Original => Hot Tub Forum => Topic started by: obi wan on February 11, 2005, 08:55:49 am
Title: ozonaters?
Post by: obi wan on February 11, 2005, 08:55:49 am
i have looked at several tubs recently, jacuzzi, HS, caldera, masters, and marquis. all but the jacuzzi are including an ozonater with the purchase and even use it as a great selling feature. jacuzzi will put one in for $199 but didn't seem to care either way from what i read,l the CD is the best type, or is it?
is this something that must be replaced every couple of years, or longer?
are they really beneficial in the long run?or is this more hype than functionality.
i want this $LARGE$ purchase to be a long term investment, and if the ozonater is very beneficial then i can factor the costs into cost of maintenance.
Title: Re: ozonaters?
Post by: hottubber on February 11, 2005, 09:09:28 am
kent,
The ozone systems that are used in MOST spas are an after market item. Whether the dealer includes it in the package or not, is not the question. Warrantees on these aftermarket systems usually are only one or two years. I believe that Marquis utilizes an ozone system that is warranteed for 5 years. Because it is factory installed. That is an Ultraviolet system. Most of the new aftermarket systems are Corona Discharge, this type of ozonator produces more than the UV bulb and it is supposed to last much longer and at a higher level of output.
We include ozone in every spa sale. It is a nice feature for those people that want to reduce the chemical need in their spas. Ozone will reduce chemical need by about 70%.
Good luck ;D
Post by: Steve on February 11, 2005, 10:03:35 am
kent,
Good luck ;D
I was with ya right up until the last paragraph. In all the years I've been around spas, I've heard ozone will reduce chemical usage by ____%. Mostly anything between 30 - 90%. I'm not sure where these numbers come from or how they're generated. Can you tell me how you came to that number tubber?
Ozone IS a chemical is it not? ??? :)
I believe there's benefits to ozone but it's aways been unclear just how much it reduces chlorine use.
Post by: HotTubMan on February 11, 2005, 10:27:03 am
I feel that ozone savings are often mirepresented. My guesstimate(since therte is no real data) is no more than 30%.
That said, the cost of new bulbs or chips should wash that saving away.
I do not present ozone as a money saver at all. It is a maintenance saver. It allows you to maintain a lower ppm of cl/br. Save money? I dont think so.
And yes it is a chemical, but we are all composed of chemicals. I find chemical to be a word most consumers equate with "anything I put in my spa besides people"
Post by: Spatech_tuo on February 11, 2005, 11:12:16 am
Bingo. I simply say it will help keep the water cleaner/clearer, which means a lot if you've ever seen the frustration a person has when their water quality battle isn't going well. I have seen many spas with and without ozone and I'm sold on ozone as it seems like the people without have water quality issues far more often. You will use less chlorine but I don't like them to push this point and see people go too low. In the end, if it makes maintenance easier and keeps the water cleaner its worth it IMO.
I'm certainly more a fan of the CD type due to the added ozone (assuming the system is well designed and can handle it). You also need to know if your CD type needs a chip change (some do, some don't) and how much and we all know the UV needs a bulb change about every 1½ yrs so you should find out what your maintenance costs would be.
Post by: poolboy34 on February 11, 2005, 11:17:55 am
Ozone is an oxidizer.  It can reduce the amount of sanitizer and shock you need to maintain your tub's water.  Now granted this all depends on how often and how many people on average are going to be using the spa.  Overall i would say that anything that can reduce the amount of sanitizer and shock you need to put into a spa on a regular basis is a good thing.  Also there are manufacturers that include a factory installed water mgmt system in their spas complete with ozonators (D-1(Reflections & Bay Series), Marquis, Caldera(utopia series), and saratoga to name a few.  All of these manufacturers cover their ozonators under warranty.
Bottom line is that anything that makes maintaining a spa easier is a good thing.
Jason,
Store manager for a D-1 & caldera Dealer
Post by: Mendocino101 on February 11, 2005, 01:41:46 pm
One thing about the UV and Corona discharge...
Marquis does use a UV....but unlike I think most or perhaps even all UV types....It  uses a Plasma cell instead of a ballast...it is the ballast that fails and with each use produces less and less ozone....by using the Plasma cell they have found that it puts out the same amount ozone from day one to day 2000 ( about 7 years ) in their testing....and requires no maintenance
Title: Re: ozonators?
Post by: Dr. Spa™ Ret. on February 11, 2005, 02:18:07 pm
Ozone is misunderstood more than just about anything else.
Ozone is just an oxidizer and will NOT sanitize or kill any bacteria. NONE.
Chlorine is both an oxidizer AND a sanitizer. HOWEVER, before it can sanitize anything it will FIRST oxidize everything in the water. If not enough chlorine is used it can get used up oxidizing all the dead organic stuff before it has a chance to sanitize (kill) anything.
Ozone, being an oxidizer, can take care of some/much of the required oxidizing. This would reduce the amount of chlorine needed to reach the desired 3ppm. YOU STILL NEED TO ATTAIN 3ppm OF CHLORINE for proper sanitizing.Additionally, ozone will break down combined chlorine, releasing the chlorine back to an effective state. Since combined chlorine has no oxidizing or sanitizing ability, AND actually consume more chlorine, this "could" reduce the required amount of chlorine needed to ACHIEVE 3ppm.
Finally, there has never, Never, NEVER been a properly conducted, peer reviewed study (released to the public) proving that ozone has ANY benefit to a spa.
I should also not, as Steve says, ozone IS a chemical. I've come across a fair number of people that are HIGHLY sensitive to it and have had anything from breathing problems to extreme asthma attacks associated with breathing small amounts of off gassing from their spa.
Post by: Gary on February 11, 2005, 02:38:47 pm
Are ozonators necessary? No, but they will help keep the cleaner from oxidation. But the has to be engineered for an ozone if not they are a waste of money. The must have a contact/mixing chamber to keep the ozone in solution or it just get wasted.
So a better question is does the spa you are looking at have a proper size contact chamber per the flow of water.
Also the solid state ozonators are the way to go. Ballast fired ones have a short life, Cd ones require maintenance. Solid State (sometimes called Plasma)last a long time and you do nothing to it ever.
Post by: stuart on February 11, 2005, 03:11:32 pm
Gary,
What a great post! This is one of your better...I didn't know you still had it in you after all these years!! ;D
Post by: steve771 on February 11, 2005, 03:48:13 pm
What would be the qualifications of a system "being well designed and able to handle it"?  I have a UV type installed now and was thinking of changing to a CD type when the bulb needs replacing.  ???
Post by: HotTubMan on February 11, 2005, 04:11:49 pm
Some will argue this point, but a well designed ozone system has a longer tube leading from the mazzei injector to the jet in the spa.
The mazziei injector is the first (or only) contact chamber. Some makes include a second contact/de-gasing chamber.
It is actually easier to explain a poorly designed ozone system. A poorly designed system only allows the ozone to mix with the water for 5-10 seconds before it is injected into the spa. The ozone bubble then makes its way to the surface and becomes and airborn gas. Once is airborn, ozone does nothing for your spa water and may do damage to your cover/pillows.
Post by: Dr. Spa™ Ret. on February 11, 2005, 04:53:58 pm
*raising hand and waving it wildly in the air*
I'll argue it, I'LL ARGUE IT.
Once the water leaves the injector, or "mixing" chamber for that matter, the little bubbles of ozone quickly rise to the top of the pipe, leaving a pocket of air in the top of the pipe............ kinda like the pocket of air above the water of a spa and beneath the cover  ;D
A longer pipe gives you.................................. just a longer pocket of ozonated air sitting on top of a longer pipe full of water.
Additionally, the slower the water is moving through the pipe, the quicker the lil bubbles will rise to the top of the pipe.
I'm still waiting to see the properly preformed, properly documented and peer reviewed study  ???
Post by: HotTubMan on February 11, 2005, 04:56:29 pm
You too?
Post by: Mendocino101 on February 11, 2005, 04:58:46 pm
It is my understanding....that Marquis which uses  "Hi Flow" for filtering initially thought that a 25 second contact chamber was the way to go..but after testing felt they achieved better results shortening the chamber to I think about 18 seconds....
Post by: HotTubMan on February 11, 2005, 05:02:05 pm
So would you agree that a second mixing chamber like the one found in a D-1(and other brands, I just know the D-1 sys better) would be beneficial?
Post by: empolgation on February 11, 2005, 05:49:14 pm
*raising hand and waving it in the pocket of ozonated air*
so I guess a reasonable question would be... is there a benefit acheived from the ozone's contact with the surface of the moving water in the pipe?  and could there be a detriment to the ozone contact with the pipe?
I am still a little unclear as to how the ozone becomes aqueous but I continue to wonder what's the difference between tiny ozone bubbles from an injector and ozone pockets in a pipe (aside from the obvious difference in surface area ratio)? Seems to me if you believe that one has a benefit than the other must as well, albeit most likely quantifiably less.
Of course without that "properly conducted, peer reviewed study" this is only food for the monster.
An often times overlooked "benefit" of ozone is that it can activate bromine.
Post by: empolgation on February 11, 2005, 05:51:23 pm
What is that second mixing chamber? Another injector? Some more pipe? a...?
Post by: hottubber on February 11, 2005, 06:18:31 pm
Just like my x, puts out for 7 years, now nothing... ;D
Post by: Chas on February 11, 2005, 06:48:02 pm
Well, just so you know: HotSpring uses the plasma type generator, that's the one which lasts about ten years and needs no care.
They also use a simple flex tube with a gentle spiral built into it. This tends to keep the water moving in such a way that the bubbles don't work themselves to the top as much. How much? I haven't shoved a mini cam into the pipe to observe it in operation, but it does spew forth bubbles which are still tiny after going through about twelve feet of 'contact chamber,' indicating that it does work as planned.
Finally, I have learned by first-hand experience that some people can tell when their ozone system is suddenly disconnected or stops operating, and that tells me that most folks can tell a difference. How? Perhaps they smell it, perhaps they notice needing more chlorine than usual, or perhaps the thing goes completely cloudy on them and they check into it.
I had a tub in my backyard for over half a year - and we found out it never had the ozone generator installed. The bubbles were there because the injector got installed, but they were just air. I only had one time the tub 'went south' during that time, but I have years of experience and I think I was putting in more dichlor as needed to compensate without really knowing it. I did have records which showed I took home more dichlor than the year before, but lots of other things could account for that.
But the cover and pillows were in far better shape that my floor models which had ozone for the same amount of time.
All that to say this: a good ozone system does make it easier to own your tub. It is not a must, but it can give you more fudge factor in applying sanitizer because it does oxidize some of the organic matter so the sanitizer doesn't have to. And on a tub with constant circulation, it goes in all the time. This is really a nice backup for vacation time.
Post by: Mendocino101 on February 11, 2005, 07:02:35 pm
Chas....
Where does the generator come into play and what is its function...
Post by: empolgation on February 11, 2005, 07:02:50 pm
I am one of those people. I had a cloudy tub and could not figure out why....  After lots of troubleshooting I found that the ozonator was not working (plasma style was not lighting up). I got the ozonator working... a little more than a day later water was no longer cloudy.
Post by: Chas on February 11, 2005, 07:50:00 pm
The Generator is the electric/electronic item which produces the ozone. There are a few types in common use: Ultra Violet (or UV), CD and Plasma. The UV has a light bulb which does the work, and only lasts about two or three years. It may still light up, but should be replaced at that time.
The CD (Corona Discharge) uses a solid-state electronic system to create a corona (high voltage) discharge which creates the ozone - just like a lightning storm can and does. The less-expensive CD units have a small chip or chamber which needs to be replaced about 9000 hours of operation - once a year if run constantly. The Plasma units - or high end CD units for that matter - utilize a much larger chamber and a much larger power supply. As a result, they can go ten years without changing anything. Once they stop working, you get a new one. They are usually the most expensive of the options.
Once the Ozone is generated, it must be mixed into the water somehow. Most tubs seem to use an injector - the most common injector is made by Mazzei. The injector is a venturi which uses the water movement to create a vacuuum which draws the ozone into the waterstream. Other tub makers put a small hydro jet or designate one of the regular spa jets and use the air inlet to draw the ozone into the tub, but there is a reason the Mazzei system works better and I'll get to it next:
Mixing chamber. This can be anything from a long flexible tube (ten to twelve feet long, wrapped around the foot area or somehow hidden in the insulated part of the tub) to a convoluted system of tanks and chambers which all have one job: extend the amount of time the ozone and the water are in contact. Because of this, some of them are called "contact chambers."
The mixing or contact chamber is a must because the ozone will simply escape ('gas off') and do no good whatsoever if it is not forced into contact with the water for as long as possible. If the ozone generator puts out a lot of ozone, and it is allowed to simply 'gas off,' it will not help with water chemistry, but will burn the underside of the cover and/or pillows. It can also bother some people's lungs if it creates a big ozone cloud above the water.
So choose your tub carefully, but don't let this system be a deciding factor. You can run a tub quite will without an ozone system, and an ozone system is not a free ride: you still need to manage your pH and TA, and you must keep a small residual of sanitizer in the water, or at least do regular shocks with a sanitizer and keep MPS or similar going in all the time.
But if you are looking a tub, and want to know if the ozone system is going to make a difference or not, find out if it is CD or UV. If UV - pass. If CD, find out if it needs to have the chip or chamber changed every year. If so, pass - or ask your dealer to include this service for the first two years. Ask about the contact chamber - if it simply blows the ozone into the tub from a mini-jet or regular jet, pass. If it has any type of contact chamber, you're good to go.
Post by: HotTubMan on February 11, 2005, 08:11:24 pm
Ill bring the camera into work this weekend. I tried and I just cant describe it well. We have D-1's UltraPure display in the store. With that tool I can describe it to you.
Post by: Mendocino101 on February 11, 2005, 08:35:40 pm
Chas...
there are those who would differ with you and suggest that it is not the bulb that goes out in the UV type but it is in fact the ballast....that the bulbs will last longer than 7 years with no loss in ability to produce ozone.....when used in conjunction with a plasma cell....
Post by: Dr. Spa™ Ret. on February 11, 2005, 09:49:28 pm
I don't really know... as I say, show me real test results. At 104 degrees, ozone gas breaks down in what? 2 seconds? What about a 10' mixing chamber?
As I understand it, you really only get good absorption of ozone into water if it's injected at 2 atmospheres of pressure.
Title: Re: ozonator?
Post by: Dr. Spa™ Ret. on February 11, 2005, 09:56:49 pm
"is there a benefit achieved from the ozone's contact with the surface of the moving water in the pipe?"
Yes, but it's SO small it's unmeasurable...... so it might as well be "no"
"and could there be a detriment to the ozone contact with the pipe?"
Possibly, but I think the rest of the spa will be long gone before the effects would be noticeable.
"I am still a little unclear as to how the ozone becomes aqueous"
Just like any gas, under the right conditions it's absorbed into the liquid. Kinda like oxygen into water so fish can survive.
" but I continue to wonder what's the difference between tiny ozone bubbles from an injector and ozone pockets in a pipe (aside from the obvious difference in surface area ratio)?"
It's the surface ration. The tinyer the bubbles the greater the absorption capability.
"An often times overlooked "benefit" of ozone is that it can activate bromine."
ABSOLUTELY!
Post by: empolgation on February 11, 2005, 11:33:45 pm
Chas... a fabulous review of spa ozonation - thanks!
HTM... much obliged for a photo, I've been trying to get a better understanding of D1's system for a while know.
Post by: empolgation on February 11, 2005, 11:43:43 pm
I'll wait to peruse the "properly conducted, peer reviewed study" before I confer ;D
Just like any gas, under the right aonditimns it's absorbed into the liquid. Kinda like oxygen into water so fish can survive.
That's about what I know although oxygen can easily be absorbed in water at 1 atm or less. I am questioning ozone's ability to oxidize upon being trapped in a "pocket of ozonated air", of unknown pressure, for a long (possibly indefinite) period of time compared to being injected (likely at 2 atm?) and off-gas relatively shortly thereafter.
Many thanks to y'all for sharing your ozone knowledge, every bit helps to gain a better understanding of it's role in spatopia!
Post by: drewdad on February 14, 2005, 09:30:43 pm
WEIRD QUESTION.....
stopped in a d-1 dealer today, and on the topic of ozonaters, this guy says that d-1 has the best type, a uv???
he says some of the lower end models have the "cd" ozonaters in them, but overall d-1 has more power and better ozonation than any one else.
am i not understanding most of the threads in this post, or is this dealer delusional??
overall seems to be nice product, but a little pricey....($9-12K) i have tested several brands now and am pretty much set on the caldera niagra, but wanted to be sure before spending this kind of money.
i have learned alot of the right questons to ask here and i appriciate the input alot
same store has la west tubs also. like the looks of the H.E.E.T model but havent seen much about them here.
where(approx) does la west fit into the food chain as far as quality? any one??
Post by: Mendocino101 on February 14, 2005, 09:48:38 pm
I think that there are some owners who have been very happy with them...As there are with most spas....Within the industry itself I think it is considered a mid level spa at best...Warranty support seems to be the single biggest reason that separates manufactures from one another and from talking to former LA dealers that is where they fell short.....
