Original => Hot Tub Forum => Topic started by: jtd1216 on May 01, 2018, 08:02:17 pm
Title: When you can't wet test...
Post by: jtd1216 on May 01, 2018, 08:02:17 pm
So, I'm in a jam. I decided on a dealer (Hot Spring) who is really great! I'm stuck between two tubs, the Hot Spot Rhythm ($6.4k) and the Limelight Flash ($8.8k). THE PROBLEM is, they only have a Limelight Pulse, which is very similar to the Flash available for wet testing, and will likely give me an accurate feeling for the Flash's soak.
So here's the problem... For the price of the Rhythm, I'm seriously considering it. HOWEVER, I can't wet test it or anything like it. I have a feeling I'm leaning that route, but I'd hate to buy it and not like it later.
I even asked the dealer to see if they'll be filling a Rhythm for wet test. they said possibly in the future, but most likely not. They were super helpful in answering my questions about the differences, but the wet test is the ultimate answer. I couldn't find another local dealer that sells it either.
What do I do????? Any recommendations!? Thanks in advance!
Title: Re: When you can't wet test...
Post by: castletonia on May 01, 2018, 08:16:08 pm
Tell the dealer you would like to try the Rhythm.  Since you are a serious buyer, no reason they shouldn’t be able to accommodate.
Post by: Hottubguy on May 01, 2018, 08:24:36 pm
Find a Caldera dealer and wet test a Vanto. If you like that then the rhythm is almost identical. Only differences are Spa Frog on Vanto and Cabinets are different. You have a couple Caldera dealers fairly close to where you are located. One in Newport area and one in Warwick. See if either has one filled.
Post by: jtd1216 on May 01, 2018, 08:41:21 pm
Castelonia, I did ask and they didn't offer it up.
Hottubguy thank you for that, that's an awesome idea! What's a spa frog?
Post by: Hottubguy on May 01, 2018, 08:53:58 pm
It’s a inline chemical dispenser for either @ease or bromine with minerals. Most tubs I sell I put on the @ease system.
Post by: castletonia on May 01, 2018, 09:05:01 pm
As a dealer, I have never turned down a serious shopper for wet testing.  Good advice by Hottubguy.
Post by: 39lasalle on May 02, 2018, 01:02:44 pm
We went and wet tested a Hot Springs Flair at a nearby dealer but was not able to buy from them because they were not in our area .   They had a better price as well.  We wound up with the BullFrog A7L.
39
Post by: jtd1216 on May 02, 2018, 01:45:34 pm
39, why did you like the Bullfrog over the Flair?
Post by: 39lasalle on May 03, 2018, 11:08:50 am
It wasnt that we did not like the Flair... there was over a thousand dollar difference from our "servicing" dealer and the the dealer where we wet tested!  When we wet tested the R7L and started talking price, we left with the A series for $9200 out the door. If I remember correctly(October 2016) this was more than a thousand cheaper than what we could get the Flair for.
39
