Original => Hot Tub Forum => Topic started by: fixitmyself on October 15, 2016, 09:58:11 am
Title: Intermittent FLO error with new filters, flow switch and circ pump
Post by: fixitmyself on October 15, 2016, 09:58:11 am
I recently replaced the circ pump and flow switch due to FLO errors.  Now I have an intermittent FLO error.  When the error is on, the circ pump still runs, but the other two pumps do not.  Any thoughts?
Title: Re: Intermittent FLO error with new filters, flow switch and circ pump
Post by: Chas on October 16, 2016, 11:47:00 pm
Most common problem would be the connections at the motherboard. Those tiny little things are often the culprit. Check them one by one.
HTH
Post by: Clayterickson on November 07, 2016, 01:46:24 pm
Did you ever figure that problem out.  I am.having the same problem.
