Original => Hot Tub Forum => Topic started by: tommyp on October 29, 2016, 07:57:36 pm
New to tub ownership. I seem to have an issue w/re-occuring light foam, and what looks like a soap scum type of film in a line about 1/2 in above my water, as well as on the plastic sides to where my filter is. Any help would be greatly appreciated. Chems seem ok, and only way i seem to keep my water clear is w/a good amount of chlorine. Ph/Alkelinity both seem on the mark.
Foam is generally caused by what YOU introduce to the water. Makeup, lotion, hair products, aftershave and the like. And yes, chlorine will help.
You should "purge" the plumbing and jets using an effective hot tub plumbing cleaner. Brand new hot tubs should definitely be purged the very first day it is filled. Manufacturer's test all hot tub plumbing with water before shipping and this can lead to a biofilm buildup which will cause the foaming you are seeing. Some manufacturers and dealers are hesitant to acknowledge this fact since they don't want people to think that their new tub is "dirty". Plus, many dealers are too busy and cannot take the time to clean and purge the plumbing of every new hot tub they deliver and set up. Biofilm is a real problem but one that will be overcome with effective cleaning and purging protocols. You will be absolutely blown away when you see the buildup and gunk that is inside all new hot tub plumbing. Jetted bathtubs too. You need to initially purge and then do so every 6 months at a minimum. Smaller hot tubs that get lots of usage should be purged more often. Water maintenance will be a breeze if your plumbing is not gunked up. Be sure to clean the filter(s) with a reliable product at regular intervals. A little time spent doing these two things will benefit you immensely.
Have you talked to the manufacturers about what they use to test new hot tubs? Is it just plain water?
Speaking with the many manufacturer we deal with it seems that this is the case. Water from a holding tank is introduced to the new hot tub, plumbing and jets are checked for leaks and then they reclaim that same water. I am unsure as to how often the holding tank water is changed.
I talked to one manufacturer who uses water and 5 other ingredients. Sanitized water being the key.
Biofilm grows in hot tub plumbing no matter if sanitizer is used or not. Look at the best kept and treated hot tubs, biofilm still grows inside the plumbing. I realize some manufacturers use treated water to test new hot tubs in an effort to mitigate biofilm formation. However, when the water is drained after teating, some is left behind since even air drying the lines still leaves some moisture in the lines. Now the tub is shrink wrapped and/or cartoned for shipping. It may be weeks or months before it is finally delivered to the customer. In that time biofilm colonization gains a foothold. There is no way around it. You need to purge all new hot tub plumbing initially to lessen or eliminate this situation. I realize some dealers don't like to hear this or have consumers know this, but this is reality. Consumers should Google "biofilm in hot tubs" to gain an understanding as to what it is and how they can control it. The CBE or Center for Biofilm Engineering is also a great source of information.
How does one purge - simply drain the tub and refill?
Theres several products out there. Someguy sells one, but there are others.
Pour in, run jets, drain, rinse. Follow directions.
I wouldn't assume that's your problem. How much do you soak? How many people? How clean are the people? How often do you clean the filter? How often do you change the water? As stated foam can be caused by many things introduced to your water.
Great question. Add the cleaner to the filled hot tub, put the filter(s) inside the tub, and run the jets for 30 minutes in the filled hot tub. Drain it, rinse it, wipe it down, refill it, get chemicals correct ans younare all set for 4-6 months. Watch how easynit is to maintain crystal clear water.
