Original => Hot Tub Forum => Topic started by: e23 on November 22, 2004, 08:24:43 pm
Title: Towel Warmer ??
Post by: e23 on November 22, 2004, 08:24:43 pm
ok.....after you are done laughing...my wife saw somewhere online....a towel warmer. It was not one of the big $2000 models but rather a smaller, almost mini refrigerator type.
Living in the northeast, she thought it might be nice to have on those cold nights...Sept thru June...lol.
Any ideas where to start looking and any opinions on them if you have one....towel warmer that is....:)
Thanks in advance for the help.
Eric
Title: Re: Towel Warmer ??
Post by: IBinit4fun on November 22, 2004, 08:36:10 pm
I've heard someone here mention warming them in a dryer and keeping them in a styrofoam cooler by the tub. Can put in robes also. There is also a warmer you can put in your microwave and then the cooler to keep towels and robe warm longer. Not my idea, but seemed like a good one to pass along.
Post by: wmccall on November 22, 2004, 09:25:45 pm
I believe Walmart has hot food bags that are sizable and made of foil.  This might work.
Post by: Chas on November 22, 2004, 09:49:53 pm
(http://images.amazon.com/images/P/B0001A3KHY.01-A1AW2BPC9A8XPV.LZZZZZZZ.jpg)
Features:
   * Warms Towels
   * Heats Towels
   * Holds 24 Towels
Product Description
HotCabi is a towel warmer cabinet that keeps towels a constant 170 degrees for refreshing, hygienic treatments. It includes a built-in UV lamp sterilizer, it holds 24 towels. 17.75"h x 12"w x 13"l
Amazon.com
ASIN: B0001A3KHY
Date first available at Amazon: December 18, 2000
The "holds 24 towels is a bit of a stretch.
Post by: Dr. Spa™ Ret. on November 22, 2004, 10:22:13 pm
That's 24 facial towels, not bath towels
Post by: Chas on November 22, 2004, 11:04:39 pm
Ah. Small facial towels at that.....
Post by: Dr. Spa™ Ret. on November 23, 2004, 12:34:39 am
I'm thinking, single ply wash cloths........... think bandana
How many days do you think it takes to get to 170 degrees?
Post by: Tman122 on November 23, 2004, 06:26:03 am
I have a double cedar box with insulation between the layers and a hinged top with a nifty handle. Inside I have a 120 watt rough service light bulb in a fixture with a switch on the outside. A metal screen seperates the bulb on the bottom from the cavity on the top. It's 3x2x2 that's 3 foot long by 2 foot high by 2 foot deep. It's finished to match my deck and makes a great bench for slippin on your shoes. It holds 2 robes and 2 towels and the friends that come over to soak always get screwed.
Post by: BobRex on November 23, 2004, 09:58:21 am
My wife just got a Bed, Bath, and Beyond catalog that showed a towel warmer rack.  Looks like it stands maybe 3ft high, has a tube that snakes around to create a couple of levels and plugs into a 110 outlet.
So, what if you took one of these, put it into a tall rubbermade (or similar) storage cabinet, running the wire outside.  Should make a decent and portable warming cabana, no?
Post by: Chas on November 23, 2004, 10:11:45 am
I have a double cedar box with insulation between the layers and a hinged top with a nifty handle. Inside I have a 120 watt rough service light bulb in a fixture with a switch on the outside. A metal screen seperates the bulb on the bottom from the cavity on the top. It's 3x2x2 that's 3 foot long by 2 foot high by 2 foot deep. It's finished to match my deck and makes a great bench for slippin on your shoes. It holds 2 robes and 2 towels.
This sounds like a very creative answer to the problem !!
Post by: Drewski on November 23, 2004, 01:55:47 pm
As I said in the last thread on this topic, I'm thinking crank the tub temp to 104, stay in 30-45 minutes and you WON'T need a warm towel!
Drewski
Post by: Jason_r on November 23, 2004, 03:32:48 pm
Do you think that the towel warmer is full foam?
Post by: wmccall on November 23, 2004, 03:49:57 pm
I think Thermopane is more likely, I doubt it could hold 24 towels if it was full foam.
