Original => Hot Tub Forum => Topic started by: cleyed on June 18, 2018, 09:53:59 pm
Title: 2015 hotspring tub pump runs all the time
Post by: cleyed on June 18, 2018, 09:53:59 pm
I have a 2015 hot spring relay hot tub that has just started to have the pump motor run all the time
 the temperature of the water is above the set rating (set at 99 and the water was at 104 when i shut the power off) is the caused by the pump always running?
 is this caused by the pump relay contacts welding themselves together? if so is there an easy test I can do to determine the cause?
 thank you Cleyed
Title: Re: 2015 hotspring tub pump runs all the time
Post by: Flyonthewall on July 24, 2018, 07:11:10 pm
just to be clear, is it one of the jet pumps that is running all the time?  if so that should be under warranty.  if you are talking circulation pump that can add heat in extreme conditions, and should be running all the time.  summer timer is a mode that shuts it off part of the day, when the tub is struggling to not overheat.
Post by: Hottubguy on July 24, 2018, 08:46:25 pm
Relay is 2 year warranty. You didn’t change filtration settings by mistake did you?
Post by: Sam on July 27, 2018, 01:12:42 pm
Filtration settings are pretty much always the reason for this call.  In a lot of spas it's easy to accidentally change filter cycles to some long time which will also cause the spa to overheat.
