Original => Hot Tub Forum => Topic started by: Sol_Dahbrishinsky on August 22, 2004, 08:39:20 pm
I am about to Wet Test!!
Any suggestions on procedure in WT two manufacturers back-to-back?
OR just jump-in and enjoy!!!
Thanks for your input
:)To gain the most from the wet test, be sure the salesman helps you to understand the controls and allow him/her to show you how to sit, etc.
Have fun!!! :)
How many are in your family or will be using it regularly? If they can wet test with you, it can help it seem closer to what it will be when you get it home.
Wet testing is so important in deciding which tub to purchase. Here is some info that I hope you find useful.
1. If possible, test soak in the evening after the store is closed. This will help you relax and enjoy the experience more. It will also help you discover how determined the dealer is in helping you make the right decision.
2. Have the salesman explain the basic functions of the machine. Diverter Valves, Air injection buttons, opening/closing jets, lighting on/off. This will help you enjoy the features the tub has to offer.
3. Bring bottled water. You can enjoy this after you've been in the tub for about 10-15 minutes and you don't have to get out of the tub! It's very refreshing.
4. If the salesman is hovering nearby, ask him if he can give you some privacy. This will allow you to relax and play with the features of the tub without worrying about doing something "wrong" and being corrected by the salesman.
5. Bring your spouse/family/friend-whoever is going to be using the tub on a regular basis. This will help you determine if the tub is the right size. More importantly, this will determine if there is enough room in the footwell for everybody.
6. Move around in the tub, make sure you check out every seat, they are all different.
7. Allow yourself a minimum of 30 minutes in the tub to check out all the features. Take your time, it's an important decision.
Good Luck! Hope this helps.
Take a notebook or some paper and a pen. Write down your experience after you are done. What you liked, what you didn't like, what others with you did or didn't like, etc. This will help in a week when you are trying to remember the wet test and can only remember that you felt like a wet noodle going home!!!
Good luck!!!
