Original => Hot Tub Forum => Topic started by: bradleyabell on August 18, 2017, 08:20:26 am
Title: New Spa Owner - Chemicals Needed?
Post by: bradleyabell on August 18, 2017, 08:20:26 am
I just purchased the Bullfrog X8L and am going to be running the spa frog floating system with the bromine/mineral cartridges.  I wanted to ask on here what other chemicals I will require.  It looks like there is a BUNCH of stuff out there, but not sure exactly what all I will need.  Not sure if there is a master list somewhere with a guide or what, but any help is greatly appreciated!
Title: Re: New Spa Owner - Chemicals Needed?
Post by: Tman122 on August 18, 2017, 08:38:01 am
What you need is to test and tell us what the PH and ALK readings of your source water are. Then we can tell you what you need to balance your water.
Post by: bradleyabell on August 18, 2017, 09:16:19 am
The hot tub is coming in a few weeks...I just want to be prepared and have everything I will need in the future already at my house so I can be ready for any situation that may arise with the water.
Post by: The Wizard of Spas on August 18, 2017, 10:25:15 am
pH, alkalinity and sanitzier are the only "needs."  Everything else is ancillary to that.
Post by: Jacuzzi Jim on August 18, 2017, 10:59:36 am
What you should do is talk to the dealer you just spent 7 grand with.      Not that were not here to help you though   ;) And the wizard is spot on.
Post by: meriflower on August 18, 2017, 11:54:32 am
Does your dealer offer water testing?  You can take a sample of your water and they can run a test.  The test will tell you what your PH/alkalinity/calcium levels are at.  Here's what I would recommend:
PH/Alk Up and PH/Alk Down (I have both but use down more as my water is very high in PH)
Stain and Scale Control
Sanitizer start up packet
Non-chlorine Shock
Test strips
Sometimes dealers provide those when you purchase a spa, mine did, I received a "care package" when the spa was delivered.
Post by: Tman122 on August 18, 2017, 07:21:59 pm
The water doesn't have to come from the tub for you to test it. It needs to come from the spigot your going to fill your tub from.
Post by: bradleyabell on August 22, 2017, 03:00:14 pm
Just tested my hose water and my alkaline is 290 and PH is 7.9.
Post by: Tman122 on August 22, 2017, 04:20:16 pm
Not bad, what sanitizer method are you going to choose? This will greatly effect your adjustments to water balance. Bromine more than chlorine will drive down both your PH and you ALK, which is what you need.
Post by: bradleyabell on August 23, 2017, 10:20:56 am
I am going to be using the spa frog floating system (bromine+minerals).
Post by: The Wizard of Spas on August 23, 2017, 10:28:29 am
Dose with sodium bisulfate or muriatic acid to lower total alkalinity.  Higher alk/pH ranges can also cause a metal deposit (that "sandpaper" feeling on the shell) which is copper and or iron, common in source waters with higher pH/alk readings.  Thus, you may need a sequestering agent. . .
Post by: bradleyabell on August 23, 2017, 01:40:43 pm
Thanks for the info...What type of sequestering agent should I buy?
Post by: The Wizard of Spas on August 23, 2017, 03:53:12 pm
Most dealers have some sort of metal reducing agent that will meet your needs if that is the case.  This is not a rare product :)
Post by: Jacuzzi Jim on August 23, 2017, 08:02:31 pm
 First get the spa, fill it, let it heat up and see where your parameters are after a day. The spa frog probably has a start up sequence to do before using.          Then start working on what needs to be done to balance your water.
Post by: Tman122 on August 23, 2017, 09:23:20 pm
Good advice, don't panic your tub will be fine. Get it heated and start sanitizing, of course use it. Then see where it ends up. Wiz is right you will likely need some acid to lower ALK/PH. But go slow.
Post by: Jacuzzi Jim on August 23, 2017, 11:30:52 pm
 So call me crazy, but most times I run across scale issues with customers it's calcium and the PH/Alk out of whack. Many times it's people using calcium hypochlorite from wally world.   Not iron and or minerals.
  Thoughts?
Post by: The Wizard of Spas on August 24, 2017, 04:23:20 pm
  Thoughts?
You're not crazy:  Lower calcium levels will cause that as well.  I try to focus on pH/Alk first because if you don't know what it is, find out what it isn't.  pH/alk, then calcium levels and if the issues persist then check out metals, as you probably know.  But that is me.
Post by: BullFrogSpasMN on August 24, 2017, 04:41:21 pm
  Thoughts?
yup...water here in the midwest generally speaking is high in both unless the city is treating the high calcium, etc.....If I fill a tub here in my showroom and don't get at least 8-10 ounces of Bisulfate in it right away it will start to scale.  I just filled a 17' swim spa that took about 24 ounces of sodium bisulfate to drive that high Alk. down...normally I would opt for Muriatic acid but didn't have any on hand.  Just treat it right away and DO NOT under any circumstances let it continue to build up on the shell surface of your spa, that stuff will get harder than concrete and require a lot of work to re-cooperate from...
