years now.  Over that time period I have had issues with my ozonator check valve.  It has failed and been replaced maybe five times.  Not a big deal, but can be annoying.  The last time I tried a HotSprings check valve to see if it would make any difference.  Well, after about six months, the check valve has failed.  How do I know it has failed...one is the lack of telltale bubbles, but two is the deterioration of my water quality and the more attention (and chemicals) I have to give the spa.  This has happened every time I have had this problem.  I don't know exactly what ozone does in a spa, but my experience has been that it definitely does something.
