Original => Hot Tub Forum => Topic started by: sobe on July 20, 2004, 04:45:26 pm
Title: Just Curious!
Post by: sobe on July 20, 2004, 04:45:26 pm
How much time does everyone spend on proper maintainence of  the tub?
Title: Re: Just Curious!
Post by: Wisoki on July 20, 2004, 05:44:33 pm
5 minutes 1 x per week. Any more than that and you are over thinking your water chemistry. Keep in mind, your water will never be perfect. Every thing that comes in contact with the water changes its makeup. Air, sun light, people, all affect the balance. Once you have it initially balanced, you should take a one time a week test and make your small adjustments. Sanitizer should be increased or decreased as needed based on usage.
Post by: Brewman on July 20, 2004, 05:48:55 pm
For me, just a few minutes a week to add shock, and sanitizer if necessary.  Test only takes a minute.
Several times a year I change the water, replace the filters, and clean the cover.  But day to day maintenance consumes very little time.
Post by: Tman122 on July 20, 2004, 05:57:21 pm
Yep 5 minutes a week or every other (depending on usage) to test the water and a few seconds to put in dichlor after use. Filter rinse once a month cover cleaning 3 times a year.
Post by: wmccall on July 20, 2004, 10:30:52 pm
What he said, except I rinse filters every two weeks. Your mileage may vary.
Post by: Spa_Tech on July 20, 2004, 11:21:17 pm
I maintenance several spas a week-
It works out to about an hour a month with water testing, adjustment, sanitation, cleaning the filter, cover, treating the vinyl with a protectant and vacuming.
Post by: johnnythunders on July 20, 2004, 11:22:01 pm
Clean filters every 2 weeks,,,,,Since i bought 8 nature2s i think i will change my water about every 2 too 3 months.johnnyT :P
Post by: Spatech_tuo on July 21, 2004, 01:25:59 am
3.47 min/wk plus cleaning the filters monthly (and any time I drain)
Post by: wmccall on July 21, 2004, 07:56:10 am
3.47 min/wk
Aproximately :)  Spatech becomes  Spock.
Post by: Brewman on July 21, 2004, 08:04:23 am
Spocktech T.U.O?  I like that!
Post by: autoplay on July 21, 2004, 09:00:58 am
Spocktech LOLOL.  At least if he's bestowed that title.....He can use with confidence the line......"I find that highly illogical Jim" ;)
Post by: Lori on July 21, 2004, 12:48:37 pm
LOL!!!!!
;D :) ;D :)
Post by: doodoo on July 21, 2004, 12:55:23 pm
Who was it that said.....soak long and prosper?
lol
