Original => Hot Tub Forum => Topic started by: rayf01 on July 21, 2018, 02:55:47 am
Hi all, looking for a bit of feedback here.
I bought a home with a tub. After some looking, I elected to do a bit of overhauling and replace the pump/motor which was 8 years old and had some issues. Now, the pump for the old one had a sticker that said 3.5 hp on it. I took it to a pump/motor shop and the guy told me "I always go off the number on the actual impeller", which says 3. So he says it was a 3 hp pump. I had him order me a new one, and of course when I look at the amp ratings the new one is lower and its a 3 hp pump. I am pretty sure my old one is a 3.5 hp. Looking at the specs of both pumps, they both appear to run at the same RPM, 3450/1725
If I install the new 3 hp one, is it going to make a huge difference and lack in jet pressure or do you think a person would even notice it much? Keep in mind I have never used the hot tub before because as soon as I took possession of the house I drained it.
Old pump/motor:
(https://i.imgur.com/sah49ax.jpg)
New pump/motor:
(https://i.imgur.com/6vnsOW8.jpg)
(https://i.imgur.com/LozyCk0.jpg)
You won't notice.
good job.
