Original => Hot Tub Forum => Topic started by: dakris on February 10, 2005, 06:00:36 pm
I've got a chairman II 2004. Wondering if there are two jets that provide the circulation in heating. On the side under the lounge I can feel one strong jet pumping out hot water and one weak jet. Are their two jets pumping out hot water or just one?
Thanks for the responses.
You will feel hot water coming from both, the smaller one is the main circ jet, the larger one is an over flow of sorts.
That makes sense. The jet towards the feet of the lounger puts out a good flow of water. The jet towards the head of the lounger puts out just a little bit of water.
Sounds like everything is working correctly then.
Thanks for you help.
