Original => Hot Tub Forum => Topic started by: taraka on October 26, 2004, 04:06:07 pm
Title: Sun Purity
Post by: taraka on October 26, 2004, 04:06:07 pm
 Anyone Sundance/ Sweetwater spa owner have the Sun Purity  purifier in there basket?
What do you use for maintance?  MPS or Dichlor??  What do you use to shock?
How much do you use of the chemical?
Title: Re: Sun Purity
Post by: Chris_H on October 26, 2004, 04:13:37 pm
Yes, it should be in the basket.
Chemicals for maintenance, as long as you have ozone:
If it is used once a day or less:  1 ounce of MPS before each use.  1 ounce of Di-chlor on a weekly basis.
If it is being used more than once a day: Add 1 ounce of Di-chlor after each use, and 2 ounces weekly.
Di-chlor is the shock.
Post by: tony on October 27, 2004, 10:07:54 am
I use the Sun Purity cartridge.  I add 1 tsp dichlor per person after use and shock weekly with either 2 tblsp dichlor or 2-3 tblsp non chlorine shock or a combination of both.
Post by: CalicoskiesNC on October 28, 2004, 08:13:15 am
I use the Sunpurity.  We add 1TBL dichlor each evening and shock with 3TBL dichlor every Sunday evening.  Thats all we use, with the exception of 2oz Spa Defender every 2 wks and occasional correction of pH/TA.
