Original => Hot Tub Forum => Topic started by: NinjaDog on September 29, 2019, 09:33:06 pm
Hopefully some old schoolers know how to do these beauties. Appears to be a plastic nut inside, and I'm a little reluctant to just start cranking off the outer white piece with some channel locks.
(https://scontent.fyvr3-1.fna.fbcdn.net/v/t1.0-9/70301516_10156739821487654_3654953173883289600_n.jpg?_nc_cat=108&_nc_oc=AQmyGfFMEUS7dDIP2pjEt9fXxCv1puFLaMcE7MdX3JNKizhMPt_7sD8YfmKnZWk30fi23gxrvzUlTvhj8R4S8E8F&_nc_ht=scontent.fyvr3-1.fna&oh=98845339e534f6a2d6dd5900a6c5cd34&oe=5DF1EEFE)
There is a special wrench that has two nubs on it that fit the two holes and yep, turn it.
The tool is called a (Spanner Wrench) and if you use it a lot there are fixed span models or there are also adjustable spans. You should be able to get one on line do a search or at an automotive store or tool store.
