Original => Hot Tub Forum => Topic started by: wmccall on November 02, 2004, 10:59:18 am
Title: Noisy GFCI
Post by: wmccall on November 02, 2004, 10:59:18 am
We had a power failure Sunday night.  Since it came back I 've noticed by GFCI- disconnect box is humming and in the last 24 hours has begun to hum reallly loudly. Thoughts?
Title: Re: Noisy GFCI
Post by: stuart on November 02, 2004, 11:02:26 am
Have you tried to shut it all of the way off and back on again? You might not have gotten a good lock on both sides of the breaker when you turned it on. Otherwise it's probably time to change it.
Post by: Drewski on November 02, 2004, 04:45:22 pm
Uhhh, don't get in your spa?
Sure would like to see you make 2000...
Drewski
:D
Post by: HotTubMan on November 02, 2004, 05:17:35 pm
Better yet, throw your neighbors cat in and if it starts crackling & popping you will know there is a problem with your gfci and as a bonus,  Krispy Kitty is gooood eatin'.
If there is a line, I'm sure you didn't see it as you crossed it.
Post by: salesdvl on November 02, 2004, 05:56:35 pm
I just got a call from Green Peace and they didn't appreciate the Deep Fried Cat comment I said, so I deleted it.  I don't have anything personally against animals.  I eat Starkist tuna cuz they dont catch dolphins in their nets.
IM SORRY.  :'(
Post by: Chas on November 02, 2004, 06:07:25 pm
Mr. WMcCall - Sir,
If I recall correctly, your box was made by Connecticut Swith and Electric, which oddly enough is in Washington State.  I would call their tech support. They have east coast hours.  This brand of contactor has failed quite a bit and they may have run out of replacements.  Seems to me that yours has lasted quite a bit longer than most of the others, but even though you have made it through the warranty they might be talked into sending you a replacement free of charge, if you mention my name.  The bad part is they will have to send you a non-exact replacement so you'll l have to drill a couple of holes and crimp on a couple of spade lugs, but they are speaking your language, "FREE."
Post by: Brewman on November 02, 2004, 07:30:06 pm
I loved the "sir" part.   The Mr. part was nice, too.
You're really trying not to get on the bad side of the new moderator, aren't you Chas?! ;D ;D
Post by: Chas on November 02, 2004, 09:13:19 pm
Too obvious, ya think?
Post by: HotTubMan on November 02, 2004, 09:43:35 pm
IM SORRY.  :'(
Greenpeice acknowledges your withdrawal and has cancelled tommorrows scheduled picket outside of your store.
HTM
Post by: wmccall on November 03, 2004, 08:08:34 am
Mr. WMcCall - Sir,
You have a relay in that box, and it may settle down and shut up if you reset it a few times. First - and this is important - hit the "test" button to be sure that your GFI protection is intact. If so, try testing/resetting several times - listening each time until the relay is quiet. If it doesn't  go silent by time you have reset a dozen times, call the tech.
I'll take a look at that tonight.  Two days in the hospital and trying to get caught up with two jobs and waiting in line 2 hours to vote has me a bit overwhelmed this week.
Post by: salesdvl on November 03, 2004, 08:51:17 am
WMC, just remember that no matter how hectic it is when you leave the hospital it is always better than the alternative.   ;)
Post by: wmccall on November 08, 2004, 09:15:50 am
Ok, I did find out that the contactor coil had some moisture in it and was rusting.  I bought the whole GFCI/disconnect from Spa Depot.com back in Feb '03.   The box was made by Connecticut Swith and Electic, which oddly enough is in Washington State.   I called at 9am eastern today, just to see if their tech support  had east coast hours, which they did.  Apparently this brand of contactor has failed quite a bit and they have run out of replacements.  Mine lasted quite a bit longer than most of the others, so even though I made it through the warranty they are sending me a replacement free of charge.  The bad part is they have to send me a non-exact replacement and I will have to drill a couple of holes and crimp on a couple of spade lugs, but they are speaking my language, FREE.
Post by: windsurfdog on November 08, 2004, 09:38:13 am
Though it may be a bit inconvenient at times, this certainly makes a case for housing the GFCI in conditioned space, a la the electrical panel.
Glad you got some excellent service, TERMINATOR.....er......I mean, wm..... ;D
Post by: newtotubbing on November 08, 2004, 10:26:07 am
Please make sure that you can use spade conncetors on this type of service.  I have never seen crimp on conncters used in home wiring.  I use them on my boat, which is required by the USCG but have never seen them used in a home.
Just a thought.
Jonathan
Post by: Chas on November 08, 2004, 10:36:10 am
Just a thought.
Jonathan
YES - required when you put a multi-strand wire into a screw terminal. Solder type connector is best for high-amperage circuits, but nobody seems to bother any more these days...
Post by: wmccall on November 09, 2004, 10:55:58 am
OK Chas, I'm looking for a reason to come to California, and if it is to pour jello in your spa then so be it!    The fact that my hospital stay was brain related,  I reread your earlier post and it had me totally confused till I saw  "« Last Edit: Nov 8th, 2004, 10:33am by Chas »
Don't mess with a 45 year old Alzheimer patient!
Post by: Chas on November 09, 2004, 11:52:53 am
Mr. Moderator Sir,
I bad. Sorry. Just couldn't resist !!!
Where can I send your new Hot Springs spa to? Can I install it myself?
Post by: Lori on November 09, 2004, 12:33:50 pm
I thought I told HotTubWoman to be careful when giving you an attitude adjustment!  LOL!!!   ;)
Maybe it was the daughter bringing the boyfriend home for the first time.  I know how you Dad's get!  LOL!!!   ;)
Post by: salesdvl on November 09, 2004, 01:36:06 pm
Hey, the best thing about having Alzheimers is that you get to meet all new people everyday!  :)
(Think of it as a silver lining.)
Post by: wmccall on November 09, 2004, 02:44:11 pm
On a serious note, I would be worthless without the first and lucky to still have the 2nd.
Now if UPS will just get that part here!
Post by: wmccall on November 09, 2004, 02:45:46 pm
Yea, but being a comedian and a story teller, you get tired of hearing, "You told us that already"  My new motto, "Read a book again for the first time!"
Post by: Lori on November 09, 2004, 03:14:55 pm
Just had to take the opportunity for the opening you gave!  You don't leave me wide open very often.
I know you adore those two women in your life, as well you should!!!   ;)
Post by: salesdvl on November 09, 2004, 03:29:12 pm
I get that alot too.  My kids have labeled me the "King of Worthless Information".  I figure I'll get even withthem when they need a "phone a friend"   ;)
Post by: Chas on November 09, 2004, 09:59:01 pm
Mr. Moderator Sir,
NOW WAIT JUST A DARN MINUTE !!!  :o :o :o :o
Post by: wmccall on November 20, 2004, 05:42:25 pm
Ok, situation resolved, through a round about way. A week later the new contactor arrived. The company that made the panel said they didn't have any more of that type available so they would send me a similar one, but I might have to replace some lugs that don't match. I considered that a little more than I wanted to do so I went through a week of turning the spa off at night so my daughter could sleep amd turning it back on in the morning so it would be hot for our nightly soak.  I asked the maintenance guy at work if he would change it out for me, he OWES ME BIG TIME. (Can you say viruses removed, wireless network installed?)  ::)
He said he would come at noon.  Its almost 1/2 time and OSU is tied with Michigan at 14.  At halftime I go out and look and see that they sent the exact same contactor. I can do this myself!
Turned off power, replaced the contactor, applied power, the Buckeyes are beating the Wolverines 27-14!!!!!  The contactor is dead, doesn't work at all.  I triple check everything and then head off to Home Depot.
Fortunately, they have a 50amp Spa GFCI disconnect only $100, that settles it.  It took me 90 minutes to tear the old one out, put this one in. The wires mount in different locations than the old box so I had to get the wire stretcher out and get everything in. Turned it on, it trips right away.  I'm feeling better knowing Ohio State has now beaten those hated Wolverines 3 out of 4 years.
I double checked and found out I had one wire in the wrong place. I found out where is was supposed to go. I saw I had to get the wire stretcher out and evolve a 3rd hand to get it there, but somehow I did.  Powered it up, it was still at 100F,  Reprgrammed everything and in a couple of hours we will be soaking tonight while yelling out to the neighborhood   !!!!!!!!OH!!!!!!!!!
to which someone will respond   !!!!!!!!!IO!!!!!!!!!
For the Wolverine fans heading home, let me give you directions.   North till you smell it and then west till you step in it!!!!!!!!!!!!!!!!!!!!!!!
(http://www.1460thefan.com/images/front/OSU-Logo-perfect-color-(1).gif)
Post by: Lori on November 20, 2004, 08:17:04 pm
Glad you got it resolved!!!  :P
So, you really are a Buckeye fan, aren't you?? ;D
I'm sending my dad to the Big 12 Championship Game in Kansas City (lets hope Oklahoma can win this year...lol)!  That is his Christmas (a little early) but he will enjoy it so much!  I'm babysitting the dogs, too!!!
Good thing about a boss who has season tickets (with guaranteed championship tickets) who has to be in NYC for tha weekend!!!
Post by: wmccall on November 21, 2004, 10:12:05 am
It was nice having a peacful quiet soak last night, the noisy contactor really did take away from what is/should be relaxation.
