Original => Hot Tub Forum => Topic started by: Botswana on May 31, 2018, 10:17:56 pm
Title: Caldera filter question
Post by: Botswana on May 31, 2018, 10:17:56 pm
Troubleshooting a different problem but I was talking to a tech on the phone today about pump 2 (1 speed) and asked if it ever turned on during filters. He said yes, both pumps run while filtering. I told him that can't be the case because only pump 1 runs at low speed for both of my filter session, which I've confirmed many times. He insisted that can be the case. Is pump 2 supposed to be used at all? 2016 Vanto...
I'm trying to trouble shoot a GFCI nuisamce tripping issue and have disconnected pump 2 which is why the question came up
Title: Re: Caldera filter question
Post by: Jacuzzi Jim on June 01, 2018, 02:26:55 pm
 When its in a filter mode, check with a volt meter and see if there is power where pump 2 hooks up.    Never heard of both pumps running during a cycle.  Did you ask him if it goes through the purge thing or not?
Post by: Botswana on June 01, 2018, 05:42:02 pm
I didn't, because he was insistent that both ran each filter cycle, therefore its a moot point.
Post by: castletonia on June 01, 2018, 06:52:50 pm
As far as I'm aware, only pump 1 runs during the filter cycle.
