Original => Hot Tub Forum => Topic started by: stevemokay on July 15, 2000, 03:30:15 pm
Title: used hot tubs
Post by: stevemokay on July 15, 2000, 03:30:15 pm
am thinking about buying a used tub.
what tips can anyone give me.
a friend has a 6 year old cal spa, 7X7.
any suggestions?
thanx
Title: Re:used hot tubs
Post by: Spa Tech on July 15, 2000, 05:04:54 pm
Tips on looking over that used Cal Spa--
-Check to see if its fully foamed on the underside...Full insulation was an option and did not come standard. Still doesnt.
-Pull the filters on the tub. A tub that size probably has two... one up in a fitting on the tub side and the other located in a pressure fitting in the motor compartment. If both of these are very dirty-reconsider. Clogged filters generally force most of the water throught the filter bypass and sedimentation and debris can harm the jet pump/s.
Basic test to see if they are bad filters-Place them in the tub to see if they float...If they sink ask to have them replaced if youre buying the tub.
-Check the motor compartment floor- Its usually plywood on a Cal Spa- Look for moisture and rot... both are signs of leakage.
-Look for white powdery residure on the equipment. This is a sign of hard water [calcification] or a possible hypersanitation problem. If it is present there could be more problems that you cant see...like below.
-Run the spa-The jet pump should run smoothly-If it sounds like its pumping gravel and not water its time for new bearings and a shaft seal...Make sure they run it hot for you so you can see it heats.
-Ask the "friend" if delivery is included in sale price. If not- look up a dealer that moves spas. Unless youve done it before dont experiment...better to pay someone to move it professionally that to get hurt or break the spa
Happy Hot Tubbin'
Post by: SpaSalesMan on July 15, 2000, 05:06:59 pm
buying a used spa can be difficult if you dont know how well the water was maintained.  Water causes the problems with spas and poor water chemistry can kill a spa.  Does it have ozone? when was the bulb replaced, do you know what repairs have been made? that brand is not known for lasting much longer than six years and I wouldnt buy it for more than $500.00-$750.00 but you can if you want..
Title: Re: used hot tubs
Post by: Chas on February 26, 2005, 05:34:35 pm
Another oldy-but-goody.
Post by: Spa_Tech on February 26, 2005, 10:11:19 pm
Geeze, Chas, you dredge up a simple 5 year old post and make me feel like I dont have anything better to do and feel like an old geezer with four words...Promise me you wont send me any Birthday cards, Okay? ;D
Post by: Chas on February 27, 2005, 01:44:25 am
A birthday card I could handle. Its the candles for your birthday cake I don't know if I could afford....
