Original => Hot Tub Forum => Topic started by: double_track on January 01, 2005, 07:52:16 pm
I've had my D1 diplomat for 1 month now and have used it almost every day. I'm starting to get foaming problems and noticed cloudy water today. I'm going to drain it but I have a few questions. Do I turn the power off or just use standby? Is it ok to let it drain overnight and clean it when it's empty or should I clean right after it drains? What should I use to clean the tub before I refill and what should I add when it's full again? I would appreciate any answers and additional advice you knowledgeable folks might have, thanks, Doubletrack
I did my first drain after 30 days and it went very easy. The water was out in 45 minutes or so and after a brief towelling it took less than 2 hours to fill it .I drained with a small submersible pump attached to my pool vac hose.The new water solved all my foam problems and questions and it has'nt reappeared yet . Good Luck....bobhol
I have a disconnect box about 6 ft. from the spa ,so I killed power from there....bobhol
Most definitely turn the power off for the drain. Draining times vary by method, I too used a submerible pump and it was done in less than an hour, using the drain plug on the tub could take a bit longer.
Cleaning the tub, depends on how dirty it is. My first refill I used a damp cloth and then used the gloss product from Leisure time. Unless you have a scum line or such you may not have to do anything this time around.
Your dealer should have given you steps to do after the tub is filled?? I put in MetalGon, adjust ph, alk, and cholrine and then wait for the temp to get just right. All in all my refill took a couple of hours.
I'm sure one the resident experts will chime in and correct me if I've misspoke. ;D
