Original => Hot Tub Forum => Topic started by: Pat2017 on November 26, 2017, 04:39:59 pm
I have a 2003 Sundance Capri with circulation pump problems. Couldnt get the circ pump to work so I ordered a new one ($230). Cant get the new one to work either! Discovered I have no power at the pump connections. Replaced all fuses on the control board, but still get no power.
Any ideas?
More than likely you have a bad relay. Is your circulation pump wired with both the white and black wire right next to each other, or is the black wire hooked up to a relay and the white wire connected to the terminal block?
Yeah, there's a bunch of youtube videos that address board relays and no pump operation. Maybe you can find one that'll help..
