Original => Hot Tub Forum => Topic started by: Constance on July 25, 2004, 03:02:29 pm
Title: Electric Cost to Maintain Tub
Post by: Constance on July 25, 2004, 03:02:29 pm
In shopping for hot tub (I'm a first time buyer), I'm getting so frustrated with trying to figure out which salesperson is telling me the truth regarding the insulation and electrically cost to run a tub.  I have one saleman who says the cost to run a tub 3-4 times a week is about $30 no matter what type on foam/insulation you have.  He does not recommend full foam and says it can cause leaks in the future due to the pressure of the foam.  Also it is more expensive to find and fix a leak in a full foam and one with a layer of foam on the tub, then air space with the box lined with insulation.
One saleman tells me that full foam is the only way to go.  He said the full foam helps prevent leaks by not allowing the pipes to shake.  He says full foam cost about 1/2 what the foam/reg insulation cost.  he said it would be about $20 a month locally.
The third dealer says the full foam is cheaper to operate and has encouraged us more toward full foam.
All three dealers carry full foam and foam/regular insulation tubs.
PLEASE HELP!!  What is the real scoop??
Title: Re: Electric Cost to Maintain Tub
Post by: Chas on July 25, 2004, 04:06:16 pm
Most major name brands tend to cost roughly the same to operate. And all major name brands have warranty coverage to ensure you don't have to worry about leaks anyway.
That's the very last thing you need to worry about: what type of insulation your tub has. Didn't any of these geniuses spend any time telling you about how much FUN it is to own a tub? Did any of them mention that it makes you feel better, sleep better and can actually improve your quality of life? Did they show you any jets that move up and down, rotate, pulse, pound, or even pamper?
Fountains that dance and dazzle? Sound systems to add a little sizzle to the scene?
Quiet moments together with loved ones, entertaining friends, solo soaking under the stars? Any of this ringing a bell?
Stick with a major name brand, ask about the features, and figure out which of those features equal benefits to you and your family. Then choose a color, and buy the thing.
You'll love it.l
Post by: ZzTop on July 25, 2004, 04:24:49 pm
Repost:
Full foam offers the highest potential insulating value.  It supports the plumbing (has less leaks) and insulates it from pipe movement and vibration.  It offers quieter operation.  It inhibits insects and mice from living in the cavity surrounding the tub.
Note: Our houses are fully insulated, (No Air Space in the walls), . . and we don’t leave off the interior drywall so that you can get to the plumbing lines to repair leaks.  If your contractor told you he was just going to put just foil in your 6" exterior walls would you let him?  Think about it.
Fridges are fully Foamed to maximize their R rating.  The more foam the better.
Coleman coolers are FULLY FOAMED!
A Thermos has space inside it but it is in a VACUUM.  Thermopane does not use a vacuum.
It makes absolutely NO sense to not support the plumbing lines with a little or no insulation in a Thermopane design.
Having pumps, wires and electronics operating in 100 plus degrees of constant heat cannot be good for their longevity.
While both systems work, the greatest long term problem is rigid support of the plumbing especially at the jets.  Each time the pumps are turned on there is a shock to the pipes which can stress the pipe where it is attached to the jet fitting.  As the tub ages these problems become apparent in some designs where no  or very little foam is used for support of the pipes.
Advantages of Thermopane:
If you like your mice dry roasted it is a great design.  It might be good for dehydrating meat and fruit, any one for some rodent Jerky? Oh yeah I almost forgot . . .you can keep your towels warm.
Yes, you can get at and fix a leak easier.  It seems that there are far fewer leaks in a full foam tub.   Just ask the guys that repair them.
It costs less to manufacture a Thermopane design., Foam is expensive.
Now Martha is the jury still out?
It also should be mentioned  that it is better to fully insulate all four sides of a Spa, than three, and that the greatest heat loss in a spa is at the waters surface.
So a Spa blanket and and a very well insulated Spa Cover are very big factors in fully insulating your spa and will be reflected in your total energy costs.
ps: You folks in sunny Florida might want to ignore some of this rant as us Northern folks just don't have your kind of weather.
Regards Zz
Post by: windsurfdog on July 26, 2004, 08:58:00 am
Zztop said:  "Coleman coolers are FULLY FOAMED!"
Man, after all of these years I neven thought of that one!  Thanks - I'll gladly use that. I may even go buy a cooler to keep on each showroom floor as a silent reminder.....
LOL         ;D :D ;D :D ;D :D ;D :D
And Coleman spas are not fully foamed........hmmmmm......could this make an even greater statement for thermopane?
Post by: Chas on July 26, 2004, 09:16:36 am
Well, since Coleman makes the chests, but doesn't make the spas, I would say no.  ???
I guess what I'm saying is: the REAL Coleman knows what works: Full foam.   ;)
Post by: rick on July 26, 2004, 10:55:40 am
Here we go again.  The Full foamers just can't stay shut up.  They are so threatened by a different technology that they start "circling the wagons"  anytime somebody has the gall to talk about benefits of thermopane.
All you spa shoppers out there, just listen to them.  Make your own judgments but just listen to them.   If they were sooooo configdent that their full foam technology was soooooo much better than thermopane, they wouldn't be spending sooooooo much time trashing thermopane.  They would ignore this "stepchild" technology like they should be ignoring a renegade Haven spa owner.   But they don't do they?  They react like anybody would react when they are truly threatened by something or somebody that doesn't do things the way they do.  It's spa racism I tell ya!!!  :)
Such a bold statement Chas,  to personally know what Coleman thinks.   I didn't know you had such close connections with the R&D staff at the real Coleman.  Again people, not to be confused with the "fake" Coleman spas that are being made by a company called MAXX.   (and why is it assumed that MAXX must be making an inferior product because it used to be made by Coleman?)
So Coleman knows what's right with spas because their ice chests are full foam?
I believe before Coleman sold the rights to MAXX on their spas that they were already doing them thermopane.  So yes, maybe Coleman does know the way to go.
Jees you guys,  can't you give it a rest and just laud the benefits of your own stuff?   It's just like these politicians out here.  They spend more time dissing the competition than speaking of the positives of their agenda.
For what it's worth to all you new spa shoppers,  I've owned a Coleman for a half year now and it costs me  $20 a month in electricity.  I run 2 3hour filter cycles a day plus this spa gets used every day, multiple times.   The full foamer's claim to better insulation is a tired one.
Nothing like a good religious war to get one's blood boiling!   Bring it on guys.
Post by: empolgation on July 26, 2004, 11:43:06 am
Is thermopane available for my house? Or is sheetrock good enough?
... I hate putting all that insulation in the walls.
Post by: rick on July 26, 2004, 11:17:32 pm
Well if you had the desire to fill your house up with water and heat it up, I'd go with thermopane for the house.  Sure.  And don't forget to tear down your wood frame and redo it in Galvalume. I'd probably go with a wetwall instead of the "now not so drywall".  :)
On a side note, I was just thinking too,, (I know, that's not very smart),,  but thinking about the Coleman ice chests and their full foam implementation;  it only makes sense that the chest would be full foam, your walls are too damm thin to even bother with a thermopane design.  No brainer.  So bad analogy.    :o
Post by: spahappy on July 26, 2004, 11:52:55 pm
Way to go Rick!!
Constance this is a repost of mine. Look up the websites on the bottom for a unbiased comparison of insulation.
I just have to jump in here. Before I start, it's great to hear from Superted and Rick! This board needs more Coleman Spa owners/dealers, ect. on line.
I’ve been selling Coleman Spas since 1994 in North Dakota. Yes that is right above South Dakota, and we are not the end of the earth!! However on a clear day if you stand on you car you can see it from here. Sorry, a little N.D humor.
Zz you are so right in your observation comparing our house insulation to the insulation in spas. We make our houses more efficient by putting insulation on our walls and attic. We install air tight windows and put high efficiency furnaces inside to heat our homes. This seals cold air out and warm air in… This is what Coleman’s Thermo Lock technology does. They start be spraying 2 to 4 inches of high density foam on the spa shell. The tubs have a solid ABS pan bottom with 1 ¼” polystyrene bead board over that. The beadboard has a lining of reflectex. Reflectex is a silver reflective foil that will reflect radiant heat from the spa’s plumbing and equipment back up onto the spa shell. The cabinets are maintenance free Duramax, which is mounted on ABS board for strength than attached to the 1 ¼” poly-beadboard and lined with the reflectex. Coleman recaptures all of the heat generated by the equipment because we have a sealed, insulated, heated, dead air space all the way around the shell of the tub. Just like the technology in a house we seal cold air out and warm air in.
The whole hype on the board about needing full foam to support plumbing is not at all true. First of all if that were the case, why would Coleman have a 5 year plumbing warranty? They would go broke fixing all the leaks. Second, take a full foam tub like Sundance. (I’m not picking on Sundance I think they have a good product!) look at the space they have their equipment in. What you will see is plumbing coming from the foam and into the equipment this is totally not supported in that part of the spa. How does that work?
The Thermo Lock also insulates the equipment noise. When we do tradeshows and fairs I always check out the competition, our spas are always quieter than full foam spa’s.
My spa is outside on the northwest side of my house with nothing around it. The winters here are cold!!! And long, it snowed two nights ago May 25th. My spa runs me around 25.00 to 30.00 in the coldest winter months, and we use our spa all winter long.
 Here are some websites to check out on foam insulation.
http://www.eere.energy.gov/consumerinfo/refbriefs/ed3.html
http://www.buyersinspectionservice.com/faq-insul-allabout.html
Now Martha is the jury still out.
         Spahappy
Post by: spahappy on July 27, 2004, 12:05:32 am
Excuse me but coolers are not fully foamed. The last time I put my beer in one it went like this...
The cooler has insulating walls, I put the ice in, put the beer in, left some air space so my beer doesn't get smashed and tadaa,,, thermolock!!!
Full foam dealer have been resorting to this showroom prop for years. In my experience most consumers get turned off by such antics
Spahappy
Post by: spahappy on July 27, 2004, 12:32:03 am
Per Chas
I guess what I'm saying is: the REAL Coleman knows what works: Full foam.[/quote]
Chas,
For as long as you've been in this business you should remember that Coleman started making their spas right from the start with thermolock insulation. This was well over a decade before MAAX purchased the spa division from Coleman.
Since you stated yourself that the cost to run per month is roughly the same, why the jabs at Coleman?
Didn't you just say that a spa is all about family time and how it will make you sleep better and feel better and improve your life and just pick the color and buy it.
Don't we all agree the wet test is the most important step in purchasing a spa?
I've never said a negative thing about Hotsprings, no matter how I feel about them, or any other brand by the way!!! Not even Haven!
I feel for new spa shoppers like Constance. How they must veiw the salesmen and saleswomen in this business. It's no wonder she's fed up with spa shopping.
Hang in there Constance! Do yourself a favor and wet test any spa you're interested in. When you find the right one, and your sitting in it in your yard, this will all be a distant memory.
Spahappy
Post by: spahappy on July 27, 2004, 12:48:34 am
Zz,
I admire your conviction to full foam and the research you've done on spas. But as you once told me, change is a way of life. I feel the winds of change in this industry. I predict more companies will turn to steel frames, ABS solid pan bottoms, and yes thermolock!!!
Spahappy
Post by: ZzTop on July 27, 2004, 12:55:54 am
Coleman's (MAXX) steel frame is an excellent idea.  Much better than other manufacturers using steel.  It would not suprise me that the industry goes this way in the future.
As for the rest, time will tell.
Regards, Zz
Post by: Ready2Buy1 on July 27, 2004, 11:59:00 am
We have the Sundance Optima, which is a fully foamed spa, and during its first two months of use the average electric use for the tub was $30.00/month.
I will note that our spa is outside and we keep the insulated cover on when not in use. We have our temperature set to 85 degrees...although the water temperature has been between 92-94 degrees with the thermal affects of the sun (maybe the insulation too).
The spa is programmed to run the four regular filtering cycles in a 24 period and we have ozone on the spa too...
Post by: ebirrane on July 27, 2004, 01:09:36 pm
Good lord, spahappy!
I know that hot air is a hallmark of the thermopane design, but I didn't know it was also a characteristic of the people who support it!
Just some gentle kidding on seeing, like, 7 posts in a row. 8)
-Ed
Post by: windsurfdog on July 27, 2004, 01:24:27 pm
Zztop said:
"Coleman's (MAXX) steel frame is an excellent idea.  Much better than other manufacturers using steel."
Zz,
I know it's an election year and there is much mudslinging about but........
Name the manufacturers to which you refer and explain yourself instead of just spewing comments like that.
Sheesh, the politicians already make it murky enough......
Post by: spahappy on July 27, 2004, 02:41:45 pm
-Ed
Iuote]
Well I'm a woman who talks for a living, sorry about getting so gabby. I'll try to ration my posts over a longer time span,( if I can )
I used to say my mouth is how I made my living, but that just was never taken the right way!
Spahappy
Post by: Chas on July 27, 2004, 03:11:31 pm
True. I sold them back in the 80's right after they purchased California Cooperage and put the Coleman name on them.
I must apologize that you took it that way. I din't mean to jab at anybody. If you will kindly reread my first post, which is the second post in this thread, you will see that I told the shopper to stick with a major name brand (Coleman IS a name-brand).
I said it, and I meant it.
Yes! I couldn't have said it better - I agree 100%
Thanks. As I said, I was not taking a jab at Coleman - the stuff about the coolers was meant in fun - I sometimes forget how sensitive people are about this topic.  The coolers work, and the spas work. I really believe that any good insulation system will work - Coleman puts enough foam on the back of thier tubs to just about qualify as full foam, and yet they still add more to the cabinet. The two systems work great in tandem: the hot air adds to the foam. It works.
Spahappy
Post by: Constance on July 27, 2004, 06:36:05 pm
WOW GUYS!!!  I didn't mean to create such a fuss!!  I am just a confused first-time spa shopper!!  One salemans says the cost to operate a thermopane spa like his Phoenix is the same costs as any full foam.  Another saleman sells Sweetwater, Jacuzzi, Sundance and I forget the brand with the thermopane, says it cost twice as much to heat the thermopane.  And the other salesman with the Tigerriver, Hot Springs and Dynasty says the thermopane costs about $10 or more per month extra for the thermopane.
I just needed some input, and thanks to all of you!!  It's been interesting!!  Your postings made me search for a Coleman dealer.  I found one in Lima, Ohio about 30 miles away.  I plan on checking them out.  I'm going to start wet-testing hopfully this week.  My concern is on the Phoenix spa.  The price for the amount of jets makes it look like a great value.  It runs about $800 to $1200 cheaper than other brand with similar features and size.  The dealership has an excellent repretation in the community, but they do not have any tubs filled to wet test.  The salesman said it is not necessary.  My hairdresser has one that I may be able to test.  I've gathered that the Phoenix brand is not popular with many people on this site.
Concern 2:  What about the dried critters in the thermopane tubs???  I live in the country, and am concerned about animals getting into the bottom as the tub will set on my deck.  Aren't these things sealed so that animals can't get into them???  Could they chew into the bottoms of the tubs?
Concern 3:  Is it best to have a 24 hr circulation pump or have the tub run for a time a few times a day?  One salesman said that the 24 hr pumps are not usually covered under the warrentee and are expensive--$200 to replace and so wear out quickly.
I greatly appreciate all of your input!!!
Connie ::)   ???    8)
Post by: Steve on July 27, 2004, 07:09:02 pm
Hi Connie,
With these salesman, all you need to do is ask for proof and not salesmanship. If they have proof to back up  their statements then great. If not, they're talking out of their a$$es. Demand it if they start "dissing" another brand or designs.
All major brands are very close in operating costs regardless of insulation design. There might be a $3-5 month difference but I'm guessing if you have $6-10,000 in disposable income for a new hot tub, that doesn't play much of a factor.
You are getting way off track with your priorities IMO.
You can decide the order these should be in but these are the main factors...
Comfort for the whole family
Therapy - specific to YOUR needs
Low maintenance
Energy efficiency (under a buck a day to operate)
Dealer reputation & service history
Value
Post by: Chas on July 27, 2004, 07:14:17 pm
Don't worry, everyone needs a hobby!!
One salemans says
Good name for a rock band, but the fact remains that most brand-name tubs end up running about the same. Now - if you get a tub with huge jet pumps and run them a lot, you'll pay a few bucks per month more. The only real energy hogs are the home-center cheapies that have virtually NO insulation.
For whom? Him? Tell him it's a 'must' for you.
This can be a great way to get a nice test soak. And a rinse.
Some tubs are better sealed than others. Check with the dealer - and ask to see the bottom of a spa. HotSpring has a very hard shell sealing the bottom of the tubs, other brands have plastic sheeting, even fiberglass.
There are good spas that have circ pumps, and good spas that don't. I like them because they are silent, keep the water in motion all over, most also filter as an added benefit, and often they are set up with ozone systems which can then put ozone into the tub on a 24 hour basis. Very nice.
they One salesman said that the 24 hr pumps are not usually covered under the warrentee and are expensive--$200 to replace and so wear out quickly.
That is an error. Go to a HotSpring dealership and get a full and complete copy of the warranty. Or download it off the 'net. The circ pump is covered fully for five years, parts and labor. Most of the major brand-name tubs are the same.
Connie ::)   ???    8)
No charge.
Post by: empolgation on July 27, 2004, 07:21:24 pm
...but they do not have any tubs filled to wet test.  The salesman said it is not necessary.
In general I agree with Salesmen who say this...
Right he is! - it is not necessary... simply because I wouldn't be interested in a dealer that tells me it's not necessary to wet test a spa.  Unless I want to use it as a planter box. How could it not be necessary if you want to know what you are buying. What? you want to try on those shoes before you buy and can't return them...
I would say thanks for the info and head on down to the dealers that think wet testing is necessary.
Post by: spahappy on July 28, 2004, 09:58:21 am
Connie
Don't worry about the critters getting in a Coleman spa! I'll try and post a picture of our solid ABS pan bottom which  bolts to our galvalume steel frame.
Coleman seals their cabinet to keep the equipment heat in, therefor you'll see, there isn't an area for mice snakes wasps ants or any other vermon the gain access to, and move in.
Take care and let me know if you have any questions on Coleman spas. Good luck on your wet test!!!
Spahappy
Post by: Spatech_tuo on July 28, 2004, 10:24:12 am
It seems like they all do!!  ::)
Post by: txwillie on July 28, 2004, 05:42:37 pm
Are there any concerns with thermopane designs keeping heat inside the cabinets and cooking motors, etc. in a hot summer climate like Dallas?
Post by: windsurfdog on July 29, 2004, 08:46:16 am
I would think that the thermopane design may be more suited to helping keep motors cooler in hot climates.  My LSX has 6 vents in the cabinets to help disperse heat plus the motors' (3 therapy, 1 circ) locations are spaced around the tub.  I'm not sure about the full foam tubs but I think most have an equipment bay for all pumps that could warm up significantly in warmer climates (full foamers, please correct, if wrong.)  Anyway, with Master Spas I had the choice of FF or TP.  I felt TP would suit my Florida environment better.  But I wouldn't let the FF/TP controversy drive my decision--either should be fine.
Post by: Brewman on July 29, 2004, 10:39:40 am
Our full foam spa has an equipment bay, but it is on the outside of the foam.
I don't believe that I have excess heat buildup in the cabinet due to the way it's foamed, but I live in the Minneapolis burbs, so we really don't have the hot issue, we have to worry about really cold winters instead!
I do not want to create another spa insulation holy war, but....
If a thermopane spa has vents in the cabinet to let out heat, what would happen in the winter?  Wouldn't you want to keep that heat in?  Just curious.
Post by: Wisoki on July 29, 2004, 12:42:52 pm
Wanna bet? Jacuzzi and Sundance (I can't speak to hotspring) have on their circuit board a "summer mode." Because the heat within your component bay is SO hot, the circulation pump automaticaly shuts down. They claim that this is so that the circ pump doesn't transfer heat into the water making it hard to keep the temp down. Well if that little 1/20th HP motor can create enough heat to over heat the water, imagine how hot it is in the equipment area! :o
Post by: Brewman on July 29, 2004, 12:50:26 pm
Good point.  Now you went and got me curious.    I think I'll do a temperature check expriment this weekend, and see exactly how warm it gets in there.
Post by: wmccall on July 29, 2004, 01:03:08 pm
As much as that argument comes up on this and other boards, that may be the best statement to make.
Post by: Chas on July 29, 2004, 02:41:46 pm
You're not quite right on this one, Frank. The summer timer, which HS also has, IS, in fact, to keep the tub from overheating in extra hot weather.  And it IS, in fact, because the tubs are so well insulated that even a tiny amount of heat from the circ pump will add up over time and push the water temp up.
As to the temp in the motor compartment - I'll speak for HotSpring spas here - the compartment stays warm, but not hot during heating. The compartment is insulated top, bottom, and all sides except for the door. If you live in ice, you can get a kit to insulate the door.
When the jet pumps kick in, air is drawn in through a vent at the bottom of the door, through the motors, and ducted out to the enviornment. On it's way, it passes a tap for the jet air system, and as much hot air is fed to the jets as you choose - to recycle the heat from the motors and still keep the temp in the motor compartment under control.
Keeps the motor compartment temp under control, adds life to the motors, recycles the heat from the jet pump motors into the water, AND quiets the motors down because of the shroud on each one.
(http://www.hotspring.com/Spas_Built_Last/gifs/wavemaster_pump.gif)
Post by: Wisoki on July 29, 2004, 04:52:11 pm
Like I said Chaz, "I can't speak to HotSpring." There is no such "shroud" in the Jacuzzi Sundance product. Nor is there any venting system that would expell hot air while drawing in the cool air. Now they do have some funky looking short slats on the front cabinet with 2 half oval cut outs in the abs base where the skirt is attached about 1/4 inch wide and 4 inces long each. Maybe thats their idea on cooling their pumps. Maybe nothing, I know it is. Then again I's jist an ijit from Ineanna.
Post by: IonHeaven on July 29, 2004, 06:39:20 pm
Hi,
The Marquis dealer in my area told me that Marquis did away with the circ pump because they were one of the main things that needed replacing. He said that he thinks Hot Springs is soon to be phasing them out as well.  ??? IonHeaven
Post by: Chas on July 29, 2004, 07:25:35 pm
Gotcha. Thanks.
How hot is it in Indiana these days?
Post by: txwillie on July 29, 2004, 08:21:34 pm
Please do Brewman and post the findings. As for me, I'm headed out this weekend to checkout a few dealers and wet test one or two. Trust me, I'm not beating myself up about the insulation thing
Post by: McKevin on July 30, 2004, 01:40:06 am
Not much of a test about summer temps, but we don't seem to be having summer temps this year. :)
FWIW, my #1 pump has been runing on low, and the #2 & #3 pumps on high for around 2 hours now.  The room temp is 75, the temp inside the (thermopane) cabinet is 90.
Don't know what that means, if anything, but until the temps get to 100 again it's all I got...
McKevin
Post by: Wisoki on July 30, 2004, 11:59:01 am
This will probably go down as one of the coolest summers on record. I don't think we've hit 90 yet. The humidity's been low. Kinda wierd, but I'm not complaining!
Gotcha. Thanks.
Post by: Brewman on August 02, 2004, 09:13:13 am
I was a little busier than usual this weekend, but I did get a chance to to a quick temperature check.
I put a thermometer probe into the equipment bay thru the slats in the skirt.  The temperature in the bay was about equal to the ambient temperature- about 82 degrees.  I turned on both pumps full speed, and the temperature in the cabinet gradually rose to just over 100 degrees in the 20 minutes until the pumps shut themselves off.  I didn't turn on the blower, that may have added more heat, but we never use the spa with both pumps at full bore with the blower.
Post by: Constance on August 02, 2004, 10:58:47 pm
 ;D Thanks to everyone for your input!!!  I've really enjoyed the conversation!!!
Connie :D
